Replacing leaking lead 'T' water pipe with copper
PostPosted: 15:11 - 18 Jan 2013    Post subject: Replacing leaking lead 'T' water pipe with copper Reply with quote
Got a leaking hot water pipe - the leak is coming from a 't junction' area.
I believe the pipe is lead.
Haven't measured, but think it's around 1" lead, which at the moment is then soldered on to a 22mm copper which goes in to the top of the hot water tank.
Anything special to look out for if I'm to replace it with copper (or plastic, etc) - you can get special adaptors, so presuming they are the right size, thinking it should be fairly easy?
Al
PostPosted: 16:07 - 18 Jan 2013    Post subject: Reply with quote
You can get compression type adaptors called 'leadlocks'
Lead pipe is normally measured in weight ie 7lb, 9lbs ect but I'm not sure what that equates to in size.
Just cut the pipe nice and straight with a hacksaw and file the edges smooth, don't over tighten the fitting as it can crush the lead and cause it to leak you just want it to bite in, maybe use some ptfe tape on the joint to help it seal.
Yamaha FZR400RR 3tj
My Instagram Thingy
Ariel Badger
PostPosted: 18:07 - 18 Jan 2013    Post subject: Reply with quote
Cut lead pipe square. Bell it out with a turnpin or home made conical 'thing' to take copper pipe. Clean up the cut end and inside pipe with shave hook/wire wool etc.
Apply light coating of flux to inside of lead. 'Tin' copper pipe before inserting into lead by applying flux and solder to end of pipe beyond insertion depth.
Flux copper lightly again and insert copper pipe into lead.Heat copper with blowtorch and using bar of Grade D solder (in same manner as normal solder) caress the side of the copper with it and watch it fill the cavity. Using wiping cloth (moleskin soaked in tallow ) shape the lead into something resembling a wiped joint that the old boys were so proud of.
Raffles
PostPosted: 22:23 - 18 Jan 2013    Post subject: Reply with quote
Do you have access to the whole length of lead piping? If so then it would probably be easier to simply replace the entire section with copper pipe and suitable fittings.
PostPosted: 23:42 - 18 Jan 2013    Post subject: Reply with quote
Cheers, had found the 'leadlocks' and decided that was probably the easiest way.
I had misplaced my blow torch, but we now have one (to be fair, mine is likely somewhere obvious if I look.)
Never soldered pipework before, so wasn't sure I wanted to start on this.
I don't have access to all the copper piping - both bits after the 'T' disappear in to the walls after a bit unfortunately.
Raffles
PostPosted: 00:13 - 19 Jan 2013    Post subject: Reply with quote
Soldering copper pipework is one of the easiest (and yet most feared) DIY tasks. It is especially easy if ''Yorkshire'' fittings are used.
If you are a soldering virgin, you should not attempt to pop your cherry with a lead joint, as it will all end horribly.
mentalboy
PostPosted: 18:12 - 19 Jan 2013    Post subject: Reply with quote
And try not to breathe in fumes Exclamation
Make mine a Corona.
smegballs
PostPosted: 18:19 - 19 Jan 2013    Post subject: Reply with quote
Engineering Boner Status:
[✓] Boner
[_] No boner
Embarassed
PostPosted: 22:12 - 19 Jan 2013    Post subject: Reply with quote
All sorted now, ta.
Used a leadlock and leadline as the shop only had one of each.
The last post was made 13 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 61.05 Kb
