cb 125 rsd wiring problem
gwgw
PostPosted: 13:23 - 16 Feb 2013    Post subject: cb 125 rsd wiring problem Reply with quote
Hi everyone, quick simple question for all you experts. I'm confused why my bike won't start. When i connect my voltmeter lead to the + on the coil and other lead to earth/frame i get zero volts. [ign on or off].
I have been following the 125 rs diagram [kindly uploaded by caferacer843] which is exactly the same as mine.
Am i correct in thinking i should have a 12v supply to coil ?
Basically i just want to start the engine to see if its running ok. All i want are the basic connections to just fire it up, ie battery, points , coil, condenser. All other components are disconnected, such as the lights, horn, resistor, regulator/rectifier and alternator.
The coil reads 4.7 ohms accross the + and - ?
Before i delve further could anyone confirm zero volts at coil and i am ok to leave the other components disconnected or could this be the problem.
Many thanks for looking.
ricklincs45
PostPosted: 09:08 - 17 Feb 2013    Post subject: Reply with quote
Try connecting both the rectifier and alternator - have a 125 RS myself and can't imagine it'll run without at least the alternator.
You're fine to leave horn/lights disconnected.
Not sure why you're bothering measuring voltage at moment, have you kicked the bike over to see if the HT lead/plug is sparking?
As previous poster has mentioned, ensure all earths are good.
Author '80 Bikes, and counting...' Currently getting frustrated with an MZ 125 TS.
Robby
Dirty Old Man
PostPosted: 10:31 - 17 Feb 2013    Post subject: Reply with quote
Your mistake is attempting to simplify things.
Get everything connected up, then give it a go. You want to see if the engine is running well, so there isn't much point in trying to run it without ancillaries.
gwgw
PostPosted: 21:19 - 17 Feb 2013    Post subject: Reply with quote
unitynotsocrippledatmo wrote:
no power to coil....or bad earth checkpoint........
usually theres no power to the coil unless the cdi unit allows it.The cdi unit turns the power on and off to the coil?
thanks for reply, however there is no cdi unit on this model, it has conventional points.
gwgw
PostPosted: 21:33 - 17 Feb 2013    Post subject: Reply with quote
Thanks for reply, i have brand new battery fitted so i figure i don't need the rec and alternator connected just to start it. No spark at HT lead/plug that's why i started with the possible coil failure. Just thought i would need some voltage there to start with. Another way to look at it would be having engine on a bench, ie. if you had petrol supply sorted what electrical components would i need to kick start engine into life ? [ simple electrical connections required]
Thanks again.
ricklincs45
PostPosted: 12:13 - 18 Feb 2013    Post subject: Reply with quote
Ok, I can see where you're coming from, but fairly sure you'll need power from the alternator/rotor to get the engine running, in which case I'd advise also connecting the regulator/rectifier (I'm sure someone with more electrical expertise will comment if I'm wrong).
Connect your alternator and rectifier, don't worry about indicators/horn/headlamp, then try kicking the bike over and see if she'll spark. If she does, brill Thumbs Up - if not, start will basics such as checking none of the wires are physically damaged and ensuring all your earth points are perfectly clean. Have come across CG125's in the recent past that have had spark problems; these have been solved by cleaning the mounting points where the ignition coil bolts to its brackets.
If no joy with that, go back even further: check your points are actually opening, if they aren't, the bike will never spark. Also worth removing the HT cap and seeing if the coil will spark (to earth) with it removed.
Trying to make things simple by leaving things like the alternator disconnected is actually making things harder to diagnose where the fault lies.
Good luck
gwgw
PostPosted: 17:29 - 25 Feb 2013    Post subject: cb 125 rsd wiring problem Reply with quote
Hi again,
decided to run a 12v supply to coil direct from battery, hey presto i got my bike started.
If i reconnect my ign switch and alternator etc, i end up with no supply to coil, i assume from wiring diagram that the supply would be from black/white wire from the alternator. So on kickover would this supply the voltage to coil, if so does this mean my alternator is capput ?
Any simple tests to confirm.
Appreciate any pointers...
Thanks everyone
gwgw
PostPosted: 09:38 - 26 Feb 2013    Post subject: cb 125 rsd wiring problem Reply with quote
This would confirm with the afore mentioned wiring diagram, ie, the ignition has to be on to feed the coil.
As i can't make out the colours of the 3 wires coming from the alternator is there a simple way of testing them to determine which goes where ?. Or doesn't it matter ?
One to ignition switch [b/w], one to reg/rec [white] and the other to the yellow wire for the lighting switch.
A 4th wire [light green] goes to neutral switch which is ok.
Thanks all.
remember ,with the normal wiring ,ANY power to the ignition coil and points is usually routed through the ignition switch,and a few switches have a 'null' circuit,two wires that deliberatly short a power or ignition coil out to prevent the engine starting when the switch is in the off position because the power for the ignition coil is taken from a generator coil,not a battery supply.i.e. stop theives.....
this circuit caused great hilarity with bike theives in the 80's ,intent on killing cg's and other bikes that used a flywheel power coil for points,simply....instead of picking the lock or buggering it with a big screwdriver ,all you did was disconnect the ign switch connector block....VOALIAVOLAI start me and trash me,i dont even need a key!!!!thank you honda.
maybe cg's deserved it for being the ugliest mfkrs,below mz's.
with the advent of chinese clones,the glory daze of stolen cg grasstracking is making a comeback.
The last post was made 12 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 67.36 Kb
