PS3 - 42" hitatchi monitor - no sound
bEN_
PostPosted: 17:36 - 12 Feb 2013    Post subject: PS3 - 42" hitatchi monitor - no sound Reply with quote
I've got my PS3 hooked up to my Hitatchi monitor, it doesn't have a TV tuner or a hdmi slot, only DVI ( i think ) instead i use a hdmi in the ps3 which is a DVI connector at the other end, the issue i'm having is i'm told DVI doesn't carry audio ?
at the moment i'm getting sound using the scart cable from the PS3 to the surround sound but this means it's only in stereo and i can only adjust the volume using the PS3 volume options ( which vary from -4 to +4 Rolling Eyes ) or by doing it manually so i can't use the TV remote to adjust it.
so i'm wondering if there is an adapter or some way i can get sound without using the SCART method on the ps3, which i think isn't 5.1 but could be wrong. i'm not sure if i've explained it very well Laughing
this is under the TV/monitor
https://imageshack.us/a/img211/1857/tv1o.jpg
i have tried using the audio 'output' plugs but still having no luck,
https://imageshack.us/a/img99/5010/tv2x.jpg
logitech surround sound ( yep its a cheap one )
https://imageshack.us/a/img689/9742/z506.jpg
i don't know if i need some sort of adapter or basically with the setup i have i'm stuck with getting my audio this way?
anyway, any help appreciated
2010 Ducati 848 Dark
Lamp Post Enthusiast
PostPosted: 18:41 - 12 Feb 2013    Post subject: Reply with quote
Not likely to get anything unless you use the optical audio out on the PS3 into a suitable amp.
bEN_
PostPosted: 18:46 - 12 Feb 2013    Post subject: Reply with quote
The surround sound setup i got was meant for a PC setup so doesn't have a remote and the cables for the speakers aren't too long either Laughing my fault for not researching my setup properly Cool
oldpink
PostPosted: 19:03 - 12 Feb 2013    Post subject: Reply with quote
HDMI -> AV converter should work
https://img.dxcdn.com/productimages/sku_47628_1.jpg
Irn-Bru
PostPosted: 19:12 - 12 Feb 2013    Post subject: Reply with quote
HDMI -> DVI & use older PS2 leads on the AV port to output sound, can convert white & red to stereo sound (I convert it to 3.5mm for my PC speakers), PS3 supports multiple outputs so works fine. I used to have a similar set up (and still do for when mates are around) but I mostly use a gaming headset these days which uses optical out.
bEN_
PostPosted: 19:29 - 12 Feb 2013    Post subject: Reply with quote
So this is the cable i use from the ps3, into the back of the surround sound to currently get my sound.
https://www.iwaco.de/bild/xps-2-chinch-kabel-3-0m-13-656758.jpg
would this adapter then enable me to have the sound setup properly?
i am terrifically shit when it comes to this stuff as you might have gathered Laughing so how would it be wired/connected up?
thanks
oldpink
PostPosted: 19:41 - 12 Feb 2013    Post subject: Reply with quote
AV input 1, 2 or 3
yellow plug to yellow input ...
The last post was made 13 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 53.87 Kb
