| stryker |
 stryker Brolly Dolly
 Posted: 15:51 - 13 Nov 2004 Post subject: loobman experience |
Ok, so I fitted my loobman today.
https://www.loobman.com
I'm by far no perfectionist, however I came so close to not fitting this little doo-hicky. Attaching something to my bike using a piece of wire coathanger and wire ties just felt so WRONG!
The shaping of the wire coathanger and positioning of the loob dispenser on the rear sprocket drove me mad. It took several goes before I was happy that the applicator would be secure on the sprocket.
I put the oil bottle up near my handle bars. This seems to have an unexpected advantage. Firstly it helps gravity do its job on taking the oil down to the sprocket, secondly it means the oil tube is going front to back so when I ride the "G"s I pull makes sure there is max oil flow when its needed, aka when riding. Thirdly, the oil bottle is above the radiator and the oil tube runs past the engine, meaning in the cold weather when oil turns to treacle, the engine's heat warms it and helps it flow when its most needed.
At this time its on parole. I want to see how it fairs over time. All I can say now is that my rear sprocket has a nice film of oil on it, where as before it looked rather dry with oil soaked dirt stuck too it. My chains looks nicely oiled too.
Pictures will follow shortly. ____________________ Now what? |
| stryker |
| Bomberman |
 Bomberman World Chat Champion
 Posted: 17:25 - 13 Nov 2004 Post subject: |
Cool. I intended to put mine on this weekend, but due to other problems haven't been able to. Interested to see how you get on with it Fitting doesn't seem to have been too problematic, but I do see what you mean about the coathanger bit  ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
'89 TZR 125 - '94 GPZ500s - ZK3 GSXR600 Alstare  |
| G |
 G The Voice of Reason
| Claud 14.7 to 1 |
 Claud 14.7 to 1 World Chat Champion
 Posted: 18:11 - 13 Nov 2004 Post subject: |
Is this one better than Scottoiler? This looks simpler. This one is manual right: you have to "oil" it yourself?
How much?
I'm kinda getting annoyed with the chain wax... Thinking about upgrading somehow... |
| mr.z |
 mr.z World Chat Champion
| stryker |
| Claud 14.7 to 1 |
 Posted: 04:29 - 15 Nov 2004 Post subject: |
Scottoiler or Loobman, that is the question...
Whats better? hehe |
| NickD |
 NickD World Chat Champion
 Posted: 05:03 - 15 Nov 2004 Post subject: |
A well adjusted Scottoiler is priceless.....22.5k on the original chain so far, and it's only just starting to suffer.  ____________________ I was only doing what it said on my licence officer....
Tear along the dotted line! |
| stryker |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 15:05 - 15 Nov 2004 Post subject: |
The scotoilers come with a T-piece so you can splice into the vaccuum tube for the fuel tap which is even easier than trying to get on one of the balancing ports. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stryker |
| mr.z |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
 Posted: 20:48 - 15 Nov 2004 Post subject: |
I suppose the other thing with a loobman is that it comes with a double sided injector. I have never tried but I would reckon you could use the injector with a scotoiler without too many problems.
I am not sure how much a dual injector costs for a scotoiler but I bet it is about the same as buying a whole loobman. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stryker |
 Posted: 10:28 - 16 Nov 2004 Post subject: |
The loobman is pretty inventive. IE the final delivery of oil to the sprocket uses cut off cable ties! so when it wears out you can easily replace the 'tongues'.
But man did it look cheap when it arrived, looks marginally better when fitted.
Yes in your collector tube on the side of the bottle, no air gap means it WILL continue to draw oil from the bottle as the bottle is sealed. ____________________ Now what? |
| DynaMight |
 DynaMight World Chat Champion
 Posted: 09:37 - 17 Nov 2004 Post subject: |
I've used one, The instructions were poor and the fitting was fiddily but worked very well when properly fitted. Wheel doesnt get anymore messy than my Scotoiler, Certainly cleaner than Chainwax/oil (not to mention 100times easier to clean). I used cheap engine oil and worked perfectly, Didnt seem any worse in the Winter or Summer in regards to flow
I did 8,000miles and the cable ties used as oil feeders had only just started to wear down, But a few cable ties dont cost much do they
It's cheap, It's quite difficult to fit but it works. It's cheaper to buy and cheaper to run than a Scotoiler. ____________________ My bikes are at https://www.bikepics.com/members/dynamight/ |
| stryker |
 Posted: 12:10 - 17 Nov 2004 Post subject: |
Thanks for that users report.
I did my first long run with it on today (my 30 mile trip to work). There was a little spot of oil where I parked my bike here at work, but then again I had given it a fairly generous squeeze of the bottle. I get the impression there was already plenty of oil in the pipe.
Happy so far. ____________________ Now what? |
The last post was made 21 years, 307 days ago. Instead of replying here, would creating a new thread be more useful? |
