| StevenF |
 StevenF World Chat Champion
 Posted: 19:10 - 26 Jan 2013 Post subject: CBR F2 Valve Clearance Check |
Hi folks
Got a list of things to do before getting the bike back in the road and one is checking the valve clearances. The bike is on 30k miles and I'm not sure if its been done yet.
I'm a bit of a novice mechanic but always willing to learn, so I thought I'd give it a bash.
I've stripped the fairings off (all except front), removed the fuel tank, air box and housing, HT leads and their control box (not sure what that's called) and now I'm left with this:
https://i4.photobucket.com/albums/y118/Wonderboy_001/A514B238-9E20-4090-B388-EC37C95FBB06-343-00000043A0E652BD.jpg
Now for the next step... As you can see the carbs are still in and so is the radiator and spark plugs. I'm aware I need to remove the radiator or at least try and suspend it forward to gain access, but do I need to take the carbs off? I don't want to be messing about with the carbs as I know they can cause a lot of problems!
Thanks ____________________ My Project - Honda CBR 600 F2/FM |
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 23:02 - 26 Jan 2013 Post subject: |
There are only two problems when removing the carbs on your bike.
The main one being, if the carbs haven't been off in while, they don't like coming out of the inlet rubbers.
The only other issue is making sure the throttle cable is correctly routed when you put them back on. It's very easy to trap the cable with tank.
If you can persuade them out of the inlets is a straight forward job! ____________________ "Everybody needs money, that's why they call it money!"  |
| StevenF |
| mab |
 mab Nitrous Nuisance
 Posted: 00:05 - 27 Jan 2013 Post subject: |
This may help
When I did my valve clearances, I didn't need to remove the carbs |
| StevenF |
| StevenF |
 Posted: 10:20 - 27 Jan 2013 Post subject: |
I'm guessing I need to remove the throttle cables that go into the carbs and remove the spark plugs before taking the head off?
I was always of the opinion that you had to replace the gasket if you take the head off, but not many people seem to bother. ____________________ My Project - Honda CBR 600 F2/FM |
| Suntan Sid |
 Posted: 17:27 - 27 Jan 2013 Post subject: |
You are removing the rocker cover, not the cylinder head, you only need to replace the rocker gasket if it's obviously damaged, although it's good practice to renew all gaskets once they'vebeen removed.
According to the Haynes, you don't need to remove the carbs but it suggests removing the coils for ease of access to the valves! ____________________ "Everybody needs money, that's why they call it money!"  |
| StevenF |
| Bikeless |
 Bikeless World Chat Champion
| StevenF |
The last post was made 13 years, 23 days ago. Instead of replying here, would creating a new thread be more useful? |
