| yaigi |
 yaigi World Chat Champion
 Posted: 22:55 - 24 Jan 2013 Post subject: What could this be? |
A few weeks ago I came to leave the house in the morning, the bike had been sat for 3 days. Put then choke on, turned the key in the ignition, then pressed the ignition button and there wasn't a sound.
Odd, I thought, so I pressed it again. Nothing. Not a peep. Checked it was in neutral, checked the killswitch wasn't on, tried again, nothing. So then I pressed it in quick succession a few more times (I'm not quite sure what I was trying to achieve here but I was annoyed) and on the very last press there was a tiny sound, so I pressed it again and the bike came to life, as it usually would.
I rode to work that day, when leaving work is started fine first time. Next day, fine. Then a couple of weeks later one morning (after it had only been sat overnight), it did it again. So I pressed it a few times, not a sound each time, until finally it started again.
It had been fine since so I hadn't worried about it too much, and to be honest, whilst it's still (eventually) starting, I'm still not massively bothered about it, but I went to start it up tonight (just cos I miss it after not being able to ride due to ice) and it did it again, and I'm just curious, what could it be? What things should I begin checking (and how cos I have never done anything to a bike!) before it gets to a point where it doesn't start at all?
Bike is a V reg Fazer 600.
TL;DR - bike not making a sound when I press the ignition, not a sign of life, but after a few presses, it works fine. Problem is sporadic, doesn't happen every time. ____________________ What would you do in life, if you knew you could not fail?
Currently own - Fazer 600, 2000, Red. (But no riding as baby on board atm) |
| Islander |
 Islander World Chat Champion
| nightshaddow |
 nightshaddow Nearly there...
| yaigi |
 Posted: 23:36 - 24 Jan 2013 Post subject: |
Thought it could be something simple, hoping it is, will give that a try. The starter button doesn't feel iffy in any way though  ____________________ What would you do in life, if you knew you could not fail?
| i.p.phrealy |
 i.p.phrealy World Chat Champion
| Islander |
| yaigi |
| J.M. |
 J.M. World Chat Champion
 Posted: 23:58 - 24 Jan 2013 Post subject: |
I had a very similar problem when my battery wasn't charging properly and the voltage was fairly low. It would take a few presses of the button before it would do anything, but once something happened the bike would fire back up. Once the charging problem was sorted out the problem went away.
There's no harm in stripping and cleaning the button even if that's not it; it'll be preventative maintenance at the very least. Just another thing to bear in mind.  ____________________ 2004 R1 & 2018 XSR900 |
| yaigi |
| Raffles |
 Raffles World Chat Champion
| nightshaddow |
 Posted: 09:43 - 25 Jan 2013 Post subject: |
this is why i like kick starts lol ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| P.addy |
 P.addy Red Rocket
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 10:18 - 25 Jan 2013 Post subject: |
Strip the switchgear. If that doesn't fix it, then you're going to have so much fun chasing earth problems down the loom.
Get hold of a multimeter; they're not expensive, and they're utterly priceless in situations like this - assuming the switchgear's not at fault, it'll help you determine where there is a continuity failure to earth much more quickly than by eyeballing it. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| YBR Ric |
 YBR Ric Spanner Monkey
| yaigi |
| nowhere.elysium |
 Posted: 10:44 - 25 Jan 2013 Post subject: |
| yaigi |
| nowhere.elysium |
| yaigi |
The last post was made 13 years, 280 days ago. Instead of replying here, would creating a new thread be more useful? |
