| WULFSTAN |
 WULFSTAN World Chat Champion
| Hetzer |
 Hetzer Super Spammer
| WULFSTAN |
| temeluchus |
| WULFSTAN |
| Bezzer |
 Bezzer World Chat Champion
| temeluchus |
| WULFSTAN |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| WULFSTAN |
| Timmeh |
 Timmeh World Chat Champion
 Posted: 17:22 - 06 Feb 2013 Post subject: |
My RVF's brakes refused to work properly until I bought a brake-end banjo with a bleed nipple on.
Got some 6mm OD silicone hose, connected two lines from the brake nipples into a pot of DOT4, then got a 100ml syringe and sucked it up through the brake end until there were no bubbles. Tightened everything off and they worked first time.
And no mess either.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
There is a gap of 5 years, 93 days between these two posts... |
| J4mes |
 J4mes World Chat Champion
 Posted: 20:05 - 09 May 2018 Post subject: |
old thread bumperoony
I've put new callipers, twin lines and reservoir on my ZX6R and I'm having a fucking nightmare bleeding them.
I've spent that last 3 hours and a litre of fluid:
trying to bleed with a gunson eezibleed. no. even using an original reservoir lid it won't seal.
reverse bleeding. no. filled the callipers and lines from the bleed nipple with syringe but I've still absolutely zero pressure and when I return to conventional bleeding there is still loads of bubbles.
cracked off the banjos at top. no. shit loads of air came out but it literally just kept coming. pumped 2 reservoirs full through and it never stopped bubbling.
I've no obvious leaks, banjos and nipples all tight.
I'm well and truly fucking stuck! And I've run out of fluid.
ideas? other than burn it?!
| Kawasaki Jimbo |
 Posted: 20:33 - 09 May 2018 Post subject: |
I used a hand vacuum brake bleed kit. (Although the O-ring didn't last long. Anyone know where I can get a replacement?) Apply a vacuum at the bleed nipple, squeeze the lever and open the bleed nipple but close it again before you stop squeezing the lever, and well before the vacuum is spent. Do this several times in succession. You're drawing air pockets downwards and not letting them slide back up. I also stuck a pipette (from work, I don't know where you'd get one otherwise, maybe a syringe?) into the master cylinder outlet to draw air bubbles out and push fluid in.
Strange but I've got no problem with Tokico 6-pots. They're naturally spongy and have a lot of lever travel before they bite but you get used to squeezing hard and they work well in my opinion. My R1's gold spots put them to shame in terms of sharpness but never mind. |
| dydey90 |
 dydey90 World Chat Champion
| Kris |
 Kris World Chat Champion
| Islander |
 Islander World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 01:16 - 10 May 2018 Post subject: |
If you can, remove the master cyl. and try to angle it's dangle with the bleeder open to get every tiny bit of air out.
If there is a bubble in there it will limit how much push there is to force fluid down the brake line.
And you will not get an ezibleed cap to fit a bike reservoir.
They are made for car enthusiastists.
You nee to buy a cap for your bike then drill it and fit the ezibleed adaptor in it.
If ye canny bleed using an ezibleed you are doing something wrong/fcukin stupid.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
 Posted: 06:35 - 10 May 2018 Post subject: |
6 pot Tokicos are gash, block the pistons apart on the bench and watch them bend apart when you pull the lever. Problems with them are always at the caliper. Clamp the lines right above the caliper (yes you can safely clamp braided lines with a proper line clamp) and the lever will go solid. ____________________ a.k.a 'Geri'
| Kris |
| Kris |
| J4mes |
 Posted: 12:09 - 10 May 2018 Post subject: |
Thanks for all the responses, my old man is coming down at the weekend to give me a hand with various methods mentioned. Trying to juggle a wife who's had a C-section, an 11day old, a 4 year old and this is leaving my patience wearing a tad thin!
I do wish I'd bought the nissens instead of having these refurbed but I'll know for next time!
MCN - I have drilled a spare cap, but it doesn't seal enough to cope with the 10-20psi I tried. while it forced fluid through, an awful lot just gobbed out the cap. I did it up so tight the first time I tore the reservoir off its mounts and had to buy a new one
Could try some ptfe on the threads I guess!
My local accessory shop winced when I said the lines were for Tokico callipers and said they were a total cunt to bleed  |
| MCN |
 MCN Super Spammer
| Ste |
 Ste Not Work Safe
| wr6133 |
 wr6133 World Chat Champion
The last post was made 8 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
