Choking on throttle?
jameswood
PostPosted: 18:36 - 23 Feb 2013    Post subject: Choking on throttle? Reply with quote
any advice? If the throttle is let off when reapplied the engine chokes (coughs, gargles, splutters?) and there is no power then after a second or two it'll rev up and be normal. It only really happens when you are moving, very rare it'll happen when pulling away from a junction though it does occationally especially when the engine isnt up to temperature in the mormning. The lower the engine revs are at the time the worse the choking.
it's running a bit rich but to get to the carbs its a two or three hour job.
The bike is a suzuki intruder 125
thanks!
nightshaddow
PostPosted: 19:28 - 23 Feb 2013    Post subject: Re: Choking on throttle? Reply with quote
thanks!
something wrong if its taking 2-3 hours to get to the carb, looking at the pics 20 mins max
when was the last time it had a service, all things concidered sounds like running rich but could be any number of issues
jameswood
PostPosted: 19:39 - 23 Feb 2013    Post subject: Reply with quote
fuel tank needs to come off unfortunately.
been to the mechanics a couple of times recently but not a full service for a while
Ariel Badger
PostPosted: 19:41 - 23 Feb 2013    Post subject: Reply with quote
Try a new plug first as they are cheap and easy to change then a new air filter. If it is still playing up you need to look at the carbs.
flumpy7
PostPosted: 19:47 - 23 Feb 2013    Post subject: Reply with quote
If you do get the carbs off, make sure you check the float height as well as cleaning and resetting.
2012 Sinnis apache
andym
PostPosted: 21:05 - 23 Feb 2013    Post subject: Reply with quote
I had an intruder 125 as my first proper bike.
I think the carbs was the only thing I didn't work on, on mine.
Anyway this choking, has it only recently started since the cold weather started or does it do it on warmer days too?
One of the problems I had with mine was the carbs freezing and it caused similar problems (although it would sometimes cut out at junctions too).
jameswood
PostPosted: 14:19 - 24 Feb 2013    Post subject: Reply with quote
thanks lads, i'll look into getting some new sparks.
the air filter should have been cleans a month or so back when it was at the mechanics but its fairly battered anyway.
Its far worse in the cold and appalling in the fog, which implies to me its air intake more than anything. it's getting slowly worse however.
woll
PostPosted: 19:48 - 24 Feb 2013    Post subject: Reply with quote
Two or 3 hour job to get at carbs on a bike?!? how?
jameswood
PostPosted: 22:32 - 24 Feb 2013    Post subject: Reply with quote
fuel tank has to come off
woll
PostPosted: 20:07 - 25 Feb 2013    Post subject: Reply with quote
And your point is? I used to be able to get the fairings tank and carbs off my cbr in around 1 1/2hr. On a ghey cruiser 125 I recon it could be done in little over half an hour.
TUG
PostPosted: 21:07 - 25 Feb 2013    Post subject: Reply with quote
With experience then yes probably...
Are you sure the choke isn't stuck on?
Kind of reminds me of the times my old CG's choke levers would flick into the on position and start choking the bike. Laughing
Haz ER-5, innit!
jameswood
PostPosted: 21:52 - 25 Feb 2013    Post subject: Reply with quote
choke lever may have something to do with it, or at least the cable, applying then releasing the lever effects the tick over as if you're adjusting it from the carb if that makes sense, the cable could be sticking in the 'on' position
fuck off if you're not here to help Rolling Eyes
jameswood
PostPosted: 22:40 - 27 Mar 2013    Post subject: Reply with quote
new plugs, no difference. Jet cleaner, however Laughing
sweet as a nut, hopefully someone will find this info useful
blurredman
PostPosted: 23:00 - 27 Mar 2013    Post subject: Reply with quote
How does that work? The lever flicks up to turn the choke on with a CG.. Confused
woll
PostPosted: 22:13 - 28 Mar 2013    Post subject: Reply with quote
I was helping Wink telling you if it takes that long to get your tank of your failing.
Walloper
PostPosted: 07:34 - 29 Mar 2013    Post subject: Reply with quote
C'mon... You didn't reeeealy help did you?
Now... Look deep into your heart and say. 'I wanted to help you but I'm sorry my advice sounded condescending'. (With feeling) Rolling Eyes
The last post was made 13 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 93.68 Kb
