| gwgw |
 gwgw L Plate Warrior
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 22:22 - 16 Feb 2013 Post subject: |
no power to coil....or bad earth checkpoint........
usually theres no power to the coil unless the cdi unit allows it.The cdi unit turns the power on and off to the coil? ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| ricklincs45 |
 ricklincs45 Nitrous Nuisance
| Robby |
 Robby Dirty Old Man
| gwgw |
| gwgw |
| ricklincs45 |
 Posted: 13:13 - 18 Feb 2013 Post subject: |
Ok, I can see where you're coming from, but fairly sure you'll need power from the alternator/rotor to get the engine running, in which case I'd advise also connecting the regulator/rectifier (I'm sure someone with more electrical expertise will comment if I'm wrong).
Connect your alternator and rectifier, don't worry about indicators/horn/headlamp, then try kicking the bike over and see if she'll spark. If she does, brill - if not, start will basics such as checking none of the wires are physically damaged and ensuring all your earth points are perfectly clean. Have come across CG125's in the recent past that have had spark problems; these have been solved by cleaning the mounting points where the ignition coil bolts to its brackets.
If no joy with that, go back even further: check your points are actually opening, if they aren't, the bike will never spark. Also worth removing the HT cap and seeing if the coil will spark (to earth) with it removed.
Trying to make things simple by leaving things like the alternator disconnected is actually making things harder to diagnose where the fault lies.
Good luck
 ____________________ Author '80 Bikes, and counting...' Currently getting frustrated with an MZ 125 TS. |
| gwgw |
| unitynotsocri... |
 Posted: 04:07 - 26 Feb 2013 Post subject: |
remember ,with the normal wiring ,ANY power to the ignition coil and points is usually routed through the ignition switch,and a few switches have a 'null' circuit,two wires that deliberatly short a power or ignition coil out to prevent the engine starting when the switch is in the off position because the power for the ignition coil is taken from a generator coil,not a battery supply.i.e. stop theives.....
this circuit caused great hilarity with bike theives in the 80's ,intent on killing cg's and other bikes that used a flywheel power coil for points,simply....instead of picking the lock or buggering it with a big screwdriver ,all you did was disconnect the ign switch connector block....VOALIAVOLAI start me and trash me,i dont even need a key!!!!thank you honda.
maybe cg's deserved it for being the ugliest mfkrs,below mz's.
with the advent of chinese clones,the glory daze of stolen cg grasstracking is making a comeback. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| gwgw |
 Posted: 10:38 - 26 Feb 2013 Post subject: cb 125 rsd wiring problem |
This would confirm with the afore mentioned wiring diagram, ie, the ignition has to be on to feed the coil.
As i can't make out the colours of the 3 wires coming from the alternator is there a simple way of testing them to determine which goes where ?. Or doesn't it matter ?
One to ignition switch [b/w], one to reg/rec [white] and the other to the yellow wire for the lighting switch.
A 4th wire [light green] goes to neutral switch which is ok.
Thanks all.
| unitynotsocrippledatmo wrote: | remember ,with the normal wiring ,ANY power to the ignition coil and points is usually routed through the ignition switch,and a few switches have a 'null' circuit,two wires that deliberatly short a power or ignition coil out to prevent the engine starting when the switch is in the off position because the power for the ignition coil is taken from a generator coil,not a battery supply.i.e. stop theives.....
with the advent of chinese clones,the glory daze of stolen cg grasstracking is making a comeback. |
The last post was made 13 years, 51 days ago. Instead of replying here, would creating a new thread be more useful? |
