Help Required! Dont know whats gone wrong!
donniemateno
PostPosted: 10:23 - 16 Feb 2013    Post subject: Help Required! Dont know whats gone wrong! Reply with quote
I previously posted on here about my brake being spongy and gunk coming from behind the lever.
I was advised to buy a master cylinder repair kit which I have done to repair mine
anyway I took it apart today and after a bit of WD40 the old piston came out, yay!
now I've just looked at the new part which is identical to the photo in haynes.......but nothing like which came out! see pictures.
The one which came out was help in with a washer spring and clip and the one I have to put in is over double the size!!!
advise please i dont wanna be mugged by a garage when this does seem a simpple repair Sad
Current bike: Honda CBR 600 F3
Previous bikes: Honda XR 125L5 , BMW 800 ST, Honda CB500
donniemateno
PostPosted: 10:24 - 16 Feb 2013    Post subject: Reply with quote
BTW its a CB500 R reg...sorry shoulda mentioned
and after a tiny bit of googling there is this kit:
https://www.wemoto.com/bikes/Honda/CB_500_V/97-98/picture/Rebuild_Kit_Brake_Mastercylinder_-_Front/
but thats still totally different to what I have
dansp1
PostPosted: 10:34 - 16 Feb 2013    Post subject: Reply with quote
Photos are really poor which doesn't help, but it looks as though you haven't got the piston out of your master cylinder yet!
donniemateno
PostPosted: 10:35 - 16 Feb 2013    Post subject: Reply with quote
at the risk of sounding thick is the silver shaft i removed which is in the top photo not the piston?
dansp1
PostPosted: 10:39 - 16 Feb 2013    Post subject: Reply with quote
looks like the actuating rod to me, the piston is stuck inside the cylinder, a little "percussive maintenance" may help, or compressed air if you have access
Copycat73
PostPosted: 10:40 - 16 Feb 2013    Post subject: Reply with quote
+1
don`t throw any of those bits out, i suspect that the long black bit will need reusing.
caveat emptor
donniemateno
PostPosted: 10:42 - 16 Feb 2013    Post subject: Reply with quote
ah yes I have got it own. thank you but ive just uploaded another picture. there completely differnt
dansp1
PostPosted: 10:47 - 16 Feb 2013    Post subject: Reply with quote
Probably had the wrong master cylinder fitted at some time, the one on the right looks too big a bore for a single caliper set up, you want 12 13 or 14 mm bore size at most, that one looks 17mm?
would explain your crap brake too
lllN30lll
PostPosted: 10:50 - 16 Feb 2013    Post subject: Reply with quote
You sure it's the right kit?
or does it look like you need this one?
https://www.wemoto.com/bikes/Honda/CB_500_R_T/93-96/picture/Rebuild_Kit_Brake_Mastercylinder_-_Front/
Turbo R1
CRF450R
donniemateno
PostPosted: 10:52 - 16 Feb 2013    Post subject: Reply with quote
the link you sent me that the kit I have
But the shaft on the left just seems too long I can probably fit in in but dunno if thats just going to leak?
dansp1
PostPosted: 10:53 - 16 Feb 2013    Post subject: Reply with quote
what is the size of the master cylinder you have? (it is cast or stamped on the body)
donniemateno
PostPosted: 10:59 - 16 Feb 2013    Post subject: Reply with quote
only stammp i see says te29 13
as i posted before is this not the same part that came out? https://www.wemoto.com/bikes/honda/cb_500_v/97-98/picture/rebuild_kit_brake_mastercylinder_-_front/ which would explain why this 96 part wont fit my 97 bike >_<
dansp1
PostPosted: 11:02 - 16 Feb 2013    Post subject: Reply with quote
measure the diameter of the piston
lllN30lll
PostPosted: 11:07 - 16 Feb 2013    Post subject: Reply with quote
so they've sent the wrong kit.
Turbo R1
CRF450R
donniemateno
piston which came out 13mm piston supplied 11mm
Hetzer
PostPosted: 11:11 - 16 Feb 2013    Post subject: Reply with quote
Or he ordered the wrong one.
donniemateno
PostPosted: 11:13 - 16 Feb 2013    Post subject: Reply with quote
receipt has model CB500 V...which this clearly isnt for. Sorry for bothering all yu guys just seems been sent wrong part Sad
Will have to use the horrid seicento for commuting till the right part shows up Sad
lllN30lll
PostPosted: 11:15 - 16 Feb 2013    Post subject: Reply with quote
He ordered this for his '97 https://www.wemoto.com/bikes/Honda/CB_500_V/97-98/picture/Rebuild_Kit_Brake_Mastercylinder_-_Front/
But ended up receiving this one instead https://www.wemoto.com/bikes/Honda/CB_500_R_T/93-96/picture/Rebuild_Kit_Brake_Mastercylinder_-_Front/
Turbo R1
CRF450R
dansp1
PostPosted: 11:17 - 16 Feb 2013    Post subject: Reply with quote
wrong kit or wrong master cylinder, all the kits on ebay seem to be 11mm
donniemateno
PostPosted: 11:18 - 16 Feb 2013    Post subject: Reply with quote
The V model looks correct...well visually anyway
The last post was made 12 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 99.55 Kb
