Bent front brake lever
beefcake
PostPosted: 16:43 - 11 Nov 2004    Post subject: Bent front brake lever Reply with quote
How easy is it to bend one of these back in shape? Its not a huge 90 degrees or anything like that, more like 30 degrees (away from the grip).
Many thanks
Deano
Gotta get my knee down...
Rob W
PostPosted: 16:58 - 11 Nov 2004    Post subject: Reply with quote
I would of thought personally it would break, due to the fact that as it's already bent it would have been stressed and therefore weakened. If you can, just try and use it anyway, or buy another cant be that expensive
mchaggis
PostPosted: 17:06 - 11 Nov 2004    Post subject: Reply with quote
I'm not sure if I'd really want to do this with a brake lever, but I dropped my bike, bending the clutch lever into a banana shape. It turns out though that it makes no difference at all when I'm riding.
I'd ride with it and see what it's like. Having said that, I'd assume that you already have and have found out that it's just too dangerous.
I must not be a troll...
Mmmm, Guinness
beefcake
PostPosted: 17:07 - 11 Nov 2004    Post subject: Reply with quote
Just tried ringing honda for the price of a new one, but they are shut today. I can still reach it, but it niggles me to know its not as it should be.
mr jamez
PostPosted: 17:18 - 11 Nov 2004    Post subject: Reply with quote
What bike is it?
www.davidsilverspares.co.uk will be open, ring them up.
jay12329
Dr. Evil
PostPosted: 22:18 - 11 Nov 2004    Post subject: Reply with quote
One for my hornet cost <£8 from hein gerrike. Was labled as a "Honda" lever
J
alains
PostPosted: 22:25 - 11 Nov 2004    Post subject: Reply with quote
what you can try is this : pick a bit of candel , warm your pedal with a torch (out of the bike) melt a bit of candel on the alu , keep going to warm until the melt is black (stearine comes black just before alu melting) then put into a baquet of water to get it cold quickly . now you've got 1 to 3 mn to de-bend it (not like a brutal) . no hammerring !!!
beefcake
PostPosted: 11:21 - 16 Nov 2004    Post subject: Reply with quote
Cheers for all your advice peeps. I had a better look at the lever once I got home. The bend was near the end of the lever. I put a soft bit of wood between the handle and the lever, and used a hollow iron bar to gently ease the lever back into shape. No stress marks on the lever whatsoever, so I've been quite lucky! Thx again!
Bendy
Mrs Sensible
PostPosted: 12:38 - 16 Nov 2004    Post subject: Reply with quote
Levers are cheap and should be in your spares box. They're consumables as far as I'm concerned. Thumbs Up
The last post was made 21 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 59.44 Kb
