Fat PS3 running hot?
PostPosted: 17:41 - 15 Jan 2013    Post subject: Fat PS3 running hot? Reply with quote
My fat PS3 had gotten noticeably nosier recently so I thought I would strip it down and clean it up.
It was dead easy far easier than an XBox.
You'll need a thin T10 torx (a normal bit was too big) and a Phillips. I noticed the torx bit looked like a security one with a lump in middle however a normal t10 worked for me. Thumbs Up
Pop the rubber bung out of the bottom undo the torx then slide the top cover off. undo all the screw here, they are all the same length barring one where is shorter, conveniently that hole is marked 'S'
There is a clip in one corner you have to release and the lid comes off. then you can seen the PSU and Blu-Ray drive these a easy to remove unclip the cables and undo the screw on the PSU (5?) the BR drive was held down by the previous casing screws.
I opened up the PSU (3 Screws) and gave it a blow out.
The next part isn't a clear but basically remove all the screws you see and pull the mainboard off it is a little fiddlely and needs the plastic casing to be bent.
BTW by this point I had removed several pounds of dust Laughing
Now you can see the heatsinks and fan. remove all screws and pull them out. I cleaned up the CPU and GFX chips and their heatsinks, then applied some AS3, I then de-dusted the fan and put the lot back together.
Result, my PS3 is quieter than ever this should ward off the LOD for a while.
Please note I neglected to reconnect the BR data cable properly so make sure that is in tight.
I'm recommend this to anyone whose PS3 sounds like a hoover.
PostPosted: 19:34 - 15 Jan 2013    Post subject: Reply with quote
Cool How To, Bro. Literally. Thumbs Up
On a related note, Mrs B's senescent little K8 flexAtx desktop was screaming like a kamikaze and going into thermal seppuku, so I had it apart. The processor looked like it had starred in a thermal gloop bukkake. A little is good, so more must be better, eh? Clean, tiny spooge, gentle rub, clamp, and it's running smoother than a hentai clunge now.
PostPosted: 19:53 - 15 Jan 2013    Post subject: Reply with quote
I sorted my mechanics PC with a similar issue it was ancient, apparently his father in law got it from him, it was surplus from a school 10 years ago. Had a 366mhz processor and I think 64mb of ram Laughing It had XP on and had never been on the internet so I can only assume was original XP out of the box.
I wouldn't turn on so I opened it up it had what can only be described as a carpet over the heatsink and fan, it was AT least 6mm thick solid dust it came out in one piece Laughing
nowhere.elysium
The Pork Lord
PostPosted: 20:05 - 15 Jan 2013    Post subject: Reply with quote
Could be worse. At work, in the library, I once had to service a PC that had not only had the front USB panel mashed in so hard that the plate it was mounted to had snapped the retaining tangs off, but some prat had decided that what this computer needed was more chicken bones. I found three in there, and promptly lost all remaining hope for humanity.
This is the same workplace where I have had a laptop brought to me to be fixed, which had been spraypainted red. When I asked why, I was told (with a totally straight face, and what sounded like true conviction) "well, it's the fastest colour, innit".
Again, in the same place, I was handed a laptop by someone who was tangentially associated with my group of friends, and asked to fix it, since it had suffered from a spillage. So, I strip it down, and find a shedload of semi-crystallised crap in there. Once I'd scraped all of it out, I found myself wondering as to what it all was. It transpires that this girl had been cooking up ketamine on her brand new (at the time) Powerbook G4. As one does.
PostPosted: 17:11 - 16 Jan 2013    Post subject: Reply with quote
At school we were arseholes with the IT stuff. You would have hated me. I remember keyboard and mouse Baseball, and just stealing all the mouse balls. This happened so many times that at the end of each lesson we all had to show that the mouse still have a ball in it Laughing
We also did the classic of auto replace in word.
Change Joe Bloggs to Joe Bloggs is a fucking cunt. Laughing
and I'm proud to say I 'hacked' the games out of our school PC's.
I can't remember exactly but they had removed the shortcuts to the games and had the PC's looked down so you couldn't access the system files.
I found if you used the help it had a direct link to all the games in it Laughing
In my day the PC's had turbo buttons. Laughing
The last post was made 13 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 49.35 Kb
