Tip on cleaning bike - found someone!
j.silvs
PostPosted: 22:36 - 24 Jan 2013    Post subject: Tip on cleaning bike - found someone! Reply with quote
As I have been riding it, I don't want the salt from roads being on it.
Could I just clean the plastics with a flash wipe?
Any advice appreciated
Benno
PostPosted: 22:38 - 24 Jan 2013    Post subject: Reply with quote
Hosepipe is probably best, and if you want it looking nice buy some bike cleaner, cheap at halfords Wink
Use a sponge and hot water to remove the more stubborn bits.
This is what I do at least.
stuartt
PostPosted: 22:42 - 24 Jan 2013    Post subject: Reply with quote
hose pipe & cold water till the bike looks clean then bucket & sponge hosing as you go .
if you use wipe you'll scratch it if its dirty .
j.silvs
PostPosted: 22:50 - 24 Jan 2013    Post subject: Reply with quote
Ok thanks, and if I don't have a hosepipe lol?
Hevra
PostPosted: 23:03 - 24 Jan 2013    Post subject: Reply with quote
A few buckets of cold water... I don't have a hosepipe either, have to cart buckets up and down the stairs (kitchen & bathroom are on first floor). Sucks, but better than corroded bike.
Going to get the bike sprayed by the allyearbiker chap in Worcester on Saturday, hopefully that helps keep the crap on the roads from eating my bike.
_MJS_ : TLDR; MTFU, RTFM, DIY, tits and Gary. It's the only way you'll learn
CBF125 > XJ600S > V-Strom 650
Benno
PostPosted: 23:24 - 24 Jan 2013    Post subject: Reply with quote
https://ecx.images-amazon.com/images/I/41R4Z5K7GVL._SL500_AA300_.jpg
Seriously Neutral
Clutchy
PostPosted: 23:27 - 24 Jan 2013    Post subject: Reply with quote
Bit of gizer (diluted) and then use the steam cleaner/ hot pressure washer, does a brilliant job.
magpiemale
PostPosted: 23:34 - 24 Jan 2013    Post subject: Reply with quote
If you do not have a hose pipe get a spray from argos or B AND Q from qualcast 5 ltr hose sprayer with lance fill pump n go £17.I used this before I added a tap outside cold water safe with salt warm water with road salt and watch your bike melt lol as warm water speeds up corrosion.
As for cleaning the bike I clean my bike once a week or 3 and use acf50 or scotoiler corrosion spray inbetween washes.My bike cleaner is hein gericke 5 ltr gel works like a good-un.
NSR125 1992 (sold) kawasaki Z750S,fazer FZ1 07 now gone present bike 2012 fz1s Fazer,beowulf rad protector,heated grips,sw motech gps holder,power socket.
Benno
PostPosted: 23:50 - 24 Jan 2013    Post subject: Reply with quote
Oh actually, you can often find water sprays at petrol stations, you could use one of those. Thumbs Up
Slacker24seve...
PostPosted: 23:52 - 24 Jan 2013    Post subject: Reply with quote
Allyearbiker?
Banger rallies are ace
magpiemale
PostPosted: 00:03 - 25 Jan 2013    Post subject: Reply with quote
Are'nt those car wash lances benno lol
The water sprayer I used are the ones used for weed killling you get em up to 7ltr's with a lance pressurise then spray,some bikes are more prone to corrosion than others I have had 2 fz1's and they wash up well my chopped in 5 year old bike looked like a 2 year old bike it was tidy.
PostPosted: 00:07 - 25 Jan 2013    Post subject: Reply with quote
To be used with caution.
Most motorcycles don't like high pressure water sprayed at the wrong angle. I'd keep it about 2ft away and spray from the front of the bike to the rear. If possible I'd leave the engine running as it may give a splutter to indicate water getting to the electrics.
No way of fitting an outside tap at mine so I use this.https://www.savewatersavemoney.co.uk/shop/images/products/244/main.jpg
They do a bigger version but it's silly money.
magpiemale
PostPosted: 00:11 - 25 Jan 2013    Post subject: Reply with quote
Same wavelength HT Wink
Clutchy
PostPosted: 00:31 - 25 Jan 2013    Post subject: Reply with quote
spray some wd-40 on the electrics at the end? We have so much at work and I've never had a problem. Cool
Paulington
PostPosted: 00:58 - 25 Jan 2013    Post subject: Reply with quote
Ooh, I am good with this! Laughing. I am a bit anal when it comes to this stuff and what I do is likely way too much for the average person, but I like to keep my bikes/cars sparkling. Thumbs Up.
On the GSX-R, this gets done at least weekly. I do it in order too.
1) Park it up and use the "jet" function on our hosepipe to wash it off. Once that's done I get our jet washer and use it on the LOWEST power/pressure, firstly to get off the stuff the normal hosepipe didn't get off and then I put soap designed for the jet washer in the jet washer's in-built soap bottle and connect it to the jet washer's brush connection, that way I can brush it, put the soap on it and it gets washed off at the same time with the pressure washer. Basically the soap in the in-built soap bottle gets mixed in with the water before it comes out of the pressure washer so it gets put on with the water, it's absolutely amazing for this. Thumbs Up.
2) Rinse all that off with the "rain" function on the hosepipe and dry it with microfibre towels then the chamois leather.
3) Wax it, I have blue, white and black wax for the different parts of the bike. First I use a slightly more abrasive wax compound all over the bike, put on and taken off with microfibre wax towels, then once that's done I use the different coloured less-abrasive Turtle-Wax compounds on the bike, put that on and leave for 20-30 minutes and then take it off with the microfibre wax cloths again.
The small parts like the brake calipers, brake discs, rear shock and various other small bits get cleaned with toothbrushes, I buy a pack of ten for £1 at the local pound shop for each clean as they usually break. Laughing!
Anyway, this is really over the top for most people but the whole rinse --> wash over with cold water and cloth/sponge --> wash over with hot soapy water with a cloth/sponge --> rinse off with the hosepipe and cold water will do for most people, if you want to wax it, you can do that too. Thumbs Up.
All year bikers, make sure to wash the salt and crud off and, if you ARE using a pressure washer make sure you have it on an uber-low setting as bikes aren't protected in the way that cars are from high pressure water so it could lead to damage, so be careful! Mr. Green.
Cheers! Thumbs Up.
PostPosted: 09:09 - 25 Jan 2013    Post subject: Reply with quote
Cleaning the bike is done in 2 easy steps:
Step 1. Look at the bike and assess what needs cleaned.
Step 2. Go make a coffee and forget about it.
Repeat after each ride.
j.silvs
PostPosted: 21:59 - 26 Jan 2013    Post subject: Reply with quote
Found a place in canary wharf. Costed £20 and came out really nice!! Other places were £30
Service came with:
Prewash
Hand Degrease, Wash foam bath
Rinse and dried
AutoGlym Radiant Wax
Hand polished paintwork, trim and chrome
leather cleaned and care applied
Took them an hour in total. Really nice guys!!
Defo recommend them - https://www.carwashers.co.uk/public/index.php?p=motorbikes%20and%20bicycles%20-%20canary%20wharf%20london
c_dug
PostPosted: 13:10 - 27 Jan 2013    Post subject: Reply with quote
Pfft, pansies, mines not dirty its just used. Laughing
Probably clean my bikes once every six months on average.
pepperami
PostPosted: 13:37 - 27 Jan 2013    Post subject: Reply with quote
Most motorcycles don't like high pressure water sprayed at the wrong angle. .
I know this Sad , I took the paint off a bike that was only three months old and had done less than 4000 miles Sad
iooi
PostPosted: 13:49 - 27 Jan 2013    Post subject: Reply with quote
Slacker24seven wrote:
Allyearbiker?
A company that charges a fortune to coat your bike in ACF 50 Laughing
Walloper
PostPosted: 17:55 - 27 Jan 2013    Post subject: Reply with quote
pepperami wrote:
[I know this Sad , I took the paint off a bike that was only three months old and had done less than 4000 miles Sad
I've used the garage jet wash on my bikes hundreds of times and have never ever harmed any part of the bike.
The idea is to stand back from the part you are washing and not let the high pressure 'jet' blast onto bodywork.
If you let it spray from about 18" you will not do any damage and still shift all the shite.
It costs about £3 for soapy-brush and rinse. 5 mins, once a week is not a chore. Rolling Eyes
pepperami
PostPosted: 18:24 - 27 Jan 2013    Post subject: Reply with quote
Yes I know that now Crying or Very sad I put the lance to close to the paintwork and stripped a nice line out of the paint on the mudguard Embarassed
recman
PostPosted: 21:04 - 27 Jan 2013    Post subject: Reply with quote
Am I alone in using a garden leaf blower to dry the bike before whacking on the ACF 50? Embarassed
pepperami
PostPosted: 21:10 - 27 Jan 2013    Post subject: Reply with quote
Embarassed Embarassed My missus told me off once because I was using an extension lead and HER hair-dryer to dry out all the nooks and crannies after washing one of my bikes Laughing .
Walloper
PostPosted: 04:21 - 28 Jan 2013    Post subject: Reply with quote
Yes. It appears you are. Razz
The last post was made 13 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 133.61 Kb
