Honda NS125 RK problem
aviator543
PostPosted: 11:07 - 24 Jan 2013    Post subject: Honda NS125 RK problem Reply with quote
I have just bought a 1989 NS125 RK and since I bought it it keeps wanting to stall at low revs, hot or cold but wouldn't if I kept the revs up. This morning it stalled 5 times, a few at low revs and a few at high revs. Each time I had to wait a few minz before it would run again and each time it would die 5 minz down the road. Does anyone know what the problem could be? I'd be greatful for any help
nightshaddow
PostPosted: 13:30 - 24 Jan 2013    Post subject: Reply with quote
could be anyone of a few problems
most likely the idle is too low, turn the idle up with the screw to left side of the carb
does the bike run well while riding under load ie accelerating riding at a steady pace
aviator543
PostPosted: 13:56 - 24 Jan 2013    Post subject: Reply with quote
It depends on the throttle position. At quarter throttle it's kinda jolty, half runs fine and three quarters it doesn't seem to accelerate at all. I thought idle speed but it cut out wilst I was going 30 at 5k revs. The revs started to drop quite fast then the engine died. Trying to accelerate didn't help at all
nightshaddow
PostPosted: 23:27 - 24 Jan 2013    Post subject: Reply with quote
sounds like you could have a general fuel flow problem then as it is cheap and easy to do give the poor thing a service,
change the coolant
change the spark plug
change the fuel lines and filter (or fit inline if one not already there)
clean the carb
change the engine oil
if you do it yourself it should cost you less than £20
Aff
PostPosted: 10:31 - 25 Jan 2013    Post subject: Reply with quote
Up to 1/4 throttle is controlled by the pilot jet.
Take the carb apart and give all the jets a good clean.
If your still having issues, check all carb rubbers for splits/cracks.
If that's fine someone may have changed your jets, if you have a pilot jet that's too large, your bike could be running rich on the pilot and that will make it feel sluggish and bog under 1/4 throttle.
Electric Bike Project
aviator543
PostPosted: 11:03 - 25 Jan 2013    Post subject: Reply with quote
The idle screw was about 6 turns out so that's why it was stalling all the time, that's fixed now. Thanx for that info nightshadow and I'll service it at weekend. Aff I'll strip the carb when I'm servicing her and keep you informed. I came to the bike this morning and noticed the petrol tank was empty but I gave her 2 gallon 60 miles ago, the bike should do at least double that on 2 gallons. Is this a simptom or does my bike just drink way too much?
skatefreak
PostPosted: 18:10 - 25 Jan 2013    Post subject: Reply with quote
The NSR will get 50MPG if you are hammering it, around 75mpg if you behave so it sounds like something's not right there...
-Jvr
Aff
PostPosted: 19:01 - 25 Jan 2013    Post subject: Reply with quote
If its running rich it wont be doing any good to your fuel economy.
nightshaddow
PostPosted: 22:08 - 25 Jan 2013    Post subject: Reply with quote
-Jvr
this is the ns 125 r not the nsr
the tc o1 and the jc 20/jc22 are totaly different animals
the tc01 the same as mine and the ops are "reported" to do 80 mpg stock (restricted) a tad over 65 unrestricted
aviator543
PostPosted: 19:37 - 26 Jan 2013    Post subject: Reply with quote
Bit of an up date... I changed the 2 stroke/trans oil, the coolant and cleaned the air filter before the weather hit me today. Looked at the old spark plug and it looks like it has carbon fouling so I think it is running rich like Aff said. Couldnt get hold of a carb rebuild kit in time so can't do anything to fix it yet. I may ajust the pilot screw to see if that helps at all
The last post was made 13 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 67.44 Kb
