Dent in titanium pipe.
Hetzer
PostPosted: 13:05 - 12 Feb 2013    Post subject: Dent in titanium pipe. Reply with quote
I have a small dent in one of my Ti downpipes, where it goes from vertical to horizontal under the motor. I'm aware of the freezing water technique but have also heard of tapping a ball or whatever into the pipe to drive the dent out. My question is this...how fragile is titanium? I've read that heating won't help, that the shit's brittle and liable to bust open etc. So, fix it or leave it? It's not causing a problem, it just niggles me.
PostPosted: 14:19 - 12 Feb 2013    Post subject: Reply with quote
How small is small? Can you turn a little wheel up with a rounded profile and fit it into a rod to poke down the hole and 'roll' it out?
Hetzer
PostPosted: 14:51 - 12 Feb 2013    Post subject: Reply with quote
I don't see how that would be possible, no way would I be able to get enough weight/pressure down onto the wheel. Hammering a form-fitted bung would do it fine, I'm just worried the titanium would fail.
Nick 50
PostPosted: 23:13 - 12 Feb 2013    Post subject: Re: Dent in titanium pipe. Reply with quote
It completely depends on the grade and alloy of the Titanium. Pure titanium is pretty ductile.
The issue normally with Titanium is heating it up as it's quite resistant to heating unless it's done properly and close to its eutectoid point.
I've attached a journal article (it's from 1970 though) if you are seriously interested in Titanium ductility/stress capabilities.
What people might be getting the "brittle" idea from is if it hasn't been welded correctly. If the weld is contaminated (even slightly) it becomes very brittle (the weld itself) .
Frost
PostPosted: 23:33 - 12 Feb 2013    Post subject: Reply with quote
I think the brittle idea comes from the grade of Ti used on bikes. Generally i's quite low grade and it's been heard of for Ti valves to fail on a tuned engine.
For an exhaust it would depend on my skill and the exact damage, but i'd be tempted to give it a go.
el_oso
PostPosted: 23:57 - 12 Feb 2013    Post subject: Reply with quote
no obligatory crappy picture taken on a mobile? tut tut...
Duke 390
Car: Jeep Wrangler 4.0L
Hetzer
PostPosted: 08:43 - 13 Feb 2013    Post subject: Reply with quote
So it should bend back ok then. I'll give it a go, I've got some Delrin I can turn to size and put a nice cone profile on. Thumbs Up
Thanks guys. Very Happy
Nick 50
PostPosted: 13:31 - 13 Feb 2013    Post subject: Reply with quote
Just keep an eye on where it is welded. Thumbs Up
spikenipple
PostPosted: 17:05 - 13 Feb 2013    Post subject: Reply with quote
Just make sure you drill a hole through the cone and stick some studding through it so you can get it back out Laughing
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
Hetzer
PostPosted: 09:49 - 14 Feb 2013    Post subject: Reply with quote
It'll be threaded onto some rod. Wasted
PostPosted: 16:28 - 14 Feb 2013    Post subject: Reply with quote
I don't rate the chance of success as very high for that. I think there's a real risk of it getting badly stuck too.
Hetzer
PostPosted: 17:14 - 14 Feb 2013    Post subject: Reply with quote
I don't think it'll get stuck, I'll give it a bit of clearance and the rod will pull it out given enough brute strength.
spikenipple
PostPosted: 21:55 - 14 Feb 2013    Post subject: Reply with quote
I wouldn't thread the delrin. Put studding through the plug, stick a nut on it and a few large washers to spread the load across the plastic. Then put a nut and washer(s) on the outside end with a lump of steel on the rod to use as a slide hammer to get it back out Thumbs Up
You could also use it as a slide hammer to bash the dent out.
Walloper
PostPosted: 08:26 - 15 Feb 2013    Post subject: Reply with quote
Turn it to the pipe's I.D. (Fire a hole through the centre.
Polish the edge.
And make a dolly to bash the feckin' ding out.
Heat probably won't have much effect on Titanium as it loses it's heat so quickly.
Have you PM'd Warped for advice??
Mind you, it maybe a bit early doors for the cunt right now though.
The last post was made 12 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 83.28 Kb
