CB250N SuperDream 1981
mumbles
PostPosted: 22:01 - 18 Feb 2013    Post subject: CB250N SuperDream 1981 Reply with quote
I have striped and rebuild my cb250 cleaning/replacing every part on the bike and have now put it all back together. the problem is the bike has a very rough idle and if I rev from idle (1400RPM) it revs up fine but when I let go of the throttle is revs down to (3500RPM-4000RPM) I have re-cleaned the carbs checked throttle cables clean airbox replaced ignition coil and i have run out of ideas also if it's any help the sparks plugs get carbon black on them everytime
Warming the world 2 strokes at a time.
2008 rs50 (SOLD) - 2006 gz125 - (Winter Bike) - 1981 CB250N (In Restoration)
STONEY!
PostPosted: 22:38 - 18 Feb 2013    Post subject: Reply with quote
Check the stator windings mate, also all the fuses and wiring under the left side panel.
Shaft
PostPosted: 22:41 - 18 Feb 2013    Post subject: Reply with quote
Do the carbs again, it took me four goes to get mine right.
They are susceptible to everything; they have to be operating theatre clean, the float heights have to be perfect and the needle valves are prone to sticking, amongst other things.
Even after getting it running right, mine would occasionally leak out of the left carb, then it just stopped one day and never did it again.
Use genuine rebuild kits if you can, the pattern ones are gash.
If it makes you feel any better, there's some poor bloke running a resto blog that has never been able to get his right, now he's on his third set of carbs.
mumbles
PostPosted: 00:02 - 19 Feb 2013    Post subject: Reply with quote
Stoney: I checked all the electrics with an ohm meter like it said to in the Haynes manual does than include the winding's ? and all the fuses ect are perfect I spent 2 weeks reconditioning an already working wiring loom I know for sure their are no problems their
Shaft: I'm going to clean my carbs again, but just one thing I last time I stripped them I tried to set the float height but the float is plastic how do I set it ?
Shaft
PostPosted: 00:13 - 19 Feb 2013    Post subject: Reply with quote
That's a good thing, you can't adjust them.
I got so frustrated with mine, I almost resorted to buying a set of plastic floats (that's all that's available now) but they work out at around £100 for the pair, so I persevered!
Blow through everything with compressed air (don't be tempted to poke things through the jets) make sure the plungers are moving freely, nothing is worn and everything is back to factory settings and balanced.
ETA: check the inlet rubbers, they go brittle with age, so make sure they're sealing properly and they haven't got any splits in them, otherwise you'll never get it set up right.
mumbles
PostPosted: 00:16 - 19 Feb 2013    Post subject: Reply with quote
Thanks mate will get them cleaned as soon as I get a chance and do the plastic floats really cost that much?? to think I was going to chuck them out because I could not adjust them [/quote]
Shaft
PostPosted: 00:29 - 19 Feb 2013    Post subject: Reply with quote
Also, check your tank for rust and if in doubt, fit an inline fuel filter.
Shaft
PostPosted: 13:45 - 19 Feb 2013    Post subject: Reply with quote
unitynotsocrippledatmo wrote:
if it were mine,and I had the money i'd buy a couple of new diaphrams.
I wouldn't like to be sent out to find some.
bikenut
PostPosted: 14:42 - 19 Feb 2013    Post subject: Reply with quote
wet dream eah!!
anyoww, is ignition advance working properly and re clean the carbs after cleaning out tank, tap and lines, fit fuel filter.
the cables arnt causing the problem are they?? or worn throttle spindles?? cold engine running spray wd or similar around carbs, revs rise??
ps the 250 dont have diaphragms but the 400 does.
mumbles
PostPosted: 17:33 - 19 Feb 2013    Post subject: Reply with quote
Tank is fresh from the paint shop it's spotless inside and out but i am running an in line filter anyway, Im not sure how to check ingition advanced timing? and i also changed my coil to a cheap Chinese replacement part because i thought my other coil was broken but tuned out it was working fine and i dont know how to check for worn throttle plates, the cables are a little firm even after oiling them and getting new one but i can see the throttle on the carb fully close
bikenut
PostPosted: 20:23 - 20 Feb 2013    Post subject: Reply with quote
timing light for ign advancs, marks on f/wheel to the left of "F", smooth transition from f at idle to full advance marks at 4k revs
on a cool engine running, spray some wd or similar ( remember it willburn ) onto the throttle butterfly shaft area one carb at a time, any rev increase all byits self..........
no is good.
progress onto carb rubbers tween carb and head, any rev increase all by its self.........no is good.
study cmsnl exploded views foryour bike print them off.......over
bikenut
PostPosted: 20:26 - 20 Feb 2013    Post subject: Reply with quote
the throttle twist grip should return by spring smooothly and fully........as well as on lock to lock.........
bad cables can cause problems returning etc..........
Pockets
PostPosted: 20:44 - 20 Feb 2013    Post subject: Reply with quote
I have to agree with everything Shaft said earlier, I'm rebuilding a 400 Superdream for no real reason, I've just rebuilt the carbs and still getting niggly little issues like float valves sticking, Shaft is spot-on when he says that you can end up taking the carbs off many times after rebuilding them.
A point worth mentioning is that the Keyster carb rebuild kits don't have the greatest reputation especially the needles, worth bearing in mind.
Finally, have you joined the Superdream forum? there's lots of goo technical assistance available:
https://honda-superdream.proboards.com/index.cgi
mumbles
PostPosted: 12:04 - 28 Feb 2013    Post subject: Reply with quote
Finally got round to cleaning the carbs up, put em back on the bike and it started first time idled perfectly so I synced the carbs and 2 mins later idled rough and right carb pops in exhaust every now and again and pops though the carb a little more often and it wont rev up but when it does after 5000rpm it revs great no problem
suzukirider19...
PostPosted: 12:47 - 28 Feb 2013    Post subject: Reply with quote
i used a old cb250n engine in a quad project i did some years ago and did away with the std carbs as they were horid to so the least. a good conversion is a set of carb from a suzuki rgv 250 26mm round slide carbs and jetted to suit worked amazing. cost me 50 quid for a set of carb and fit straight into std inlet rubbers.
husky sm610
mumbles
PostPosted: 15:04 - 28 Feb 2013    Post subject: Reply with quote
Dont think the carbs are the problem they are very clean like new, I have ordered a new cdi and it already has a new ignition coil so hopefully that cures it
UPDATE: I have been messing about with the mixture screw and it idles a little rough but it's okay and it revs up fine but theirs a little hesitation just before it revs up if you open the throttle fast
prawny1
PostPosted: 23:43 - 28 Feb 2013    Post subject: Reply with quote
check for air leaks aroung the inlet manifold/pipework and check to see if the choke is not coming off properly both can cause revs to hang like that.
hellkat wrote:
mumbles
PostPosted: 00:21 - 01 Mar 2013    Post subject: Reply with quote
I removed the chokes (they were pointless on this engine in my opinion) and first thing on my list to do tomorrow thanks
bezzabsa
PostPosted: 12:33 - 01 Mar 2013    Post subject: Reply with quote
WHY????
so how do you intend to run in cold weather???? and ho do you think the cold throttle response will be?
put them back on. they are there for a reason!!
mumbles
PostPosted: 13:58 - 01 Mar 2013    Post subject: Reply with quote
bezzabsa wrote:
WHY????
The choke's were broken and causing more problems than solving when I got the bike so I removed them as I hardly ever use them because
I always warm my bikes before riding, habit since owning my rs50.
trevor saxe-coburg-gotha
PostPosted: 08:06 - 02 Mar 2013    Post subject: Reply with quote
Pockets wrote:
there's lots of goo
So THAT'S why they call it the wet dream!
Mr. Green
paddlesat16
PostPosted: 16:34 - 02 Mar 2013    Post subject: Reply with quote
Lumpy idle....
could be the carbs need balancing Wink
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
mumbles
PostPosted: 16:42 - 04 Mar 2013    Post subject: Reply with quote
thanks guys engine is running spot on now after adjusting the balance and mixtures screws Smile just the odd pop when revving down now
titan666
PostPosted: 23:00 - 04 Mar 2013    Post subject: Reply with quote
i used to have a twin carb overhead cam cb200 Very Happy
nice bikes and really nice to work on.
good luck mate and look after it Thumbs Up
love my susuki gz 125 maraurder 1998
The last post was made 13 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 135.87 Kb
