| vinnychoff |
 vinnychoff Derestricted Danger
| barrkel |
 barrkel World Chat Champion
 Posted: 18:37 - 13 Jan 2013 Post subject: |
Here: https://cdn.bikechatforums.com/files/img_20130113_173238.jpg
In case the picture ever disappears in the future; the check bolt is quite low, only slightly higher than the drain bolt, and the capacity is 300cc from disassembly and 280cc from draining. Torques on all bolts are 13Nm. And check bolt is 2x as long as filler and drain bolts, don't swap them. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| vinnychoff |
| barrkel |
 Posted: 19:00 - 13 Jan 2013 Post subject: |
| vinnychoff wrote: | do you have a pdf copy of the manual i could copy? |
I don't, but the English manual can be bought from David Silver, Wemoto etc., part code 62KTW00 for SH300 07-10, 62KTW00Z for 11-, £40 well spent if you own the bike. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| vinnychoff |
| vinnychoff |
| barrkel |
 Posted: 00:09 - 19 Jan 2013 Post subject: Re: help in starting |
| vinnychoff wrote: | I bought the air filter today and fitted in the snow....tried to start the bike and nothing.
could you tell me how you are supposed to start it. should it be hold the brake? i tried to hold both front and back brake. press the starter but nothing. i can see the heated grips flashing lights. |
Rear brake must be held in hard. The rear brake has two switches, one for the rear light, another, further in, for ignition. Front brake is neither enough nor necessary, it has no connection to ignition. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| vinnychoff |
| barrkel |
| vinnychoff |
| vinnychoff |
| barrkel |
 Posted: 23:36 - 01 Feb 2013 Post subject: |
| vinnychoff wrote: | thanks i have the bike started, serviced and took it to mot. the only issue is that the vin plate was damaged when it was stolen. does any one know if there is a frame number any where else on the bike. on all the other bikes that i have owned they have been at the headstock but i have looked at all the normal places and access covers but no success. i have found the vin tag under the rear wheel.
thanks |
Engine serial number on final reduction case near rear wheel (this is probably what you found); this is near the beltcase separation leverage gap, but further towards the rear wheel.
VIN is right side of frame just in front of rear shock absorber (visible from underneath); I guess this is what was damaged?
Registered number plate is attached on left side of frame in front of rear shock absorber (similarly, visible from underneath)
There's also a throttle body identification number, stamped on lower side of throttle body.
No indication in manual of whether these are all correlated, or whether Honda can match them up. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| vinnychoff |
| vinnychoff |
| vinnychoff |
 Posted: 09:49 - 02 Feb 2013 Post subject: youtube |
i added a youtube video of me pointing out the bolts. hope it will make it easier for others who carry out a service of the diff oil.https://youtu.be/gNSMyHQx_nA |
The last post was made 13 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
