Aprillia Rs125 project
G19RKE
PostPosted: 12:55 - 29 Jan 2013    Post subject: Aprillia Rs125 project Reply with quote
hi guys my name is tom clarke im from north wales and i got into bikes when i was 25 because i moved to wales and the roads are all nice and theres always bikes around and i just had to have some of it! i was into my cars before this but moving to wales turned my interest to bikes so i brought myself a supermoto to see if i liked bikes firstly then shortly i wanted to go faster soi swapped the moto for the aprillia as an upgrade from my supermoto so i could go a bit faster without having to get a full license just yet. I was told it was full power and that it had just had a rebuild so it had to be run in for 500mile... i kept off the band for 500mile and ran it in as i was told then when it went in for mot the guy tells me he dont think its a full power model at all...
the bike struggles to go above 80 so is deffo not full power but in all honesty i never take it into the redline area cause the guy i brought it off said it would mess up the engine if i ride it in redline all the time an ill need to rebuild it again quick if i did that..
its deffo got the power valve because you can really feel the difference when it kicks in, i normally change at approx 10k at most and have never been above 11k on it since rebuild.
it has the 2nd air pipe capped with a big screw in the end of it, it has the double air vent intake under the fuel tank but one of them had a bit of sponge in it for the run in process and the mixture was turned up for run in process too.
since iv had the bike ic put new brakes on front and rear, fitted new chain and sprocket, replaced front wheel bearings, fitted a uk headlight as it was eu fitted, stripped fairings back and repainted as bodywork was in a poor state and now im looking into the mechanical side of things..
the guy who done my mot said the bike was running lovely but he was sure it wasnt a full power version tho. he said his son had a full power version a few years ago and mine was nothing like it.
what can i check to see if i have a full power version and what can i check to make sure everything is working properly.
id like to get it working as it should be and get the full potential out of it. its looking the business now i just want to get it to go like it should Smile
i will add some photos of my project so far..
thanks in advance for your replies Smile
G19RKE
PostPosted: 13:08 - 29 Jan 2013    Post subject: Reply with quote
this is how i got the bike
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1588.jpg
it had rebuild
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1587.jpg
then i stripped it all to freshen it up
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1561.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1566.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1564.jpg
primered em all up
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1565.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1558.jpg
then final coats
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1598.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1582.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1581.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1576.jpg
and putting it back together slowly
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1610.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1607.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1611.jpg
still have not fitted front end yet, iv had to fit a uk headlight as light was projecting onto wrong side of the road, and i want to order some nice probolt fairing kit and screen bolts for it.
im also looking at getting these off ebay as a nice touch i think
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1605.png
https://i18.photobucket.com/albums/b115/clarkie3985/Aprillia%20RS125/IMG_1606.png
so thats how she looks now id just like to get her running like she is meant to with the help of you guys and then ill be one happy chappy Smile she is only going out on bendy roads on nice days and the odd nice day to and from work so i dont use her everyday for commuting or anything Smile
Supermoto_Fan
PostPosted: 13:13 - 29 Jan 2013    Post subject: Reply with quote
Nice bike, subframes bent tho
Formerly known as
P.
If it was restricted, 80 is all you would get with no real "go" after 8k.
Full PV system/exhaust and 34mm carb should give it the full oomph.
You'll want it to be above 60 degrees minimum before you start ragging it past about 6k. You want to keep it above 8k and under the tip of the redline to have some proper power.
G19RKE
PostPosted: 13:34 - 29 Jan 2013    Post subject: Reply with quote
subframe is bent? could you show me what its supposed to be like and where its bent?
yea especially when im in top gear it just bogs down and site at about 80 at around 6k ish. it pulls up to 10k then kind of starts to drop off
is my exhaust not good enough ..
Formerly known as
P.
PostPosted: 13:51 - 29 Jan 2013    Post subject: Reply with quote
I saw 100 indicated on my RS, power valve jammed open and an arrow exhaust.
Exhaust should be fine, you have an older pre-cat model.
G19RKE
PostPosted: 15:37 - 29 Jan 2013    Post subject: Reply with quote
haha thank god for that. i saw no problem with it i just thought someone spotted something i missed....
yea sorry about the grammar im not the best at writing stuff and explaining myself.
also i let my bike run from cold to 50-60 before i ride it anywhere and normally blip the throttle up to about 4-5k an let it drop to warm it up so it doesnt sit there idling at low revs.
one thing i have on my bike is a intermittent sensor reading. its fine from cold when its warming up but once im riding along and its up to temp it will occasionally come up and say its cold or its 30 etc... this is a sensor issue for sure but is that reading water temp or oil temp and where would the sensor be located to replace..
Formerly known as
P.
PostPosted: 15:59 - 29 Jan 2013    Post subject: Reply with quote
You want to be riding it... albeit gently from starting it, don't let it sit there, it'll just coke the plug up. Start it, put your helmet and gloves on and ride gently, don't go over 5-6k till its at 60. You might notice it drop as the thermostat opens.. it just dumps the water round so can get a little colder.
I'd change the plug, as you aren't 100% of the restricted/derestricted etc go buy a BR9ES spark plug and ride with that for a bit. Don't bother with Iridium plugs.
Sensor should be near the head I believe. Should see it there. Just lift the tank.
G19RKE
PostPosted: 16:16 - 29 Jan 2013    Post subject: Reply with quote
so how can i really tell if its restricted or derestricted...
and what do i need to change in order to make it derestricted!
Formerly known as
P.
PostPosted: 16:43 - 29 Jan 2013    Post subject: Reply with quote
A full licence, a proper one.
But... if you want to break the law.
Should have power valve, cable from solenoid to that.
Full exhaust, 34mm carb jetting correctly and a BR10EG plug.
Make sure the power valve is clean, working and put in the right way.
TotalGSXR
PostPosted: 16:57 - 29 Jan 2013    Post subject: Reply with quote
If you stick the bike on a dyno you will quickly find out if it's making close to the ~30bhp or if it's significantly down on power.
nightshaddow
PostPosted: 17:00 - 29 Jan 2013    Post subject: Reply with quote
i am sure i read somewhere that the cdis are restricted too, iirc there is a cut out at the back of the cdi with a metal strip/wire once cut it gives full power,
not sure if its a model thing or a country spec i see if i can find it
edit found this in another forum hth Thumbs Up
CDI Derestriction
The Aprilia RS125 comes with a CDI restriction. It retards ignition around 6000rpm so the bike can pass EU emission tests so they can be manufactured. This makes your bike perform very poor at 6000rpm and does not let the engine pull. Derestricting this will invalidate your warranty. If you bike is in warranty the best thing to do is buy another CDI and derestrict this and use it on your bike.
Derestricting the CDI?The CDI is a black box under the passenger seat. Therefore to get to it you will need to remove the tail of the bike. The easiest way to do this is to remove the rear side fairings with the tail. See the manual for more details.
The CDI will have a serial number on it? if the serial number is in the following format 071000-XXXX-XXXXX then this derestriction will work if done correctly (may still work on others).
You will need to cut out a hole in the CDI to reach the bridge. Cut out a rectangle 30mm by 10mm and 5-10mm deep.
https://flexiweb.atspace.com/rs125/1.jpg
You will see a part of a circuit board, snap this. This is known as the bridge. (If you reach glass it means you have dug too far!)
Once you have snapped the bridge, fill your hole back in with silicone, make sure its waterproof! Now there will be no environmental dip between 5000-6000rpm.
Here is a detailed diagram...
https://www.angelfire...di-instruct.jpg
Full Power Derestriction
The Aprilia RS125 can be restricted so its learner legal, and then derestricted to full power (claimed 33bhp). To do this you will need the following items:
o RAVE controller
o Powervalve blade
o Solenoid
o Cable
If your RS125 is restricted then it will not get a significant power increase around 8000rpm. If you know the powervalve is installed but you are still not getting this increase ensure all parts are working correctly, connected, and the solenoid is set correctly.
What does the powervalve do?
The blade of powervalve goes in the barrel of the engine. This then moves up and down to increase and decrease the exhaust outlet size to give you different performances at different rev ranges. The more revs you give the bike the more the powervalve blade is pulled by the solenoid and opens the exhaust outlet.
All a solenoid is, is an electromagnetic componet. Bbasically all you need to know is it pulls a cable which is connected to the powervalve blade to pull it out to increase the gap in the exhaust outlet.
You must check your bike for the componets listed above.
Your bike may be restricted via a blanking plate. You can see this by removing your right side fairing and looking above the exhaust. It will be a small plate and have 3 bolts along it (one either side and one in the middle). If you see a blanking plate then you will need to purchase the powervalve blade, mount, and other parts see parts diagram below... Your probably best getting a gasket for it too even though there is one on the blanking plate... you can reuse them but to ensure the bike performs well and you dont get any problems get a new one...
https://flexiweb.atspace.com/rs125/2.jpg
Once you have aquired these parts remove your blanking plate and fit the powervalve into the bike.
Note, the powervalve goes in one way!
It has a tapered end on one side, this should face downwards, and the flat side of the powervalve blade should face upwards! Ensure you do this!
https://flexiweb.atspace.com/rs125/3.jpg
If you can see the powervalve mount sticking out the exhaust then you will not need to purchase it of course and you will see something like this above the exhaust...
https://flexiweb.atspace.com/rs125/4.jpg
Remove your tank...
To the right of the battery there should be a solenoid which should have a cable connected on the end of it. The cable connects to the powervalve blade that goes into the engine that we looked at before.
It should look something like this altogether...
https://flexiweb.atspace.com/rs125/5.jpg
If you do not see the solenoid and/or cable then you will need to purchase these.
Once you have purchase these parts mount them to the right of the battery, there is a place for it to be fitted, it goes on the part of the radiator frame that goes right next to the battery.
If you see the solenoid and cable, and you see the powervalve mounted in the engine but your bike is not performing as it should... then it may be a case that the solenoid is not connected! If you look on the picture above there is a connector block on the end of the solenoid, see if this is connected, it connects to the main loom which runs along the right hand side of the bike from the front all the way to the back of the bike.
If you connect it up and it does nothing then keep reading....
Remove the passenger seat and check for the RAVE unit. (just remove the two back side fairings and tail)
https://flexiweb.atspace.com/rs125/6.jpg
If you cannot see this, then you will need to buy one of these and fit it to your bike. There will be a spare connector block coming out of the main loom were it should be connected to. Once you have fitted all these parts your bike should be derestricted!!!
All you need to do now is to set your solenoid up correctly... It has adjuster nuts on it, so the cable can be adjusted. This is because the solenoid starts acting around 3000rpm (you can see the solenoid opening when you rev the bike to this with the tank off). The more the powervalve blade sits in the exhuast the better low range power you will have, but poor top end. This works vise versa. See how to adjust your solenoid below...
https://www.125ccsportsbikes.com/forums/uploads//post-9-1093176496.jpg
WARNING: WHEN YOU DERESTRICT YOUR BIKE YOU WILL NEED TO CHANGE YOUR SPARK PLUG OTHERWISE YOU WILL BLOW A HOLE IN YOUR PISTON. Despite what the manual says, the spark plug to use when your bike is full power (powervalve installed) is a BR10EG. This is because the plug is colder. When your bike is restricted you should run a BR8EG. You can change these plugs for other versions e.g. Denso plugs, Iridium plugs for smoother running.
Exhuast Derestriction
The later bikes 2003 onwards have a CAT in the expansion chamber. In the expansion chamber not the end can. To get rid of this CAT which makes your bike perform differently, get an after market expansion chamber (best buying the end can with it) or buy an earlier expasion chamber from an RS125 or take the expansion chamber off and be prepared to cut it open, remove the CAT and weld it back together.
If you are going to buy a different expasion chamber then you will have to rejet your carb. The bikes with a CAT in them are set to run rich (more oil) because the CAT requires the bike to run like this. Therefore you will need to buy a standard main jet for your carb. If you have a 28mm carb (finally got it right I normally say 26mm) then your standard main jet size is a 120. If your carb is a 34mm your main jet is more likely to be a 158(i think) You can get these for a couple of quid. This means taking your carb off and removing the old main jet, and replacing it with a new one.
The racers tend to use the standard expasion chamber because it is thicker then aftermarket ones therefore contains the heat more, and these work better with more heat. They normally just change the end can.
Removing your CAT (if your being a big man)
You will need to take your expasion chamber off the bike (see manual if you dont know how)
You need to cut your expansion chamber open where this fella is cutting it and where the white line is indicated...https://flexiweb.atspace.com/rs125/7.jpg
Once you have done this you will be able to remove the CAT
https://flexiweb.atspace.com/rs125/8.jpg
Thats it really, dont know too much about it because I havent done it... Just weld your expasion chamber back up with the CAT removed, give it a respay (heat resistant of course) because they tend to rust like hell even if you dont ride your bike in the wet.
https://flexiweb.atspace.com/rs125/10.jpg
The expasion chamber doesnt really have anything in it anyway if your thinking this was too simple. Literally just cut it open, remove the CAT and weld it back together.
Some exhausts also have a recirculation tube that goes to the air box. You just have to cut this off and weld it up and seal up the air box.
The snorkel in the air box can be taken out too, this will let some more air in slightly and make your bike sound a lot better. Just pull the rubber out the top, or you can cut the part that sticks out. This shouldnt affect your jetting since the bike is not jetted correctly from standard anyways. If you want to be sure stick a bigger main jet in (121 on a 28mm carb). Do a plug chop to confirm. To do a plug chop see the pinned topics... under useful RS125 information.
Carbouretter
The older bikes had a 34mm carb on. The new ones have a 28mm carb. I think it was the 98's that had the 34mm carb on then after that unless modified it was a 28mm carb. If you want better mid range power, and a better top end without affecting your petrol consumption too much get a 34mm carb. The petrol consumption is suprisingly good, it does guzzle more but you get that back in power!
All you have to do is get hold of a Deloroto VHSB 34MM and a new inlet manifold because the original will be to small and then fit it onto your bike. The standard air filter will still fit this new carb.
Well thats basically it. Your bike is derestricted...
Mods to follow to make your bike faster and all round better performance...
Formerly known as
P.
PostPosted: 17:02 - 29 Jan 2013    Post subject: Reply with quote
Yup, there is an environmental dip at 5-6k but not needed to get 100mph.
You'll get 28hp out of the engine. Maybe.
Less at the wheel, so don't cry if you only see ~23 at the wheel.
G19RKE
PostPosted: 16:16 - 30 Jan 2013    Post subject: Reply with quote
well after close inspection today i have learned that i have apower valve fitted with cable and actuator. i have the rave control unit under the pillion seat just not sure if cdi is derestricted or not... sooo i have removed the pv today and found that it was sealed in black gunk so i have soaked it and cleaned it all down the best i could get it and gave it a light wet sand to get some more of the gunk off so i will try it once i get it going and see if that makes it any better..
Formerly known as
P.
PostPosted: 16:18 - 30 Jan 2013    Post subject: Reply with quote
The PV can go in 2 ways, but you want it back the correct way.
Don't worry about the CDI, power is mainly over 7k anyway.
Good luck Thumbs Up
G19RKE
PostPosted: 10:25 - 13 Feb 2013    Post subject: Reply with quote
replaced the clutch adjuster yesterday and the clutch... bought a couple of those ally replacement caps from pjme rather than putting the crappy plastic ones back in for the clutch adjuster cover and filler cap on gearbox casing.. also got some blue screen bolts and mirror bolts and tank bolt. new gasket and a new br9 spark plug and liquid top ups and im nearly ready to take her back out after the winter storage...
oh and i added some white rim stripes which i do really like how they look..
https://i18.photobucket.com/albums/b115/clarkie3985/F15F9C4E-65EF-4550-8FFE-3A7255C09FF6-486-00000114F92E6039_zps8971d339.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/AB1BCDD9-8D8D-4710-B5B6-4BA659D876D5-486-00000115153B05D6_zpsf573fe2d.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/BCAA0CCF-A677-42B9-BD84-2847D718875A-486-00000114C854BAD0_zpsa2a2dc59.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/05FA28FD-E178-49E9-B409-2BFFB7EC0B62-486-00000114BBB1D1F3_zpsf5984c55.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/1D996381-ADF3-42B9-8674-2195323B7670-486-00000114ECC20CF2_zps5ac05dab.jpg
https://i18.photobucket.com/albums/b115/clarkie3985/E39CF8C6-8AED-47A6-B804-437E23BE9959-486-00000114DF5A2F8B_zpsa4f89bb8.jpg
one question tho guys is what battery should i buy... the same one thats from the bike now or iv seen a maintenence free gel battery which says its for high performance ignition systems so i thought this might be better for the rs.. anyone else tried these are they a better option for this bike as my one now seems to just die all the time so its gotta be time for a new one.. it was fine before i put it away for the winter but crap now iv got it back out.
G19RKE
PostPosted: 10:30 - 13 Feb 2013    Post subject: Reply with quote
if you look close at the clutch assembly in this picture you can see the top plate isnt sat in the recess like it states it should do in the haynes manual..
is this fitted incorrectly by the previous owner or is there a reason it would have been fitted this way?
i have to be honest i stuck with the haynes factory settings and changed the setup so the top plate sat in the recess properly but it did work fine installed the other way. i wouldnt have known had i not took it apart. .
neatbik
PostPosted: 10:33 - 13 Feb 2013    Post subject: Reply with quote
Motobatt. Thumbs Up
But first just check your charging system is working properly.
Do a search on here, it has been covered in detail before.
Bomberman
PostPosted: 11:15 - 13 Feb 2013    Post subject: Reply with quote
How long was it stood for? Have you charged the battery at all since getting it back out?
GrumpyGuts
PostPosted: 12:29 - 13 Feb 2013    Post subject: Reply with quote
I'd get that seat cover - I've just bought one from the same seller for my Hornet and its great quality Thumbs Up
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
G19RKE
PostPosted: 13:14 - 13 Feb 2013    Post subject: Reply with quote
yea i plan on getting those seats covers at some point... finishing touches an all that.
as for battery yes it is on charge again now but i charged it last week and it started the bike first time. let it run for min then turned it off. then thried it maybe an hour later after tinkering with other things and it was below 12v so turned the motor once but didnt start. then after that just clicked at me and wouldnt turn over so the battery is fooked in my eyes..
once its charged again now im going to test the voltages and make sure its charging the battery before i get a new one.
Bomberman
PostPosted: 13:17 - 13 Feb 2013    Post subject: Reply with quote
Like I say, how long have you left it? It's been pretty cold over the winter so if you've left it all winter its probably fooked. Mine died last year in similar circumstances. That said, the Dynavolt I replaced it with has held up well this year. No idea what's in my new bike yet Very Happy
stirlinggaz
PostPosted: 17:15 - 13 Feb 2013    Post subject: Reply with quote
hi,
remove the battery & take it indoors to charge it up (properly) as the rs is known for being a c*nt to start. the lack of a kick-start doesnt help.
btw ignore what it says on the lcd (on voltage setting) as they are notoriously unreliable.
the rs starter takes a fair bit out of the battery, so be a good idea to stick it on a trickle charger (if you have access to electrickery wherever you park up at night).
12v or below = wont start. even though all the lights work.
12.5-13v & it will start.
put a new spark plug in. no need for expensive iridium or such like, get a couple of br9's
get a multi-meter out & set to v, should be around 13.4 when its been fully charged.
re-install battery & its job done Cool might be an idea to use a little easy start.
while you have the multi-meter out, test your charging system, need to rev it to over 5000rpm or youll quickly flatten any battery, new or old.
so to sum up my babbling
1 : remove spark plug
2 remove battery
3 : charge battery*
4 re-install battery
5 : check compression while you have a full charge & the spark plug is out
6 : fit new spark plug.
finally check charging system with multi-meter.
* helps if you have a good charger, some of which can recover deeply discharged batteries.
heard people say when a battery gets down to single digits its f*cked. bollox, i've re-charged a little battery (yt4 or similar), which was made in 1986 & was showing 3v! topped it up with distilled water,kept it on the charger & it recovered. took a whole day & night & then some!, but got it up to 12.8v & its held its charge ever since.
GAZ
G19RKE
PostPosted: 20:16 - 05 Mar 2013    Post subject: Reply with quote
OK so i need your help again now guys...
iv purchased a new battery and its a motobatt quadflex which is a gel battery and ready to use out of the box and should give me plenty of juice to get the bike going..
however! after shelling out 45 on a new battery im still getting the same clicking noise i was getting before i fitted the battery.. its not even turning the starter or anything...
to be honest if i keep pressing the button it sometimes spins the starter half a turn or so but still doesn't start. its as if the starter is faulty or the starter switch is faulty..
i have tried to bump start it but it is really difficult to push when its in gear, when in neutral i can push it much easier than when its in gear and holding clutch in it feels like its still biting but its not because it does roll but just with resistance.. not sure if they are meant to be like that or not..
if any of you could help that would be great... its all completely charged and a brand new battery but it just clicks when i press start button with or without choke it does the same.
The last post was made 13 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 153.08 Kb
