Rattling clutch
Flip
PostPosted: 22:41 - 11 Nov 2004    Post subject: Rattling clutch Reply with quote
My bike makes an awful chattering / rattling sound until I pull the clutch lever in Confused Is this the clutch plates or what? Happens 99% of the time and f*cking annoys me and can't be doing the bike much good either.
Any ideas?
Please help. Sad
Guest
PostPosted: 22:58 - 11 Nov 2004    Post subject: Reply with quote
If this is your Suzuki then it doesn't surprise me, 'they all do that sir' Wink
If it's as bad as you say though, whip the clutch cover off, remove the springs and pressure plate and check the tightness of the centre nut - see if you can pull the inner clutch drum along the shaft.
If that's ok see if the outer drum can be waggled about, maybe the roller bearing it sits on is kaputnik.
Flip
PostPosted: 21:33 - 13 Nov 2004    Post subject: Reply with quote
It was suggested that it could be basket wear. The fella said it would cost more to fix it than the bike is worth! Shocked He said, all old kwaks suffer from it. Rolling Eyes
tatters
Exxon Valdez
PostPosted: 21:40 - 13 Nov 2004    Post subject: Reply with quote
complety normal on old kawaskai,s when there cold mainly, l,m told my ZZR600 does when pulling off in 1st gear and at low revs in neutral
The last post was made 21 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 38.79 Kb
