Honda sh300 service. final drive plugs and capactitys?
vinnychoff
PostPosted: 18:21 - 13 Jan 2013    Post subject: Honda sh300 service. final drive plugs and capactitys? Reply with quote
I have a sh300 honda (57 reg) and am servicing it but cant find the level plug for the final drive. I can find the plug to fill up which is high up. when i put a screwdriver in i can see oil but looking around i cant find a bolt in the right area to look like a level plug.
has anyone changed the oil. know the capacity?
thanks Vince
barrkel
PostPosted: 18:37 - 13 Jan 2013    Post subject: Reply with quote
Here: https://cdn.bikechatforums.com/files/img_20130113_173238.jpg
In case the picture ever disappears in the future; the check bolt is quite low, only slightly higher than the drain bolt, and the capacity is 300cc from disassembly and 280cc from draining. Torques on all bolts are 13Nm. And check bolt is 2x as long as filler and drain bolts, don't swap them.
vinnychoff
PostPosted: 18:47 - 13 Jan 2013    Post subject: Reply with quote
thanks for that. it helps so much.
i have been searching for ages on the net. there is little information about the bike out there.
i thought the check bolt looked like a drain plug or a bolt to hold the cases together. when i had the bike apart earlier.
do you have a pdf copy of the manual i could copy?
Vince
barrkel
PostPosted: 19:00 - 13 Jan 2013    Post subject: Reply with quote
I don't, but the English manual can be bought from David Silver, Wemoto etc., part code 62KTW00 for SH300 07-10, 62KTW00Z for 11-, £40 well spent if you own the bike.
vinnychoff
PostPosted: 19:11 - 13 Jan 2013    Post subject: Reply with quote
thanks. much appreciated. its not my bike so helping out to service the bike for a friend.
vinnychoff
PostPosted: 20:39 - 18 Jan 2013    Post subject: help in starting Reply with quote
I bought the air filter today and fitted in the snow....tried to start the bike and nothing.
could you tell me how you are supposed to start it. should it be hold the brake? i tried to hold both front and back brake. press the starter but nothing. i can see the heated grips flashing lights.
i think it must have a fault. maybe the alarm or trasponder in the key maybe. when i picked it up it was dodgy. it took a couple of attempts to turn the key and then start.
Vince
barrkel
PostPosted: 00:09 - 19 Jan 2013    Post subject: Re: help in starting Reply with quote
Rear brake must be held in hard. The rear brake has two switches, one for the rear light, another, further in, for ignition. Front brake is neither enough nor necessary, it has no connection to ignition.
vinnychoff
PostPosted: 11:26 - 19 Jan 2013    Post subject: fault Reply with quote
thanks for your help. i have a fault. i can hear the relays click as i pull the lever in. first must be the brake light, then the start. so both seem to be working but as i try to press the starter nothing. i must have a problem some where else.
i will be trying to find out what to check next.
barrkel
PostPosted: 11:54 - 19 Jan 2013    Post subject: Re: fault Reply with quote
These pages might help: https://imgur.com/a/EDZoO
vinnychoff
PostPosted: 18:51 - 19 Jan 2013    Post subject: Reply with quote
thats really helpfull thanks. i will try tomorow. i guess the fuse or solenoid is first to try
vinnychoff
PostPosted: 22:26 - 01 Feb 2013    Post subject: Reply with quote
thanks i have the bike started, serviced and took it to mot. the only issue is that the vin plate was damaged when it was stolen. does any one know if there is a frame number any where else on the bike. on all the other bikes that i have owned they have been at the headstock but i have looked at all the normal places and access covers but no success. i have found the vin tag under the rear wheel.
thanks
barrkel
PostPosted: 23:36 - 01 Feb 2013    Post subject: Reply with quote
thanks
Engine serial number on final reduction case near rear wheel (this is probably what you found); this is near the beltcase separation leverage gap, but further towards the rear wheel.
VIN is right side of frame just in front of rear shock absorber (visible from underneath); I guess this is what was damaged?
Registered number plate is attached on left side of frame in front of rear shock absorber (similarly, visible from underneath)
There's also a throttle body identification number, stamped on lower side of throttle body.
No indication in manual of whether these are all correlated, or whether Honda can match them up.
vinnychoff
PostPosted: 00:02 - 02 Feb 2013    Post subject: Reply with quote
thanks will have a look tomorrow in the day light
vinnychoff
PostPosted: 09:29 - 02 Feb 2013    Post subject: Reply with quote
thanks. it was the vin plate that they had damaged not the frame so i am off to get a new one made. the other side is the frame which has the number stamped on. thanks. it was so easy to miss.
barrkel wrote:
thanks
vinnychoff
PostPosted: 09:49 - 02 Feb 2013    Post subject: youtube Reply with quote
i added a youtube video of me pointing out the bolts. hope it will make it easier for others who carry out a service of the diff oil.https://youtu.be/gNSMyHQx_nA
The last post was made 13 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.15 - MySQL Queries: 15 - Page Size: 86.13 Kb
