| P.addy |
 P.addy Red Rocket
| P.addy |
 P.addy Red Rocket
 Posted: 21:42 - 30 Jan 2013 Post subject: |
To help issues.... I have drawn a bad diagram.
Brown is my current setup in old frame.
Pink is what the new frame had previously.
Yellow is what I would think works best.
Orange dot is filler cap, blue square is frame.
Dark grey is oil lines from/to the engine.
Red dotted is the estimated path of current oil
Solid red is a metal pipe joining the 2 rubber hoses.
Sorry for the really shit paint..
https://super-user.co.uk/reallybaddiagram.png |
| jimspeed |
 jimspeed World Chat Champion
 Posted: 21:54 - 30 Jan 2013 Post subject: |
You need to find out what exactly the pipe does on the 450 engine, it could just pump it thru a steel pipe to cool the oil a bit (less exposed than a proper oil cooler maybe)
if the 426 had a tank in the frame then that engine mush be dry sumped at a guess? and the 450 definatly is a wet sump ? but yes you could join both pipes together so the oil flows straight thru them or maybe get a pipe made up to do it in 1 go so no joints to leak etc. i wouldn't be blanking them off anyway  ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?" |
| P.addy |
 P.addy Red Rocket
 Posted: 21:57 - 30 Jan 2013 Post subject: |
Wouldn't blank them, I physically just wanted to join them, if it seems sane to people on here  |
| jimspeed |
| P.addy |
 P.addy Red Rocket
| _Iain_ |
 _Iain_ Banned
 Posted: 23:44 - 30 Jan 2013 Post subject: |
Pitbike oil cooler between said hoses.
Cheap, works, cools oil, can be made to fit very easy. Should be fine.
Cant/wont be a filter in the frame as it would mean a frame swap if you needed to clean it
At a guess its routed through there for either oil cooling, a little extra capacity, a 2nd feed of oil to avoid starvation for the few seconds whilst wheelieing/jumps etc, or durability as you might damage a hard pipe of that length/might be easier to break etc.
I thinks anyway.  ____________________ Please be aware that the above post may be full of complete nonsense.
| P.addy |
 P.addy Red Rocket
| _Iain_ |
 _Iain_ Banned
 Posted: 23:56 - 30 Jan 2013 Post subject: |
Nah. I cant belive that they'd actually design a non replaceable filter on a bike thats built to be ragged.
So if the bottom end shits itself you've gotta replace the frame? Makes no sense.  ____________________ Please be aware that the above post may be full of complete nonsense.
| G |
 G The Voice of Reason
| P.addy |
 P.addy Red Rocket
| _Iain_ |
 _Iain_ Banned
 Posted: 00:21 - 31 Jan 2013 Post subject: |
| P.addy |
 P.addy Red Rocket
| G |
 Posted: 00:31 - 31 Jan 2013 Post subject: |
| P.addy |
 P.addy Red Rocket
 Posted: 00:39 - 31 Jan 2013 Post subject: |
It's ok.
If all else fails.. I have a frame number, I have a frame, I'll work some magic.
Engine has to come out anyway but I'll see how it goes  |
 Posted: 01:15 - 31 Jan 2013 Post subject: |
Seems a bit strange.
The printed diagrams look like a dry sump setup. One pump (no need for high pressure) to scavenge the oil from the sump and push it to a tank, and then a feed from that down to the proper high pressure pump. However on a setup like this I would expect the filler to be on the oil tank rather than the sump.
The way you describe the 426 is even stranger. Can't really see how it would work to have a remote tank with a single pipe to / from it. Downloading the owners manual (which is pretty in depth it seems, more a workshop manual) does state it is a dry sump engine.
Pretty much exactly the same oil flow chart is in both the WR426 and WR450 owners handbooks. There must be an extra pipe on the WR426 hidden somewhere.
| P.addy |
 P.addy Red Rocket
 Posted: 08:18 - 31 Jan 2013 Post subject: |
I believe A-A is the sump with a pump in there (number 5)
On the left diagram, I think A is the other pump.
I still can't see how its a dry sump when it takes oil in the standard fashion and pumps it round fairly similar to the SV/any oil cooled lump?
Can you see that engines are not my thing  |
| temeluchus |
| P.addy |
 P.addy Red Rocket
| garth |
 garth World Chat Champion
| P.addy |
 P.addy Red Rocket
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 06:42 - 01 Feb 2013 Post subject: |
Be a bit careful if you decide to work some magic.
Should the bike need a police inspection for any reason, they're pretty savvy about spotting dodgy numbers, font, spacings etc. there's a lot more than meets the eye on a frame number.
Personally, I think the best thing that could be done would be to make a jig from the frame, and swap/reweld the headstock. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| P.addy |
 P.addy Red Rocket
 Posted: 10:10 - 01 Feb 2013 Post subject: |
OK, so this is going to get sorted tomorrow.
Anyone know the stamp size required for a frame number? Can only find 3mm and 5mm punches locally  |
| G |
The last post was made 13 years, 265 days ago. Instead of replying here, would creating a new thread be more useful? |
