AA on their way, 2-3 hours. Lock will not turn.
skylineonfire
PostPosted: 19:47 - 17 Jan 2013    Post subject: AA on their way, 2-3 hours. Lock will not turn. Reply with quote
Luckily I'm at home!
Went into the bike shed this evening about a hour ago, lock was frozen as usual. Heated it with hot water bottle normally works, when that didnt work, boiling water on it, no luck, WD40, no luck, lock anti freeze stuff, no luck.
Something must of actually broke inside it, the key goes in fine now, it just will not turn. Any ideas whatsoever? I desperately need to nip to the shops and the 650 is at my friends as I caught a taxi home the other night, so no transport. AA are approximating anywhere between now and 2-3 hours.
Cheers,
noobRider
PostPosted: 19:51 - 17 Jan 2013    Post subject: Reply with quote
It is the right key? Smile
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
Eddie Hitler
PostPosted: 19:57 - 17 Jan 2013    Post subject: Reply with quote
Tried pushing it down (the key into the barrel), whilst waggling the handlebars?
Sounds like its the little lock in the barrel thats not budging from its hole in the headstock. Maybe try some WD-40 there.
Ash-69
PostPosted: 20:09 - 17 Jan 2013    Post subject: Reply with quote
Hairdryer - Although if your avatar's anything to go by, maybe you haven't one to hand .................
FZ1-S Fazer (licence killer😢) , CRF1000L - Adventure Sport
skylineonfire
PostPosted: 20:10 - 17 Jan 2013    Post subject: Reply with quote
Tried WD40, hairdryer etc.. No luck. It cant be ice at this point. And yes, the right key! Even tried the spare keys. Incredibly frustrating.
Ash-69
PostPosted: 20:11 - 17 Jan 2013    Post subject: Reply with quote
Doh - new boy error, been a long day Embarassed
Hairdryer ...............
Eddie Hitler
PostPosted: 20:12 - 17 Jan 2013    Post subject: Reply with quote
Mr. Green
skylineonfire
What am I missing from this, I dont get it :S
Eddie Hitler
PostPosted: 20:18 - 17 Jan 2013    Post subject: Reply with quote
Just wondering, did you try what I suggested?
Ash-69
PostPosted: 20:20 - 17 Jan 2013    Post subject: Reply with quote
It's the good ol' respond to the wrong poster trick ....
Have you tried a bit of percussive maintenance ie whack it a couple of times with an 'ammer ??
skylineonfire
PostPosted: 20:28 - 17 Jan 2013    Post subject: Reply with quote
Running to the bike shed to try this now, pretty sure I have but I'm going to give it another shot, back in a second
skylineonfire
PostPosted: 20:31 - 17 Jan 2013    Post subject: Reply with quote
No luck. Any more force and the key would snap
Copycat73
PostPosted: 20:34 - 17 Jan 2013    Post subject: Reply with quote
i had a similar problem with mine recently.. would you be able to remove the lock assembly ?
caveat emptor
skylineonfire
PostPosted: 20:37 - 17 Jan 2013    Post subject: Reply with quote
My bike shed is jammed with bikes and no electricity so it's pitch black, and I can't even back the bike out as the steering lock is on. I'll wait for the AA guy to do that if he thinks that's what he wants to do. I wouldn't feel too comfortable doing that myself in the dark with limited tools etc. What helped with yours? What was it in the end?
3illy
PostPosted: 20:40 - 17 Jan 2013    Post subject: Reply with quote
Jizz in the barrel and let your little work men do all the work.
Ash-69
PostPosted: 20:42 - 17 Jan 2013    Post subject: Reply with quote
Mine normally responds to WD40 and gentle pressure against the mechanism whilst lifting the key, does the key turn to any of the positions at all, I can sometimes get the steering lock off but no further without more jiggling and WD40 ...
TheManWithThe...
PostPosted: 20:45 - 17 Jan 2013    Post subject: Reply with quote
What bike is it?
My ER5's lock jammed on the steering lock, so i sprayed a fuck load of WD40 down the barrel and kept pushing the key in and out just to thoroughly coat all the internal parts of the lock, left it for about 15 mins and just repeated until it came off after a little wiggle of the key and handlebars
MBK Nitro 50, Sold. Kawasaki ER-5, Honda ST1100
"Anyone can jump a motorcycle! The trouble begins when you try to land it..."
Copycat73
PostPosted: 20:48 - 17 Jan 2013    Post subject: Reply with quote
it was the lock barrel (seen with the key in)
its made from cast aluminium ,over time it wears that and the tumblers,
so when you put in your key they don`t retract and so stop the lock from turning... i ground them back untill they were flush again & filled the thing full of greese... but getting the thing off was a nightmare like drilling 6 shear bolts off...you can see them 2x 8mm and 4x 3mm Crying or Very sad
https://i867.photobucket.com/albums/ab232/copycat73/24k%20Service%2014th%20jan%202013/Photo1042_zpsf7e254d4.jpg
caveat emptor
skylineonfire
PostPosted: 20:51 - 17 Jan 2013    Post subject: Reply with quote
its a 2012 CBF 125, it wont turn to any of the positions, key goes in fine though. WD40 has done nothing and I used a shit load.
Jim Mc
PostPosted: 20:53 - 17 Jan 2013    Post subject: Reply with quote
What more can the AA guy do realistically if you've tried to free the lock up with oil? Best bet is he trailers the bike to a garage?
skylineonfire
PostPosted: 20:59 - 17 Jan 2013    Post subject: Reply with quote
Not a clue, hoping he has some idea as to what to do.
PostPosted: 21:15 - 17 Jan 2013    Post subject: Reply with quote
I tend to try and force the bars left and right whilst pushing down and right with the key.
kawakid
PostPosted: 21:27 - 17 Jan 2013    Post subject: Reply with quote
I bet its's weather related. I've had the same in cold weather with both the steering lock and then fuel lock.
I've a twin and a 4.
Copycat73
PostPosted: 21:34 - 17 Jan 2013    Post subject: Reply with quote
as maybe.. but cheap materials used in the mechanisms definitely don`t make for a durable lock.
caveat emptor
skylineonfire
PostPosted: 21:51 - 17 Jan 2013    Post subject: Reply with quote
AA guy says it feels like the lock has disintegrated inside, and has arranged collection for tomorrow morning, should be covered under warranty as its only a few months old.
Unfortunately its in my tiny shed surrounded by ice, with a small entry it barely fits through normally, and with the steering lock on. I have literally no idea how on earth we are going to get it out. This is not what I need, especially since I was made redundant yesterday too. Shittiest week so far.
The last post was made 13 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 120.53 Kb
