MOT Fail - Alpha's Yibber
Alpha-9
PostPosted: 14:19 - 26 Jan 2013    Post subject: MOT Fail - Alpha's Yibber Reply with quote
lol big shock there
Failed because:
Frotn headlamp at least one does not illuminate on dipped beam (lol wut, only one bulb comes on by default and the other is highbeam, thats how dull it is by default it works fine!)
Headlamp aim too high and too far too the left - Yeah okay, but I can literally push it down with my hand, it is fucked up and bent though
Here's the best one...
Front wheel out of line with rear wheel. Motorcycle structure excessively distorted.
Poop! It rides fine though, doesnt pull to either side or feel 'odd' but does look on the piss somewhat I think..it's an optical illusion!
The guy said he couldn't get my key out the ignition either... Rolling Eyes Just fucking pull harder nonce!
Fzr-600 1999
Fisty
PostPosted: 14:23 - 26 Jan 2013    Post subject: Reply with quote
So you can't ride it at the moment.
Fix it.
Fatter and faster than Fret
Alpha-9
PostPosted: 14:26 - 26 Jan 2013    Post subject: Reply with quote
Fix it.
How do I fix structural distortion? It doesn't coast left or right when I take my hands off and the thing with the headlight makes me wonder about this garage Laughing
New headlight is like £50, can do that, the bracket is bent but I could maybe bend it back else that's another fiddy, it was pissing me off anyway right cunt to put back together every time I have to fiddle with electrics
Least I know what needs sorting... dunno if the front wheel alignment is because of the new forks or wut Thinking
The CG may just make a comeback Laughing
Crying or Very sad
Fzr-600 1999
neil.
PostPosted: 14:28 - 26 Jan 2013    Post subject: Reply with quote
Bent frame by the sounds of it, a write off. Can get them straightened but need to strip everything off it first. Not sure if it's worth it.
Fisty
PostPosted: 14:29 - 26 Jan 2013    Post subject: Reply with quote
Scrap it then.
scream aim fire
PostPosted: 14:49 - 26 Jan 2013    Post subject: Reply with quote
book another MOT and on your way there have some car pull out on you and knock you off, claim on his insurance and jobs a good'n! Laughing
disclaimer: May not work Confused Laughing
CBT PASSED 18/01/09 THEORY PASSED 14/04/09 DAS PASSED 17/04/09 3 minors wet test.
Bikes: 2009 Aprilia RS125 (PX'D) - A1P ZX6R - Stolen -Triumph Daytona 600 -wrote off via BMW
Current bike: P7F ZX6R
DMCpro
PostPosted: 14:52 - 26 Jan 2013    Post subject: Reply with quote
So you got a new pair of forks? Or managed to make the ones I gave you fit? Why not ride cg? Honda>Yamaha
Honda CB-1, TS125X
VW Golf Estate
keggyhander
PostPosted: 15:12 - 26 Jan 2013    Post subject: Reply with quote
Chances are the bottom yoke is bent.
Take the wheel out and check fork alignment with two straight-edges.
Then get plank of wood and twist between forks until the straight edges line up. I did this to my dad's Virago when he dropped it.
You see, when you drop a bike, the steering stops suffer a large impact and this usually deflects the bottom yoke. Most people think their forks are bent, when it's sometimes the yoke instead. This then causes the front wheel to run parallel with the back wheel instead of in line with it.
I can't guarantee that's what's wrong with yours, but it does cost nothing to fix, so HTH Thumbs Up
Alpha-9
PostPosted: 16:46 - 26 Jan 2013    Post subject: Reply with quote
Dmcpro; those forks wouldnt fit and the yoke didn't fit either, so I bought 2008 forks and yokes which fit and sold the ones I bought off you
the cg is leaking oil and the sump is rounded off, replacement will be here in a few days
Thanks keggy, the yokes were replaced also though, but t could still be the forks, I just used the mudguard to line up the forks figured that'd straighten it
Trying to work out where the play is with bits of string, don't get how to do it as pegs and exhaust and bits are in the way?
Frame was straightened after my first crash, unless they didn't do a very good job? wasn't re MOT'd
Fzr-600 1999
Ja7
PostPosted: 17:00 - 26 Jan 2013    Post subject: Reply with quote
I think it's done like this.
https://www.motorcyclistonline.com/howto/string_align_motorcycle_wheels/
Alpha-9
PostPosted: 17:33 - 26 Jan 2013    Post subject: Reply with quote
Think I did it wrong then just now Laughing
I don't see where it's out Thinking
https://s13.postimage.org/ckmfd7a46/IMG_20130126_00071.jpg
https://s13.postimage.org/55x3kto8m/IMG_20130126_00072.jpg
https://s13.postimage.org/ipdxqj27q/IMG_20130126_00075.jpg
I mean the wood's straight
https://s13.postimage.org/nziwhtmgm/IMG_20130126_00073.jpg
Fzr-600 1999
Alpha-9
PostPosted: 17:40 - 26 Jan 2013    Post subject: Reply with quote
Heh camera sure shows up where the winter salts have been getting to it
Fzr-600 1999
Paulington
PostPosted: 17:56 - 26 Jan 2013    Post subject: Reply with quote
That's a 2009 YBR? Laughing!
Also, go here for how to do the string check properly: https://www.framestraightsystem.com/Motorcycle%20Frame%20Check.htm
Alpha-9
PostPosted: 18:05 - 26 Jan 2013    Post subject: Reply with quote
Yeppers, why so lol? Razz
I see, will try..
Fzr-600 1999
Paulington
PostPosted: 18:14 - 26 Jan 2013    Post subject: Reply with quote
I see, will try..
I've seen 1950s bikes in better condition, just looks like it's had a hard, hard life with you. Laughing.
andym
PostPosted: 18:22 - 26 Jan 2013    Post subject: Reply with quote
Just out of curiosity, with the headlight, would they allow you to adjust that at the MOT station as I have a similar headlight on my gpz which hasn't been aligned and I was going to take the tools with me
ZaphodBeeble
PostPosted: 19:02 - 26 Jan 2013    Post subject: Reply with quote
Headlight adjustment is the only thing that a tester is officially allowed to modify during testing as far as I am aware. So to answer your question; yes they would but could probably do it themselves if it won't take too long. If, however, it's a long winded process expect them to fail it. You can always tell them that you know how to quickly adjust it.
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
baggylastard
PostPosted: 19:10 - 26 Jan 2013    Post subject: Reply with quote
I think your near me Alpha, where did you take it for the test?
Alpha-9
PostPosted: 19:12 - 26 Jan 2013    Post subject: Reply with quote
ark motors in sileby, just across the road from me
Fzr-600 1999
Nick_Giles
PostPosted: 20:00 - 26 Jan 2013    Post subject: Reply with quote
Are the forks bent as someone suggested.?
If they are and the cause of your woes I have a virtually brand new immaculate pair of fork legs here for a CG. Thumbs Up
Pick em up and they are yours for free.!
I 'did' have a set of stanchions also but gave them to someone on here. (they were a bit used)
Nick.
Nick_Giles
PostPosted: 21:38 - 26 Jan 2013    Post subject: Reply with quote
Ooops. Just realised it's your YBR not the CG that has the problem so the forks would be of no use. Crying or Very sad
Nick
DMCpro
PostPosted: 21:49 - 26 Jan 2013    Post subject: Reply with quote
Post pics of cg? Looks cool
Honda CB-1, TS125X
VW Golf Estate
Boxing
PostPosted: 21:57 - 26 Jan 2013    Post subject: Reply with quote
You didn't take your bike to Fast Track, did you? That one near town, near KFC St. Matthews area?
Don't go there, they're scammers. Wanted £50 to remove a tyre and fix a puncture, £50!!! Got said puncture repaired for £10, it had a slit and air escaping at the valve, fixed up at a car tyre place, fitted on, no problems since. Very Happy
Also heard from another biker suffering from them can't remember what he had happen now though, crash damage or something and they tried to charge him overnight storage when he didn't want their business. Won't be going there again.
Alpha-9
PostPosted: 22:35 - 26 Jan 2013    Post subject: Reply with quote
They straightened the frame for me....
lol Thumbs Down
Forks are fine yokes are fine, as I said, I changed them, they are new.
Fzr-600 1999
The last post was made 13 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 132.07 Kb
