GS500E Custom fairing, plus Aramids.
Rebelervi
PostPosted: 09:26 - 18 Jan 2013    Post subject: GS500E Custom fairing, plus Aramids. Reply with quote
Hi all.
Purchased a GS500E 94.
The Suzukis maintenance looked to have been slightly neglected, every inner weld joint open to the elements.
Rode okay though... Very Happy
https://i114.photobucket.com/albums/n244/ukcjm/GS500E2.jpg
https://i114.photobucket.com/albums/n244/ukcjm/SuzukiGSXR750K62006standardscreen.jpg
Purchased GSX750 Screen.
https://i114.photobucket.com/albums/n244/ukcjm/bikinifairing.jpg
Bought Raptor fairing, for light unit, and template.
(Petition) https://moonbears.org/
Rebelervi
PostPosted: 09:43 - 18 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/GSSeatForm11.jpg
Used laminated flooring panels, filler and Plasticine to give a base, for Carbon fiber sheet.
https://i114.photobucket.com/albums/n244/ukcjm/DSC04276719x350.jpg
Wanted to keep same rear light holder, although lens would have to go.
https://i114.photobucket.com/albums/n244/ukcjm/seatformcf.jpg
CF layed up with Epoxy, SP106, to create a form/core.
Rebelervi
PostPosted: 09:59 - 18 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/GSSidePanel1.jpg
Side panels- Had to create a form to add shaping. Treated original panels with release wax, around 6 times. Used couple layers of Gelcoat.
https://i114.photobucket.com/albums/n244/ukcjm/GSSidePanel2.jpg
Layed up around three layers of chopped strand matt, polyester resin. Use the 600, as its easy to thin down.
https://i114.photobucket.com/albums/n244/ukcjm/GSSidePanel3.jpg
Left for around a week, and split.
Rebelervi
PostPosted: 10:33 - 18 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/SidePanelFirstcut.jpg
Cut out the start for side vents, keeping the piece removed to use as vent "Floor."
https://i114.photobucket.com/albums/n244/ukcjm/SideVentFistSideVentFloopr.jpg
Attached firmly to bike, yet easy to remove. Reinforcing with ply, and filler. Incidentally, the ink lines on ply are useful as guides, when adding and sanding the filler.
https://i114.photobucket.com/albums/n244/ukcjm/SidePanelSeatForm.jpg
Can use any junk to start filling in gap, polystyrene, carrier bags etc.
Rebelervi
PostPosted: 12:31 - 18 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/BCFSIDE.jpg
Filler creating steep sides, vent floor ready to stick while panel is on bike, so as can position to max effect.
https://i114.photobucket.com/albums/n244/ukcjm/BCFSIDE1.jpg
https://i114.photobucket.com/albums/n244/ukcjm/BCFSIDE2.jpg
Wavy but okay for now.
Rebelervi
PostPosted: 12:43 - 18 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/BCFSIDE3.jpg
Fiberglass,to create a bed, and start to bring forwards, frame protected from resin/filler.
https://i114.photobucket.com/albums/n244/ukcjm/BCFSIDE4.jpg
Removed, trimmed.
https://i114.photobucket.com/albums/n244/ukcjm/BCFSIDE5.jpg
The CF seat panel core is starting to go wafer thin, cheesing, which will help any adding of CF later on.
Ran the line down from tank edge, to Gelcoat on side panel plug, hence hole.
Rebelervi
PostPosted: 12:57 - 18 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/BCFSIDE6.jpg
Work all the lines with , 80 grit abrasive paper, the easy sand filler is very workable with chisels, and alike.
Simply sweeping the filler with abrasive, creates a good finish , and the paint is just extra filler at this point.
https://i114.photobucket.com/albums/n244/ukcjm/BCFSIDE7.jpg
Trimmed bottom line, left rear of panel for now.
The front still needs matching to frame, and forward vent.
Originally, considered laying CF over plug, but it seems beneficial to take a mold.
Tim..
PostPosted: 14:11 - 18 Jan 2013    Post subject: Reply with quote
Good work!
Whats the final goal you're trying to achieve?
www.marshallracing.co.uk
t121anf
PostPosted: 14:13 - 18 Jan 2013    Post subject: Reply with quote
Looks good so far, be nice to see the finished product.
mysterious_rider
PostPosted: 14:55 - 18 Jan 2013    Post subject: Reply with quote
How strange, the gs runs a steel frame so welding a new subframe would have been a piece of piss. Although I wanna see the outcome.
Looks good. Very Happy
KAWASAKIIIII
AL-
PostPosted: 14:59 - 18 Jan 2013    Post subject: Reply with quote
Good work. Looking forward to seeing it finished Thumbs Up
mintex
PostPosted: 21:45 - 18 Jan 2013    Post subject: Reply with quote
Doing well bud, i will watch this one with interest Thumbs Up
Rebelervi
PostPosted: 11:17 - 19 Jan 2013    Post subject: Reply with quote
Hey...Heartfelt thanks one and all.
Your hospitality is greatly appreciated. Sun
Tim...The only goals, or achievements in mind, are to experiment, and hope to encourage others.
https://i114.photobucket.com/albums/n244/ukcjm/cheers-1.gif
https://i114.photobucket.com/albums/n244/ukcjm/Headlight1.jpg
Raptor (?) Aftermarket fairing stripped down - Wanted to keep headlight unit up the right way, but turn the shaping it was held in, upside down. So could use the fairing as a mold.
https://i114.photobucket.com/albums/n244/ukcjm/Headlight2.jpg
Any edges made CF snag, and after working CF into shape, would only be left with a Horse shoe shaped item.
https://i114.photobucket.com/albums/n244/ukcjm/Headlight3.jpg
Adding a divide between lights, might add to character.
Rebelervi
PostPosted: 11:26 - 19 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/Headlight4.jpg
Pulled from the fairing, which I still treated with release wax, despite it being plastic, i needed to turn up other way, on flat laminated board and add a top surface.
https://i114.photobucket.com/albums/n244/ukcjm/Headlight5.jpg
Could know trim to one edge of the light unit.
https://i114.photobucket.com/albums/n244/ukcjm/Headlight6.jpg
Layed up another couple of layers, joined to front curve, which pulls up allowing light unit to be removed.
Rebelervi
PostPosted: 11:41 - 19 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/Headlight7.jpg
With unit held at top, the lower line sat into light unit recess.
https://i114.photobucket.com/albums/n244/ukcjm/Headlight8.jpg
Sourced two Lucas lenses, cut down, and used some Airex core material, to start the central divide.
https://i114.photobucket.com/albums/n244/ukcjm/Headlight9.jpg
Added some "yachting" weave fibreglass, as core,and continued with CF, and all with SP106.
pdg
PostPosted: 11:51 - 19 Jan 2013    Post subject: Reply with quote
This project is quite interesting, looks like you're putting some decent thought into it.
Why strange? What possible reason is there to chop out a perfectly sound portion of the frame when it suits the desired outcome? Some people actually realise that altering the frame in such fashion can affect the legality of the registration.... (Oh, and if welding is so easy why can't you do it with any semblance of quality?)
Rebelervi
PostPosted: 12:09 - 19 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/DSC05632768x576.jpg
Purchased CF braiding.
In addition Kevlar strip and BMW light protector.
https://i114.photobucket.com/albums/n244/ukcjm/PICT4330.jpg
Would need a temporary/prototype fairing, jigged the screens, GSX and Raptor, to sections of plastic.
https://i114.photobucket.com/albums/n244/ukcjm/PICT4336.jpg
Plastic slitted, and junk to fill, ready for glass
Rebelervi
PostPosted: 12:18 - 19 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/PICT4340.jpg
Keys in the plastic made for a sturdy, item. Slits gave plastic reasonable curve.
https://i114.photobucket.com/albums/n244/ukcjm/PICT4379.jpg
The BMW light protector, was heated in oven, at around 110 c for around 2 - 4 minutes, then wrapped around light unit.
Layed up some Gelcoat + glass within the curve,, pulled, and cut from the curved protector an area for two individual protectors to be set into custom faring.
Rebelervi
PostPosted: 12:34 - 19 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/Attahfairing-1.jpg
Used "L" shaped Laminated panels, as mold to fabricate CF and epoxy bracket.
Added castor pins.
https://i114.photobucket.com/albums/n244/ukcjm/Attahfairing1.jpg
Scrap ally plate to join.
https://i114.photobucket.com/albums/n244/ukcjm/Attahfairing2.jpg
Re positioning clip ons, made GS go from Transport, to a Machine.
Temporary fixings sought, ready for all to be fitted.
Rebelervi
PostPosted: 08:48 - 20 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/ProtofitFairing.jpg
Fortunately I had a seat plug, from a previous project (Bucket seat) layed up a seat panel to duplicate.
Layed some CF against the frame, treated with wax, leaving epoxy untill tacky, before applying CF.
https://i114.photobucket.com/albums/n244/ukcjm/ProtofitFairing1.jpg
The impression taken from a headlight protector (Similar/ same as BMW K1200S 2005-2010 ) attached to larger assembly, bolted using the original headlight brackets, and gauge panel.
Cut two individual protector covers, applied resin to set into panel and removed.
Took impression of GSX screen, fitted, fillered.
https://i114.photobucket.com/albums/n244/ukcjm/ProtofitFairing2.jpg
A section of laminate had stuck, happens rarely, but does remind to use wax sufficiently even on " Non stick" surfaces.
Ran bike for awhile, was able to adjust "on" pivot/ castor pins.
Rebelervi
PostPosted: 09:24 - 20 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug.jpg
Had to fix the sections to bike & cut/fit some ply cross sections.
The forks were treated with one coat of release wax before using cellophane.
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug1.jpg
After an eternity of measuring, the lower panel was bracketed under neath, the ply set squarely, could then manipulate edges.
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug2.jpg
No plans. No strategy. No drawings. No restrictions.
The Grinder is always close.
Rebelervi
PostPosted: 09:32 - 20 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug3.jpg
The ply is the same as drawing a line, the filler suitable workable, not to disturb the guide it represents.
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug4.jpg
Picked line on clip on.
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug5.jpg
Added lower section.
Rebelervi
PostPosted: 09:40 - 20 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug6.jpg
Wanted central lines to reach down.
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug7.jpg
The two indicator surfaces, were fillered using templates, keeping curve regular.
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug8.jpg
Key areas all measure up, black invaluable to gauge surface.
Screen edges removed, allowed for small amount of adjustment.
Rebelervi
PostPosted: 09:57 - 20 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug10.jpg
Rear ply was stuck to top of forks, measuring aided by "n" template.
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug11.jpg
Edges just an extension to lines already set.
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug12.jpg
End of plug in sight.
Rebelervi
PostPosted: 10:25 - 20 Jan 2013    Post subject: Reply with quote
https://i114.photobucket.com/albums/n244/ukcjm/FairingPlug13.jpg
Finishing edges and decided line around clip on.
Possibility of using multi colors, in final article, found:
https://www.ecfibreglasssupplies.co.uk/c-928-decorative-cloths.aspx
The last post was made 13 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 140.4 Kb
