ACF 50 spray question?
DottyDuck
PostPosted: 19:03 - 04 Feb 2013    Post subject: ACF 50 spray question? Reply with quote
Hello I have ACF50 which i use on my bike.. i shook it and sprayed abit on the bits i needed to. Then sprayed it on another area and all that came out was this weird black stuff it was like a hard gooey thing... so i thought i'd shake it and spray again and its like the same substance! does anyone know if this is normal? cause it wasn't like that when i have used it in the past.
Thanks Thumbs Up
Ripp3rCrust
PostPosted: 19:10 - 04 Feb 2013    Post subject: Reply with quote
The liquid is rather viscous, so may need heating a little before application. Try placing the can in some warm/hot water for a while (not too long!) and trying again. This will help to thin the liquid a little preventing the sludge.
Hope this helps.
Current: '05 CBR600F - Previous: '01 GSF600S Bandit, '06 XR125
Marmalade
PostPosted: 19:16 - 04 Feb 2013    Post subject: Reply with quote
as above plus make sure the can rattles when you shake it.
noobRider
PostPosted: 19:32 - 04 Feb 2013    Post subject: Reply with quote
I used it for the first time yesterday on my bike and I may have gone a bit wild with it. The garage really stinks now and the kids who live directly above it are complaining Neutral . I also got some on the front discs, though they still stopped me ok today.
I suppose the smell could be petrol from flooding the carbs restarting the bike after adjusting the mix.
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
DottyDuck
PostPosted: 20:14 - 04 Feb 2013    Post subject: Reply with quote
Hope this helps.
arhh that makes sense actually because i keep it in a shed with the stuff i use to clean my bike ..and its freezing in there brhhh!
but when i shake it the can does rattle? so that was is confusing me :S
p.s thanks for the help everyone Smile
Dave-the-rave
PostPosted: 20:25 - 04 Feb 2013    Post subject: Reply with quote
Mine's purple and smells like WD40
and so does my ACF50.
Benno
PostPosted: 20:44 - 04 Feb 2013    Post subject: Reply with quote
It says on the can that it needs to be kept warm to work optimally, so warm the can up in some water like others have said and make sure you shake it for a few minutes before use. Just don't get any on the brake discs.
Got some on the front brake disc myself I reckon, because ever since then the front brake has not been as powerful.
Seb
PostPosted: 23:09 - 04 Feb 2013    Post subject: Reply with quote
I spray a cotton cloth and then wipe down the metal surfaces with that. Excessive ACF50 just makes the road crud stick to the bike.
2010 Triumph 1050 Sprint ST
GREENI3
PostPosted: 00:08 - 05 Feb 2013    Post subject: Reply with quote
It's pretty much suppose to come out like that.
What I do is spray some in the cap and then dip a paint brush in it and then apply it to different parts of the bike.
Makes application a lot easier and not as messy.
Davenaylor
PostPosted: 08:18 - 05 Feb 2013    Post subject: Reply with quote
To those that spray it straight on the bike, why not just set fire to your £15 instead?
A quick search on here prompted me to remember the saying, 'a little goes a long way'.
Spray it on a cloth and wipe it on the bike. Even if there are bits you can't reach, the ACF-50 is so full of black magic that it will cover those bits itself as long as you get close enough with your application.
EazyDuz
PostPosted: 09:29 - 05 Feb 2013    Post subject: Reply with quote
I coat my bike twice a year with it, using loads and spraying directly onto the bike. It is still more than half full one year later Thumbs Up
Shaking it for a few minutes is also OTT advice, just chuck it in some warm water, shake a couple of times and spray...
It smells good
PostPosted: 13:07 - 05 Feb 2013    Post subject: Reply with quote
I bought a litre bottle, which I expect to outlast me, and just brush and wipe it on. You get a lot more actual product for your money.
The last post was made 13 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 72.15 Kb
