GS425 - Potential Project
wots
PostPosted: 16:06 - 29 Jan 2013    Post subject: GS425 - Potential Project Reply with quote
I may be able to obtain a GS425 quite cheaply. Been off road for a long time, but dry stored. Anyway, I'm fairly certain this will be leaded fuel only, how difficult (and is it possible) to convert to unleaded. Head swap for something else that's compatible?
It's just one of many things to consider, but was curious at this stage.
bezzabsa
PostPosted: 16:13 - 29 Jan 2013    Post subject: Reply with quote
It'll run on unleaded as it is, most Jap bikes from early 70's took unleaded as standard!!!!
nowhere.elysium
The Pork Lord
PostPosted: 16:14 - 29 Jan 2013    Post subject: Reply with quote
It should be fine on unleaded. What year is it? The Japanese have been making their engines unleaded-compliant for quite some time; I believe they started in the early to mid 70s, although I can't find an exact date.
What sort of condition is the bike in? I've just finished getting my '83 GS650 on the road, and it was a pig of a job, at times. The electrics were a particular challenge.
From what I remember offhand, the GS425 was the predecessor to the 450, which subsequently became the 500 which is still around today. Although Suzuki was investing a bit more time and money into the finish of their bikes back then, I'd still keep a close eye on any steel bits, in case it gets a dose of the tinworm. The engine casings will fur up at the drop of a hat, but it's nothing seriously harmful.
wots
PostPosted: 16:15 - 29 Jan 2013    Post subject: Reply with quote
It was an assumption, but it was also based on an article that someone had written saying that they had run one on unleaded and it ran like a dog, HOWEVER, that doesn't mean that there wasn't something else wrong with though. Very Happy
nowhere.elysium
The Pork Lord
PostPosted: 16:18 - 29 Jan 2013    Post subject: Reply with quote
Combination of this, and the fact that it's a direct antecedent of the GS500, which runs like crap even in perfect nick.
wots
PostPosted: 16:19 - 29 Jan 2013    Post subject: Reply with quote
Not sure exactly, it's a family member and I mentioned a little while ago that I remembered that bike, reminiscing blah, blah, blah. Turns out he still had it, laid up at least 15+ years ago.
I think it was a T/V reg maybe. A little vague. Trying to find out if he wants to part with it! Very Happy
nowhere.elysium
The Pork Lord
PostPosted: 16:28 - 29 Jan 2013    Post subject: Reply with quote
OK. Well, according to your profile, you're in South London, right? I'm based in East London, and have some experience of particularly recalcitrant elderly Suzukis, so I'm happy to lend a hand if you need it.
Based on your guess as to the registration, it'll be somewhere between 1978-80 (at a guess), so it should be happy with unleaded regardless. Most of the parts on this era of bikes are mechanically simple to work on, although I'm warning you in advance about any rubber parts; they may not have perished, but they will have transmuted into granite. As for the electrics, brace yourself for some fun times.
This might be of some interest to you.
wots
PostPosted: 16:31 - 29 Jan 2013    Post subject: Reply with quote
Electrics I can deal with, good experience with this in various fields. It's the Mechanics I'll need to get to grips with.
nowhere.elysium
The Pork Lord
PostPosted: 16:33 - 29 Jan 2013    Post subject: Reply with quote
It won't follow any common sense rules, I promise you Laughing
The mechanical side won't be too challenging; there's nothing overly complex in them, although there were some questionable design decisions - silly things like the carb linkages not liking the English weather very much. Nothing insurmountable, though.
wots
PostPosted: 16:43 - 29 Jan 2013    Post subject: Reply with quote
Good first project bike then?
nowhere.elysium
The Pork Lord
PostPosted: 16:48 - 29 Jan 2013    Post subject: Reply with quote
Provided you don't mind swallowing the cost of parts, yes. They shouldn't be too bad, but check the availability of electrical components (or be prepared to build your own electrical system from scratch), and I found that seats, exhausts, tanks and bodywork were the pricey bits. If they're in good nick, then you're laughing.
Take a look under the seat, though; if it's rusted through, budget for a new one. There's a guy in Germany that I bought a brand new seat for my 650 from; £160, but worth it, given the originals are unavailable.
Be prepared to buy things from the US, but only if you have no other choice. Their postal system is dog slow, but old Suzis seem to be more popular over there.
wots
PostPosted: 16:52 - 29 Jan 2013    Post subject: Reply with quote
I noticed when looking at parts, was checking forks, that a lot of parts were in the US.
What models are (to some degree) interchangeable with parts then?
nowhere.elysium
The Pork Lord
Also meant to add that CMSNL have got a great parts fiche library, and Robinson's Foundry is the place to order OEM parts from; CMSNL sometimes has marginally better prices, but Robinson's will deliver much faster.
nowhere.elysium
The Pork Lord
PostPosted: 16:54 - 29 Jan 2013    Post subject: Reply with quote
Um, I can't answer that with any real authority, but I'd be looking at part numbers from the GS400, the GS450, and maybe (although it's doubtful) the first-generation 500. Whatever you do, check parts numbers: while the items may look identical, there's every chance that there's some subtle difference that'll ruin everything forever.
:edit: after reading around a bit, it would appear that it only shares components with the 400.
Take a look here for more information. Be warned, that's an 80MB link, but it is worth it.
Bezzer
PostPosted: 17:13 - 29 Jan 2013    Post subject: Reply with quote
You'll find the 425 has a lot more in common with the earlier 400 motors than the later 450 and 500s as it was basically a bored out 400. The 400 and 425 had roller bearing big ends and a longer stroke compared to the later plain bearings and bigger bore/shorter stroke of the 450 and 500. You might have more luck with later cycle parts though.
wots
PostPosted: 17:21 - 29 Jan 2013    Post subject: Reply with quote
Just downloaded that Manual, brilliant will have a look through later. Also looking through your thread for you 650
nowhere.elysium
The Pork Lord
PostPosted: 17:25 - 29 Jan 2013    Post subject: Reply with quote
Heh. Well, I hope the manual's useful, and that the thread's a worthwhile read. I've got a Clymer manual for my 650, and it's surprisingly good. I'd still recommend getting hold of an original Suzuki service manual if you can, though; they tend to have very good exploded diagrams, which can be a real sanity saver at times.
The last post was made 13 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.77 - MySQL Queries: 13 - Page Size: 104.28 Kb
