| rhys1005 |
 rhys1005 Crazy Courier
 Posted: 21:00 - 30 Jan 2013 Post subject: Ybr issues |
hi guys bought a 06 ybr125 off a friend in dorset (had to ride it back 300 miles!) for £700 and i've had a few issuea with it. At first it was very hard to change gear. By the time i got home the gears felt better but still shit so i replaced the oil which cured the issue. Next the bike wouldn't start properly and i noticed it had the wrong spark plug so i bought another and it then started straight away. Problem is the bike sometimes doesn't start for a while and takes a good few trys to get it going. my mate said wd40 down the ignition usually fixes the issue Any ideas why that could be? Also today there was a large pop/flash and the fuel indicator stopped working. Oh and it won't start unless i use the choke, i then need to ride with the choke on for a bit for i to stay running. Solutions to these problems will be really appreciated
Thanks, Rhys. |
| rob_rob999 |
 rob_rob999 Renault 5 Driver
| neil. |
 neil. World Chat Champion
 Posted: 21:47 - 30 Jan 2013 Post subject: |
Always needed choke on my old YBR for a few minutes before it would idle normally. Not a problem.  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| rhys1005 |
| jeddy11 |
 jeddy11 Traffic Copper
 Posted: 10:41 - 31 Jan 2013 Post subject: |
Clean your air filter and play with choke settings when starting with mine i had to apply the choke in slightly different positions to get a good start rather than off/on with practice you will get used to it.
And as also mentioned i had to run with the choke on untill it warmed up or it would bog down and stall.. ____________________ Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!! |
| rhys1005 |
| rhys1005 |
| jeddy11 |
 Posted: 10:59 - 01 Feb 2013 Post subject: |
Yes i think there could be crap in the carb if the filter is just a mesh, that may stop the odd leaf going in but not crap that will block your jets.
seems like your going have the carb off to clean it out and the jets reasemble and get a proper airfilter in there ! ____________________ Fuelly My Z1000SX
| YBR Ric |
 YBR Ric Spanner Monkey
The last post was made 13 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
