Ybr issues
rhys1005
PostPosted: 21:00 - 30 Jan 2013    Post subject: Ybr issues Reply with quote
hi guys bought a 06 ybr125 off a friend in dorset (had to ride it back 300 miles!) for £700 and i've had a few issuea with it. At first it was very hard to change gear. By the time i got home the gears felt better but still shit so i replaced the oil which cured the issue. Next the bike wouldn't start properly and i noticed it had the wrong spark plug so i bought another and it then started straight away. Problem is the bike sometimes doesn't start for a while and takes a good few trys to get it going. my mate said wd40 down the ignition usually fixes the issue Confused Any ideas why that could be? Also today there was a large pop/flash and the fuel indicator stopped working. Oh and it won't start unless i use the choke, i then need to ride with the choke on for a bit for i to stay running. Solutions to these problems will be really appreciated Thumbs Up
Thanks, Rhys.
rob_rob999
PostPosted: 21:16 - 30 Jan 2013    Post subject: Reply with quote
Try taking the carb off and give it a clean with some carb cleaner might not be the problem but wouldent hurt it to give it a good clean with carb cleaner
neil.
PostPosted: 21:47 - 30 Jan 2013    Post subject: Reply with quote
Always needed choke on my old YBR for a few minutes before it would idle normally. Not a problem. Thumbs Up
rhys1005
PostPosted: 08:42 - 31 Jan 2013    Post subject: Reply with quote
Il try the carb cleaner for the choke problem. Any suggestions for the starting problem?
jeddy11
PostPosted: 10:41 - 31 Jan 2013    Post subject: Reply with quote
Clean your air filter and play with choke settings when starting with mine i had to apply the choke in slightly different positions to get a good start rather than off/on with practice you will get used to it.
And as also mentioned i had to run with the choke on untill it warmed up or it would bog down and stall..
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
rhys1005
PostPosted: 22:04 - 31 Jan 2013    Post subject: Reply with quote
Ok took off air filter and my mate or previous owner has ripped out the old yellow paper filter and put in 4cm thick mesh! Do you think that alone would effect the running or do you think because it's mesh with big holes it's let dirt into the carb? Should i just run some sort of cleaner through it or do i need to strip down the carband clean it properly? Never cleaned a carb before. Thanks.
rhys1005
PostPosted: 09:00 - 01 Feb 2013    Post subject: Reply with quote
Bump
jeddy11
PostPosted: 10:59 - 01 Feb 2013    Post subject: Reply with quote
Yes i think there could be crap in the carb if the filter is just a mesh, that may stop the odd leaf going in but not crap that will block your jets.
seems like your going have the carb off to clean it out and the jets reasemble and get a proper airfilter in there !
Fuelly My Z1000SX
YBR Ric
PostPosted: 12:31 - 01 Feb 2013    Post subject: Reply with quote
As the carb has been running an ineffective filtering medium,
perhaps the idle circuit air bleed passage should be your first priority once the carb has been removed from the bike.
Clean all other jets and internals with carb and choke cleaner to remove any stale fuel deposits if present.
The last post was made 13 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 59.07 Kb
