I broke it.....CG electrical issues
mudcow007
PostPosted: 21:18 - 28 Jan 2013    Post subject: I broke it.....CG electrical issues Reply with quote
right this is (probably) my fault
i have been tidying up the loom on my cg, replacing corroded connectors etc..
connected four wires from genny up (inc. coil wire) no spark
ignition isnt connected so cant be that
do i need all four wires connected to get a spark from the genny or just the black n white wire?
**edit** this is my fault it was working before i got my mitts on it.....
Islander
PostPosted: 23:11 - 28 Jan 2013    Post subject: Reply with quote
Have you looked for a wiring diagram in the sticky threads in this section?
cb1rocket
PostPosted: 12:15 - 29 Jan 2013    Post subject: Reply with quote
b&w wire is usually the wire that comes on when the ignition is off to short the coil and kill the spark to the engine. disconnect and see if it starts. If so check the switch and that everything is wired up correctly
bikenut
PostPosted: 12:55 - 29 Jan 2013    Post subject: Reply with quote
black with white trace usually ign kill on a honda, connect b and w to earth to kill ign.
Cyclingbiker
PostPosted: 18:15 - 29 Jan 2013    Post subject: Reply with quote
Have you checked the points for dirty or poor contacts or the ignition coil for defects?
Just make sure the wires from the generator are connected to right ones. Simple as it may seem they are hard to see when they are tucked up beneath the tank and I have got them mixed up plenty of times when messing about with my faulty stator. Embarassed
Honda CB500s (1999) - Honda CG 125 BR-J (1991)
Mod 1 - Passed - 12/11/12 --- Mod 2 - Passed - 26/11/12
TheSmiler
PostPosted: 20:08 - 29 Jan 2013    Post subject: Reply with quote
https://i.imgur.com/s2cWj0S.jpg
mudcow007
PostPosted: 21:53 - 29 Jan 2013    Post subject: Reply with quote
cheers for the posts guys
i have just printed the wiring diagram out on 6 sheets of A3 (basically covers my sheds wall)
from what i can work out,
black/white goes from coil to genny & also to ignition - ignition isnt connected though.
i think i will try an strip all connectors tomorrow as maybe there is a bad connection somewhere
if i connect b/w wire from genny to my voltmeter an earth the other probe an kick the bike should i see a voltage?
just trying to figure out how to test wires
thanks all
tomh
PostPosted: 22:12 - 29 Jan 2013    Post subject: Reply with quote
Connecting just the black/white wire up should work absolutely fine. Leaving it disconnected where it connects to the ignition switch is correct aswell as that is basically what the ignition switch does anyway in the ON position (disconnects the wire from the green negative wire going to the ignition switch). When in the OFF postion it will short out the spark wire with earth causing no spark.
What you now need to do is check if the earth/negative is wired/connected correctly. First using a multimeter, switch it to continuity test (the one that beeps) and put one probe on the negative on the battery and the other on the black/white wire. If there is any continuity then that is the problem and there is a short somewhere in the loom.
Next check the earth at the ignition coil and test between the green spade connector for the coil and negative on the battery. If there is no continuity then there is a break in the wiring loom or it is not connected. You can even check the frame is earthed at all by putting the multimeter probe on any bare metal eg, the fork stanchion and the other on the negative terminal.
I assume you've not adjusted/gone anywhere near the points? Also if you do get the bike running, put the choke on full with no throttle to kill the engine without the ignition switch Thumbs Up
mudcow007
PostPosted: 22:32 - 29 Jan 2013    Post subject: Reply with quote
thanks for the reply Tom
yep i haven't touched the points etc...
the engine has been out the bike for a few months since it last ran...
all i have done is snipped off connectors on the 4 wires by the genny (as they were really short) an also lengthened the wire from the coil (black/white)
if i connect a live from the battery to the wire to the coil an earth the neg to the frame. should i get a spark?
mudcow007
PostPosted: 20:43 - 30 Jan 2013    Post subject: Reply with quote
i "think" i have sussed it
the coil is earthing on the frame!?
im getting continuity when the coil is fitted to the frame - if touch green (earth) on the loom an touch the low tension wire coming off coil i get a circuit
im guessing this shouldn't happen?
thanks for all the help Smile
mudcow007
PostPosted: 18:56 - 31 Jan 2013    Post subject: Reply with quote
quick update
i put my voltmeter on genny an earth an got voltages as i turn the flywheel...so points seem ok
anyone any other ideas im stumped
Sad
The last post was made 13 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 73.09 Kb
