| mumbles |
 mumbles Two Stroke Sniffer
| STONEY! |
 STONEY! Brolly Dolly
| Shaft |
 Shaft World Chat Champion
 Posted: 22:41 - 18 Feb 2013 Post subject: |
Do the carbs again, it took me four goes to get mine right.
They are susceptible to everything; they have to be operating theatre clean, the float heights have to be perfect and the needle valves are prone to sticking, amongst other things.
Even after getting it running right, mine would occasionally leak out of the left carb, then it just stopped one day and never did it again.
Use genuine rebuild kits if you can, the pattern ones are gash.
If it makes you feel any better, there's some poor bloke running a resto blog that has never been able to get his right, now he's on his third set of carbs. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| mumbles |
| Shaft |
 Posted: 00:13 - 19 Feb 2013 Post subject: |
| mumbles wrote: |
Shaft: I'm going to clean my carbs again, but just one thing I last time I stripped them I tried to set the float height but the float is plastic how do I set it ? |
That's a good thing, you can't adjust them.
I got so frustrated with mine, I almost resorted to buying a set of plastic floats (that's all that's available now) but they work out at around £100 for the pair, so I persevered!
Blow through everything with compressed air (don't be tempted to poke things through the jets) make sure the plungers are moving freely, nothing is worn and everything is back to factory settings and balanced.
ETA: check the inlet rubbers, they go brittle with age, so make sure they're sealing properly and they haven't got any splits in them, otherwise you'll never get it set up right. ____________________ Things get better with age; I'm close to being magnificent........
| mumbles |
| Shaft |
 Posted: 00:29 - 19 Feb 2013 Post subject: |
Also, check your tank for rust and if in doubt, fit an inline fuel filter. ____________________ Things get better with age; I'm close to being magnificent........
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 13:41 - 19 Feb 2013 Post subject: |
if it were mine,and I had the money i'd buy a couple of new diaphrams. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Shaft |
| bikenut |
 bikenut World Chat Champion
| mumbles |
| bikenut |
| bikenut |
| Pockets |
 Pockets Derestricted Danger
 Posted: 20:44 - 20 Feb 2013 Post subject: |
I have to agree with everything Shaft said earlier, I'm rebuilding a 400 Superdream for no real reason, I've just rebuilt the carbs and still getting niggly little issues like float valves sticking, Shaft is spot-on when he says that you can end up taking the carbs off many times after rebuilding them.
A point worth mentioning is that the Keyster carb rebuild kits don't have the greatest reputation especially the needles, worth bearing in mind.
Finally, have you joined the Superdream forum? there's lots of goo technical assistance available:
https://honda-superdream.proboards.com/index.cgi |
| mumbles |
| suzukirider19... |
 suzukirider19... Nova Slayer
| mumbles |
| prawny1 |
 prawny1 World Chat Champion
| mumbles |
| bezzabsa |
 bezzabsa Scooby Slapper
| mumbles |
| trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
| paddlesat16 |
 paddlesat16 Crazy Courier
 Posted: 16:34 - 02 Mar 2013 Post subject: |
Lumpy idle....
could be the carbs need balancing  ____________________ I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T. |
| mumbles |
 Posted: 16:42 - 04 Mar 2013 Post subject: |
thanks guys engine is running spot on now after adjusting the balance and mixtures screws just the odd pop when revving down now ____________________ Warming the world 2 strokes at a time.
2008 rs50 (SOLD) - 2006 gz125 - (Winter Bike) - 1981 CB250N (In Restoration) |
| titan666 |
 titan666 Scooby Slapper
 Posted: 23:00 - 04 Mar 2013 Post subject: |
i used to have a twin carb overhead cam cb200
nice bikes and really nice to work on.
good luck mate and look after it  ____________________ love my susuki gz 125 maraurder 1998 |
The last post was made 13 years, 8 days ago. Instead of replying here, would creating a new thread be more useful? |
