Whats going on here??(Fixed and with piccys)
paddlesat16
PostPosted: 15:28 - 23 Feb 2013    Post subject: Whats going on here??(Fixed and with piccys) Reply with quote
Bike is Aprilia Pegaso 650cc
Symptons:
Bike starts fine, on choke. Then it starts to miss as if one of its cylinders isn't firing(like on a twin cyl) or like it's firing at intermittant strokes. But if I turn on the lights it idles correctly(on choke still and warming) and revs etc but turn off the lights and it's back too missing?? Once fully warm it goes away.
it's a big single and wasn't lumpy at all, idled correctly and ran fine.
This started last week after the last lot of snow, though the bike has been covered, ran and commuted.
Any ideas, cheers
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
Timmeh
PostPosted: 15:33 - 23 Feb 2013    Post subject: Reply with quote
It's italian, ergo the wiring loom will be shot, so you're going to have to get the multimeter out and start prodding things.
Your best bet is looking around the coils first as something is clearly grounding them out.
Copycat73
PostPosted: 15:36 - 23 Feb 2013    Post subject: Reply with quote
possibly damp gettin in ..check condition of multi block connectors & wd-40 anything electrical,under seat,fuel tank & pannels etc... wouldn`t hurt to put a volt meter across the battery terminals and switch the lights on & off with the engine running see what readings you get ?
caveat emptor
paddlesat16
Was afraid somebody would say that, electrickery isn't my best subject Laughing
cheers
Copycat73
PostPosted: 15:41 - 23 Feb 2013    Post subject: Reply with quote
cheers
par for the course m8 Crying or Very sad
caveat emptor
temeluchus
PostPosted: 15:53 - 23 Feb 2013    Post subject: Reply with quote
Hose the electrics down with WD40.
Ariel Badger
PostPosted: 16:33 - 23 Feb 2013    Post subject: Reply with quote
Pull every connector off and drown in WD40. Italian electricity is a very delicate thing.
paddlesat16
PostPosted: 16:50 - 23 Feb 2013    Post subject: Reply with quote
so I got the tester out and working from the workshop manual:
My recharge voltage at 5000rpm is 17.49v it should be between 13-15v
Alternator output at 5000rpm is 78v, anything over 70 is good below 70 is bad
Alternator continuity is good
Voltage regulator failed miserably on tests looks like my reg-rec has died; some terminals not showing any resistance at all. Sad
So what I think is happening is there is too much voltage to the coil, with the lights on it goes within resistance tolerances hence the normal running with the lights on.
Always happens when your skint as well.
I will test the coil tomorrow for its values as i've gotta take of the tank and half the panels just to see the coil Sad
katana
PostPosted: 17:14 - 23 Feb 2013    Post subject: Reply with quote
Don't use wd40 on electrics, it will just make it sticky. It is an oil. It will attract dirt. Use electrical contact cleaner, its what it was designed for.
Check for water in the fuel, give the spark plug a check too and see the colour of the plug. Make sure that the plug lead is on properly and not wet.
katana
PostPosted: 17:22 - 23 Feb 2013    Post subject: Reply with quote
https://www.electrosport.com/media/pdf/fault-finding-diagram.pdf
is your friend
mysterious_rider
PostPosted: 17:37 - 23 Feb 2013    Post subject: Reply with quote
doesn't sound like a 'must fix now' kinda thing. Just run the bike with it's lights on? Then fix when you can afford.
KAWASAKIIIII
paddlesat16
PostPosted: 17:46 - 23 Feb 2013    Post subject: Reply with quote
Might just use the cage and accidently purchase a new reg rec Wink
Being as the weather is fookin freezing at the mo and I definately need a new one also my commute is stupidly long 50 miles a day. Don't wanna breakdown Laughing
Beans on toast for the next week Very Happy
paddlesat16
PostPosted: 17:50 - 23 Feb 2013    Post subject: Reply with quote
is your friend
Thats a cool find Very Happy
Many thanks will spend some time digesting that lot
katana
PostPosted: 18:05 - 23 Feb 2013    Post subject: Reply with quote
Depends on what other damage it does, to the battery for a start. The reg rec will get very hot and just having the lights on wont do much to use up the extra volts.
https://www.electrexworld.co.uk/acatalog/Online_Catalogue_Regulator_Rectifier_206.html
paddlesat16
PostPosted: 18:10 - 23 Feb 2013    Post subject: Reply with quote
I noticed the battery bubbling like mad Shocked don't think this is normal but can't be sure. But it can't be doing it any good getting 17.5 volts.
So I think it's the cage till I get a new reg.
Regards
mysterious_rider
PostPosted: 18:49 - 23 Feb 2013    Post subject: Reply with quote
Regards
definitely dont use! Laughing Laughing Laughing
KAWASAKIIIII
BigGeeking
PostPosted: 07:46 - 24 Feb 2013    Post subject: Reply with quote
Regards
+1 Hand
It will start to damage other things on your bike. 17.5 is very high
Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,,
paddlesat16
PostPosted: 14:15 - 26 Feb 2013    Post subject: Reply with quote
I have purchased the new reg rec Very Happy
Hopefully this baby will sort my woes Mr. Green
Many thanks to all
https://www.electrexworld.co.uk/cgi-bin/sh000001.pl?REFPAGE=http%3a%2f%2fwww%2eelectrexworld%2eco%2euk%2facatalog%2fOnline_Catalogue_Regulator_Rectifier_206%2ehtml&WD=650%20aprilia%20pegaso&PN=RR71%2ehtml%23aRR71#aRR71
paddlesat16
PostPosted: 14:37 - 02 Mar 2013    Post subject: Reply with quote
The new reg rec appeared next day, result Very Happy
https://i245.photobucket.com/albums/gg75/paddlesat16/20130227_125212_zps058bdfd2.jpg
And a couple of hours messing about with a soldering iron, heat shrink and crimpers saw the reg/rec fitted
https://i245.photobucket.com/albums/gg75/paddlesat16/20130227_154700_zpsbccba09f.jpg
Returns a healthy 14.5v and doesn't get hot at all just mildly warm. The battery has stopped bubbling like a witches cauldren Laughing
Pics of the old and decrepid reg/reg/wiring showing lots of heat damage and burning. Was a fire waiting to happen Shocked
https://i245.photobucket.com/albums/gg75/paddlesat16/20130302_155211_zpsd64ab883.jpg
https://i245.photobucket.com/albums/gg75/paddlesat16/20130302_155231_zps85e930f9.jpg
https://i245.photobucket.com/albums/gg75/paddlesat16/20130302_155252_zpsb1875403.jpg
Timmeh
PostPosted: 19:19 - 02 Mar 2013    Post subject: Reply with quote
Shocked
that's some BBQ wiring right there, glad you got it sorted!
The last post was made 12 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 108.9 Kb
