Bandit 600 not starting
SteveSmith
PostPosted: 18:52 - 16 Jan 2013    Post subject: Bandit 600 not starting Reply with quote
I'm sitting at work waiting for the AA to turn up to my Bandit 600 which is refusing to start. The starter motor is turning over happily, but apart from a couple of coughs, the engine isn't playing. It normally takes a fair bit of choke and a couple of attempts in the cold, but now there's nothing at all. It rode in this morning without any problems, and there's at least half a tank of fuel in it.
It's my first bike, and apart from being a little bit rough at low revs (around 3000ish) it's been great so far.
Any guesses?
Steve.
PostPosted: 18:55 - 16 Jan 2013    Post subject: Reply with quote
How wet is it where you are?
SteveSmith
PostPosted: 18:57 - 16 Jan 2013    Post subject: Reply with quote
Not at all. Been dry all day.
Steve.
Ripp3rCrust
PostPosted: 19:45 - 16 Jan 2013    Post subject: Reply with quote
Not sure if this will help but your problem sounds similar to how my Bandit acts when it's really cold, just the engine spluttering and struggling to start with couple of coughs.
The trick I use however is clutch in, use no throttle whilst pressing the starter. As soon as the bike attempts to start give a tiny bit of throttle until the bike starts, then start revving! May take a couple of attempts but as soon as the engine has warmed slightly it ticks over fine. No idea what the underlying problem is though.
Good luck, let us know how it goes!
SteveSmith
PostPosted: 20:38 - 16 Jan 2013    Post subject: Reply with quote
Thanks, mine's the same and I tried all that. One AA guy has come out and reckons it's fuel starvation somewhere, but they can't do much about that at the roadside. I'm now waiting for another one to come out with a truck and lift the bike to a garage.
Could be expensive!
PostPosted: 20:42 - 16 Jan 2013    Post subject: Reply with quote
Fuel starvation?
1st, check the vacuum pipe is seated properly.
2nd, turn the tap to PRI and see if fuel comes out of the fuel tap.
If it does, try ON. If it does...you are in trouble. Means the tap may need a rebuild. Should run fine on PRI though.
If it isn't that then check some filters, you usually have an in line filter, could be blocked.
Hyaon
PostPosted: 20:43 - 16 Jan 2013    Post subject: Reply with quote
If its like my bandit was, starter+twist throttle full. Oh and put the side stand up.
Mod2 Passed 30/03/2011!
CBF125>GSF650 Bandit K8>B-King 2008+R1 2002
PostPosted: 21:15 - 16 Jan 2013    Post subject: Reply with quote
If it has an alarm/immobiliser - suspect that first!
SteveSmith
PostPosted: 21:54 - 16 Jan 2013    Post subject: Reply with quote
Well, I'm home now and the bike is chained to a lamppost outside a garage. I guess I'll find out in the morning what the problem is. Thanks for the suggestions - I'll let you know if any of you got it right!
Cheers,
Steve.
The last post was made 13 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 60.22 Kb
