Ignition frozen, not working
Benno
PostPosted: 00:50 - 31 Jan 2013    Post subject: Ignition frozen, not working Reply with quote
Fortunately this has not happened to my bike. My friend's CBF125, though, had its ignition freeze during the recent cold spell. He poured boiling water on it from a kettle on at least one occasion to try and remedy this (not sure if it worked).
He called me the other day telling me it was still fucked and asking my advice. I don't know a thing about this, all I can think of is perhaps the rapid heating he caused by pouring boiling water on it broke it somehow?
Can anyone offer any wisdom here?
sickpup
Old Timer
PostPosted: 08:34 - 31 Jan 2013    Post subject: Reply with quote
Has he tried oiling it?
YBR Ric
PostPosted: 09:10 - 31 Jan 2013    Post subject: Reply with quote
The boiling water probably removed any remnants of original lubricant from within the switch leaving only water behind.
Then the temperature dropped to below freezing again...
Any water in there needs to come out and lubricant needs to go back in.
Copycat73
PostPosted: 09:45 - 31 Jan 2013    Post subject: Reply with quote
wd-40 inside the key hole
caveat emptor
Walloper
PostPosted: 09:59 - 31 Jan 2013    Post subject: Reply with quote
to washout any water and any lubricant. Smile
For locks the best stuff is Powdered Graphite.
You can get it in dinky little puffer bottles with cute li'l' pointy spouts specifically for lock lubrication.
The benefit of using Graphite is that it is more or less temperature inert and won't harm any seals.
It may cause massive electrical arcing and cremate your arm when you next try to start though Laughing
https://www.google.co.uk/products/catalog?q=graphite+powder&hl=en&gbv=2&prmd=ivns&um=1&ie=UTF-8&cid=15332035299972832691#
Copycat73
PostPosted: 16:39 - 31 Jan 2013    Post subject: Reply with quote
yes & you wont wash the grease out with wd-40 but it will soften whats in there.
No comment Laughing
caveat emptor
Islander
PostPosted: 16:50 - 31 Jan 2013    Post subject: Reply with quote
Definitely this. If you don't have powdered graphite to hand then try rubbing a soft pencil along the key, working it into the lock and repeat until it's working.
My front door lock only gets used when we're away and is prone to seizing with lack of use. This is how I unjam it. Thumbs Up
stuartt
PostPosted: 17:10 - 31 Jan 2013    Post subject: Reply with quote
get it bone dry with a hairdryer then wd-40 or ever better get some grease in it .
The last post was made 13 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.13 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 63.5 Kb
