| BillyJ |
 BillyJ Nearly there...
 Posted: 20:37 - 24 Jan 2013 Post subject: CBR 125 Front brake problems |
So my CBR was fine before winter,
it's now been sitting in my garden for about a week and i found out today that the front bake is showing very odd behavior...
when the handle bars are center or full lock left, the brake behaves as you would expect... not braking till you pull the lever... but when you turn the handlebars to full lock right, the front wheel for some reason locks up as if the lever was being pressed??
I've had a look at the line and it doesn't seem to be pinched anywhere..
WHY  |
| Robby |
 Robby Dirty Old Man
| BillyJ |
| BillyJ |
| Robby |
 Robby Dirty Old Man
| krarkol |
 krarkol World Chat Champion
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 10:02 - 28 Jan 2013 Post subject: |
robby seems to know what he is doing but the obvious things to check are kinked/squashed brake lines
if it was me i would strip and rebuild the whole braking system and rebuild it replacing anything that looked suspisious ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| BillyJ |
| Robby |
 Robby Dirty Old Man
 Posted: 09:07 - 29 Jan 2013 Post subject: |
I'm going to be busy on either saturday or sunday, probably sunday, will try to find out today.
For brake fluid you want either DOT4 or DOT5.1, NOT DOT5. Get whatever is cheapest from your local garage, it all does the same thing.
Try to get some new copper washers too. A bike shop will well them, I only need 4 but try to get 10, always worth having spares on the shelf. They're a standard size, just ask for copper washers for brake lines.
Try to get some latex or nitrile gloves too. Brake fluid is nasty stuff.
To answer some of the questions from other people in the thread:
1. The brake lever isn't touching on anything, and the line isn't being squeezed anywhere.
2. The bike has been down the road at some point, there's a little scuffing on the master cylinder lid.
3. There is no suggestion of a prior brake fluid change, and the bike is a 2007 model.
I'm clutching at straws somewhat, but some remote possibilities are:
1. General crap in the fluid is blocking the master cylinder fluid return hole when the bars are moved around to the right.
2. An air bubble is exerting a tiny amount of pressure somewhere.
3. The old fluid has absorbed enough water to have too much fluid in the system, exerting pressure at odd times.
My plan is to drain down the system, clean the caliper and master cylinder fully, give it all a proper visual inspection, and reassemble. I'll have a look at the ignition switch while I have it all apart - its wiring appears to have been routed incorrectly. |
| BillyJ |
| Robby |
 Robby Dirty Old Man
| BillyJ |
The last post was made 13 years, 17 days ago. Instead of replying here, would creating a new thread be more useful? |
