engine problems!
binge
Emo Kiddy
PostPosted: 22:57 - 16 Nov 2004    Post subject: engine problems! Reply with quote
Right, There are a few little problems with my scooter what I cant fix, and they are bugging me now.
Its a speedfight 1, L/C.
1, When the engine is on tick over, and I turn off the key and take it out, the engine take up to 30 seconds to stall?
2, My K&N air filter has gone a funny shape, its all wonky and bent?
3, Theres a loud rattle coming from near my Variator?
Can anybody help me or has anybody had any similar problems?
Ben...
PostPosted: 23:09 - 16 Nov 2004    Post subject: Reply with quote
1)
When you put the ignition switch to the 'off' position a connection is made which sends the electricity that normally goes to the ignition coil to earth. Either the switch is faulty of the earth connection is erratic.
First spray loads of WD40 into the switch and work the key back and forth a few times. Failing that you will need to test the switch with a multimeter or a battery and bulb, if it checks out ok you will need to follow the wiring to the earth connection and check this is making contact properly.
2) Is something hitting it, such as a foot or part of the bodywork when the suspension moved up and down? Is it next to something really hot (eg exhaust) and melting? Does the bike 'spit back' through the carb on the overrun (which would be the equivalent of hitting the filter with a flame thrower)?
3) I know nothing about these.
binge
Emo Kiddy
PostPosted: 23:30 - 16 Nov 2004    Post subject: Reply with quote
Cheers. I have a feeling ur right on the air filter because it is right below my rear shock.
Ill have a look at my ignition tomorrow, its just worrying me because my ignition runs through the Peugeot immobiliser, and they are like £300 to replace, I really hope it isnt that!
Cheers for ur help
PostPosted: 23:57 - 16 Nov 2004    Post subject: Reply with quote
The switch is usually completley seperate to the immobaliser. It is a simple connection to earth when in the off position.
Your immobaliser will be wired through with various parts of the ignition system but is essentially a secondary switch. You switch on the first one in the normal way using your key. This supplies power to the immobaliser in the normal way (as in a switch going 'on').
After that the complicated stuff happens. I am assuming your immobaliser chip is in the key. When the immobaliser powers up, it looks for the chip which is in your key using an antenna built in to (or often stuck on top of) the ignition switch. If the chip is correct, the immobaliser supplies all the power for the rest of the bike.
So in short, a bike with an immobaliser has a simpler ignition switch than most. There is the 'off' switch which connects the coil to earth when in the off position and the 'on' switch which supplies power to the immobaliser when in the 'on' position. There is also the immobaliser antenna which is not specific to your bike or chip, it is just a glorified loop of wire.
Anyway, lesson ends here, I am confusing/boring you unecessarily. Most ignition switches are in two pieces, the switch itself is seperate to the ignition barrel (the lock part that you put the key in) so changing it is usually just a case of unscrewing the switch part from the bottom of the barrel and undoing a snap connector then replacing it with a new one.
The WD40 will most likley do the trick though.
binge
Emo Kiddy
PostPosted: 00:16 - 17 Nov 2004    Post subject: Reply with quote
Well you learn somthing new every day.
Not it wasnt boring it was helpfull Very Happy .
Cheers mate, ill get out the old WD 2mora.
Ben...
Robby
Dirty Old Man
PostPosted: 07:25 - 17 Nov 2004    Post subject: Reply with quote
This is a 2 stroke, no? It could just be rather coked up too, which will cause it to keep running after the ignition is switched off. Drop some redex into the next two tanks of fuel and really thrash the living daylights out of it.
stryker
PostPosted: 12:12 - 17 Nov 2004    Post subject: Reply with quote
Is the coil grounded to earth to make sure it is discharged? I mean why not just cut off the power supply when the switch is set to off?
Now what?
binge
Emo Kiddy
PostPosted: 22:12 - 17 Nov 2004    Post subject: Reply with quote
Ive sprayed WD alover my ignition barrel and where it is earthed, thats all fine.
It only happens when the bike is on tick over, when im reving it and I turn off the key, it cuts out immidiatly.
the strange noise was comming from the clutch! Ive put my malossi clutch back on and its fine now...
My K&N wasnt fouling with the susspension. It still goes a funny shape after riding the scooter, How can I check if its spitting back through the carb? How can I stop it if it is?
PostPosted: 22:27 - 17 Nov 2004    Post subject: Reply with quote
Doesn't work that way with a CDI ignition. It is 'hard wired' up, the engine is killed by sending the power from the CDI to earth. This is why ned scum bastards just pull all the wiring out from behind the headstock when they steal your bike.
You would hear spitting back through the carb as a kind of popping sound on the overrun.
binge
Emo Kiddy
PostPosted: 00:03 - 18 Nov 2004    Post subject: Reply with quote
I duno, cos I have a filter on and a noisy race pipe, I wont be able to hear it. (unless its loud like a backfire)
I was out on my scoot earlier and as I was riding along, I switched the key off, and it cut out straight away. But then I parked up, and turned off the key, and it ticked over for about... well, It didnt even stop, I had to put my choke on to stall it.
Its definatly getting worse...
Could it be my mixture, and it being too rich so when I cut the key out, there is still some unburnt fuel?
mbknitrof1
PostPosted: 01:06 - 18 Nov 2004    Post subject: Reply with quote
hi, my mate had this on his speedfight 2 it cost him about 400 pound in the end to fix. He had to have all new immobiliser and stuff to sort it,he said in the end u wont be able to start it at all Embarassed
binge
Emo Kiddy
PostPosted: 01:40 - 18 Nov 2004    Post subject: Reply with quote
WHAT?!?
O my god! how gay...
I dont have a problem starting it tho. just a problem switching it off sometimes...
pipnet11
PostPosted: 20:42 - 18 Nov 2004    Post subject: Reply with quote
This is quite unlikely, but try it anyway.
It is possible that the engine has got coked up. This stuff glows red hot inside the cylinder head when the engines running. If there is enough of it, the engine will simply keep going like a glow engine (same as on R/C cars, the ignition is supplyed by a glowing hot plug not a spark). If this is happening it will cause the engine to die the instant you try to put any throttle on or the choke as you said. As there is more cold fuel and air getting in there is not enough heat to keep the ignition going.
As I said this is unlikely, but I have seen it happen. Simple check - as you switch the ignition off at the key pull the spark lead off, if it keeps running its doing what I described, if it stops imediately it is something else.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
cagiva gezzer
PostPosted: 20:55 - 18 Nov 2004    Post subject: Reply with quote
If you get a huge electric shock, its not coked up! Razz
pipnet11
PostPosted: 21:02 - 18 Nov 2004    Post subject: Reply with quote
Is yours not covered in plastic like?? even so it wasnt my best suggestion ever. Laughing
mchaggis
PostPosted: 21:07 - 18 Nov 2004    Post subject: Re: engine problems! Reply with quote
My mum's old CG125 did that, you'd turn the ignition off and remove the keys and the bike would keep running merrily. You had to move the bars to make it stop. Laughing It's probably just a dodgy connection in the ignition.
I must not be a troll...
Mmmm, Guinness
binge
Emo Kiddy
PostPosted: 21:42 - 18 Nov 2004    Post subject: Reply with quote
yep, my HT lead is rubber.
The electric can still jump though Wink .
Ive a feeling that Mchaggis is right. I havnt tried it yet. But it may be just me being wishful.
If it is the immobiliser, Is it hard to completely take it out and bypass the immobiliser and have it as a normal scooter?
Ben...
pipnet11
PostPosted: 21:52 - 18 Nov 2004    Post subject: Reply with quote
These aint lightning style sparks were on about here, they jump 2mm ish through air, not 3-4mm through rubber/plastic.
Almost certainly not the problem anyway, electrics sound much more likely.
PostPosted: 23:00 - 18 Nov 2004    Post subject: Reply with quote
Right then, you hold onto the plug cap of my jawa while I kick it over then.Twisted Evil You can still get a shock off one. I would use some insulated pliers to pull the lead if you are going to, I have had plenty of zaps in my time from touching part of the HT system on a running bike. Shocked
binge
Emo Kiddy
PostPosted: 01:36 - 20 Nov 2004    Post subject: Reply with quote
Right. I striped my speedy down today because I had problems with the wireing anyway. I traced the earth from the ignition barrel right back to the battery, and gave it a good spray in WD, aswel as everything else in the area!
Ive thrashed it around all day IN THE FREEZING COLD! and its great! Not a problem...
oh, By the way, is it my ped, or do you think its the mositure and cold in my airfilter which is causing slugish take off???
cheers... Ben!
There is a gap of 310 days between these two posts...
djflava
PostPosted: 11:31 - 26 Sep 2005    Post subject: PEUGEOT SPEEDFIGHT 2 100CC Reply with quote
HI THERE I AM LOOKING FOR SOME HELP ...
I HAVE JUST BROUGHT A COOL ALARM FOR MY PED AND IT HAS A REMOTE START FUNCTION ON IT WHICH WILL ENABLE ME TO PRESS A BUTTON ON MY KEY FOB AND THE BIKE WILL START BUT.... AND THIS IS A BIG BUT I NEED TO SOME HOW BYPASS THE FACTORY IMOBILISER SO I CAN USE THIS FUNCTION ANYONE HAVE ANY IDEAS IFSO PLEASE GET IN TOUCH DJFLAVA@HOTMAIL.CO.UK MANY THANKS MATT..
The last post was made 20 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 113.93 Kb
