Dry clutch vs wet clutch?
Kradmelder
PostPosted: 11:07 - 21 Jan 2013    Post subject: Dry clutch vs wet clutch? Reply with quote
Which do you have and which do you prefer?
I have one bike wet and one dry. I find the dry clutch doesnt like being slipped so much and you must rather use throttle, hence dry clutch doesnt work so well in sand, with the risk of burning the clutch. It also tends to 'jolt into gear if you let the clutch out a bit too quick, which means you can easily take a fall in sand or mud. The friction zone is much less.
I can see the advantage of a dry grabby clutch for track, and for prolonging oil life, but im prefer the smoothness of a wet clutch.
2011 KTM 990 Dakar
2009 BMW 1200 GS
Wave2k
G's Stalker
PostPosted: 12:18 - 21 Jan 2013    Post subject: Reply with quote
advantage of dry is weight and the fact it doesnt lose as much power from crank to wheel spinning in oil i believe.
Problem is they wear out quick and overheat and get snatchy in traffic.
Still id have a dry clutch every time, cant be the ring a ding ding of an open clutch cover Very Happy
I miss my Ducati Sad
Ducati 1299 Panigale
2009 Corvette C6 z51
Walloper
PostPosted: 15:23 - 21 Jan 2013    Post subject: Reply with quote
Never noticed any difference, advantage or disadvantage and I've had both. Confused
Probably a designer's whim/quim.
Kradmelder
PostPosted: 16:33 - 21 Jan 2013    Post subject: Reply with quote
I think the advantage of the wet clutch is poor traction terrain so you can slip the clucth more and let it engage with a minimum of wheel spin.
But generally it means more oil changes and running higher synthetic oil grades.
I see BMW has gone over to a wet clutch on their new GS....hmmm. I wonder why.
2011 KTM 990 Dakar
2009 BMW 1200 GS
PostPosted: 16:49 - 21 Jan 2013    Post subject: Reply with quote
With the fairings off I can change my clutch plates in 15mins. Easier to do than brake pads. Not experienced any snatching/grabbing and I keep the clutch rattle to a minimum by adding an extra friction plate at the back of the basket. It's a mod that works well on my Ducati 944 ST2. As is removing 2 of the 6 clutch springs. I now have a much lighter clutch lever and also no issues from doing so. Toured 2 up with camping gear and it never slips.
I periodically whip the cover off and blast the dust out.
Suspect the speed of changing a clutch in the pits was another reason why the dry clutch was invented.
I prefer the quiet sound of a wet clutch tho.
PostPosted: 20:05 - 21 Jan 2013    Post subject: Reply with quote
Krad, suspect that having a large single plate clutch rather than a multiple plate clutch possibly has more effect than whether it is a wet or dry clutch.
Kradmelder
PostPosted: 20:17 - 21 Jan 2013    Post subject: Reply with quote
Ja probably but I think the reason for single plate is to utilise the weight benefit of a dry clutch and due to space layout of the engine configuration. Ducati as the best known dry clutch, not known what they do, but apparently it is also grabby. Bmw as the other well known dry clutch system, goes for a clunky system but no grabby. You need this on a torquey engine. But I think they will never match the smoothness that a wet clutch brings to a torquey set up.
2011 KTM 990 Dakar
2009 BMW 1200 GS
PostPosted: 20:20 - 21 Jan 2013    Post subject: Reply with quote
Suspect the large flywheel / clutch is there to smooth out the engine with the large low revving pistons .
TheBikerStig
PostPosted: 20:26 - 21 Jan 2013    Post subject: Reply with quote
Wet clutches will rust quicker. Try to keep it dry which isnt easy in this country.
I am usually naked when posting to this forum.
PostPosted: 21:54 - 21 Jan 2013    Post subject: Reply with quote
Aye?
Kradmelder
PostPosted: 22:50 - 21 Jan 2013    Post subject: Reply with quote
Wtf? At least put a lol after your jokes.
2011 KTM 990 Dakar
2009 BMW 1200 GS
Valentino Mossy
PostPosted: 23:51 - 21 Jan 2013    Post subject: Reply with quote
Other bikers hate my rattle..... hence why i love it. Thumbs Up Wink Open dry clutch ftw.
Ariel Badger
PostPosted: 00:46 - 22 Jan 2013    Post subject: Reply with quote
I want rapid power to the rear wheel. dry clutch gives me that.
DottyDuck
PostPosted: 06:06 - 22 Jan 2013    Post subject: Reply with quote
... I'm just going to nod and agree! I wish my knowledge on bikes was much better than what it is. boo-hiss.
Alpha-9
PostPosted: 10:55 - 22 Jan 2013    Post subject: Reply with quote
I'm guessing wet is always on small newbie bikes as they'd rape their clutch with inexperience else
Fzr-600 1999
Kradmelder
PostPosted: 11:18 - 22 Jan 2013    Post subject: Reply with quote
doubt manufactures care. I think wet is cheaper. And space and weightr are less of an issue on small motors.
Single plate dry probably takes the least space so they do that when the engine configuration is constricting.
2011 KTM 990 Dakar
2009 BMW 1200 GS
Alpha-9
PostPosted: 11:28 - 22 Jan 2013    Post subject: Reply with quote
Weight is an issue on small bikes moreso than big ones surely?
I imagine they do care as its creates a reputation for the bike, if they brought out a newbie bike where the clutch was jolty and unsmooth then it wouldn't sell as well as newbies wouldn't get on with it very well, hence why the YBR is a strong seller, it's renowned for being easy to ride
Fzr-600 1999
Walloper
PostPosted: 14:00 - 22 Jan 2013    Post subject: Reply with quote
A wet clutch should 'theoretically' last longer than a dry clutch as the shearing forces on the oil transmit drive from drive plate to driven plate when the drive is 'taken-up'. Oil is changed much easier than clutch linings.
This is why a wet clutch is used.
But.... Any clutch is designed to last the 'life-time' of the vehicle.
The fact that they are 'the fcuk abused out of' means they don't last very long in some hands/feet.
PostPosted: 14:01 - 22 Jan 2013    Post subject: Reply with quote
Never had or ridden a bike with a dry clutch.
Even when I used a Ducati, it was a wet clutch Laughing
The last post was made 13 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 3.62 - MySQL Queries: 13 - Page Size: 107.29 Kb
