Is my battery gone?
the_quick
PostPosted: 10:58 - 29 Jan 2013    Post subject: Is my battery gone? Reply with quote
Left the bike to stand in cold garage for most part of 3 weeks and it was really cold.
Tried to start it, it was very very weak turning and would not start.
Took battery out check with multimeter 11.70V
Ok so I have put it on charge (Lidls charger), after more than 5 hours charger indicated battery is fully charged, checked again with multimeter and it shows 12.85v - sweet.
This morning checked again and it shows 12.72V - so clearly discharged a bit.
Is it normal for battery to go down a bit or is the battery gone and I need a new one?
It is normal acid battery, nothing fancy.
Thanks in advance
Bandit GSF600 '00
Dave-the-rave
PostPosted: 11:08 - 29 Jan 2013    Post subject: Reply with quote
You're supposed to leave the battery for a few hours after charging before testing voltage. If you tested immediately after charging then again a few hours later it would be normal to see a lower second reading. That would be normal and doesn't suggest you're battery is knackered.
uberkron
PostPosted: 21:38 - 29 Jan 2013    Post subject: Reply with quote
The standing voltage of a fully charged flooded type battery at 20 degrees c is 12.6 volts, sounds to me like a good battery. I charge them and give them 24 hours then check voltage. Checking whilsst on charge or just after charging will only show a faulty battery generally.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
uberkron
PostPosted: 21:39 - 29 Jan 2013    Post subject: Reply with quote
ImpactBattery
PostPosted: 23:36 - 29 Jan 2013    Post subject: Reply with quote
The surface voltage will drop off a bit over 24 hrs. Dropping from 12.85 to 12.72 is not bad at all. Your battery appears to be a little sulfated as it should have been able to reach peak voltage of 13 after charge. All in all this battery sounds fine when looking at the voltage.
the_quick
PostPosted: 08:50 - 30 Jan 2013    Post subject: Reply with quote
Thanks guys.
Battery now in bike, started without a smallest problem Smile
Bandit GSF600 '00
The last post was made 13 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 47.42 Kb
