| stranger12 |
 stranger12 World Chat Champion
| stranger12 |
| P.addy |
 P.addy Red Rocket
| Srengam |
 Srengam Scooby Slapper
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:28 - 17 Jan 2013 Post subject: |
It's a 125, it should be able to come off the choke in seconds. Lawd's sakes, I start my 500 on full choke, ride away immediately, and I'm off choke by the second corner on Scumbag Estates.
You'll want to increase the idle speed and possibly enrich the idle mixture. How that's done is entirely down to your bike.
What bike do you have? Do you have a manual for it?
I'm going to stick my neck out and assume that you've got a CG or Chinese copy (fair odds), in which case you're looking for these:
https://2.bp.blogspot.com/__DYtEEjm5wE/SdE2lp3cYgI/AAAAAAAAABo/92yQIiecTJM/s320/carb.jpg
If you've got a bike designed in the latter half of the 20th century though, where the choke also increases the idle speed, then I'd go with 'blocked idle jet'. That's a carb strip, you can start mucking around with Redex or a carb cleaner spray, but you're only wasting time and money. ____________________ Biking is 1/20th as dangerous as horse riding.
| P.addy |
 P.addy Red Rocket
| bikersupermot... |
 bikersupermot... Could Be A Chat Bot
 Posted: 18:41 - 18 Jan 2013 Post subject: |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:53 - 18 Jan 2013 Post subject: |
GPZ is water cooled, and I very much doubt the OP is on a 2-smoke.
Anyway, he's apparently sorted his problem, so that's all right.  ____________________ Biking is 1/20th as dangerous as horse riding.
| Nick_Giles |
 Nick_Giles Could Be A Chat Bot
| stranger12 |
 Posted: 23:02 - 02 Feb 2013 Post subject: |
| Rogerborg wrote: | It's a 125, it should be able to come off the choke in seconds. Lawd's sakes, I start my 500 on full choke, ride away immediately, and I'm off choke by the second corner on Scumbag Estates.
If you've got a bike designed in the latter half of the 20th century though, where the choke also increases the idle speed, then I'd go with 'blocked idle jet'. That's a carb strip, you can start mucking around with Redex or a carb cleaner spray, but you're only wasting time and money. |
thanks.
i did change the idle to 2000 when warm and it seems to be ok now.
although this did not made much differene but to increase the idle so it could keep it on
once i changed the spark plug which had done 7000 miles it all seems good now
how should one warm his bike up? i believe in you ride it with low rev and not let it stand for 10 mins
idle may not very good for the engine so anyway i turn it on wait for a minute if i can or ride of straight away |
| P.addy |
 P.addy Red Rocket
| stranger12 |
The last post was made 13 years, 272 days ago. Instead of replying here, would creating a new thread be more useful? |
