GS500 revving problem
Docker
PostPosted: 15:49 - 24 Feb 2013    Post subject: GS500 revving problem Reply with quote
Hopefully someone might be able to come up with something I havent already checked, basically the bike idles fine but when you rev past 5-6k it loses all power and wont go past that mark.
So far ive checked:
stripped and cleaned carbs
checked compression
checked coils and ht leads
checked fuel vacuum pipe and bypassed it so its a direct feed
changed carb rubber seals
changed carbs (worked perfect the first test yesterday, started doing it again today)
Anyone have any ideas what could be causing it?
flumpy7
PostPosted: 19:34 - 24 Feb 2013    Post subject: Reply with quote
Have you checked float heights?
Have you checked the joins between engine and carbs for leaks?
2012 Sinnis apache
orac
PostPosted: 20:05 - 24 Feb 2013    Post subject: Reply with quote
plugs is the obvious ones, what colour are they
Docker
PostPosted: 20:40 - 24 Feb 2013    Post subject: Reply with quote
yup, even changed the rubbers the carbs connect to.
Plugs are spot on, even tried two spares just incase
Ariel Badger
PostPosted: 20:59 - 24 Feb 2013    Post subject: Reply with quote
What condition is the fuel in? 5 to 6K is about where she will come onto main jet if there is a touch of water in the fuel it will kill it. Take the drain plugs out and drain into your hand, you will see any water.
Docker
PostPosted: 21:28 - 24 Feb 2013    Post subject: Reply with quote
Checked that as well Sad
Casper
PostPosted: 21:33 - 24 Feb 2013    Post subject: Reply with quote
Air filter. My bike runs like shit without one and almost just as bad with a dirty one.
Ariel Badger
PostPosted: 22:09 - 24 Feb 2013    Post subject: Reply with quote
It is not getting fuel when it needs it most so.....Fuel pump (if you have one), fuel filter, tank venting properly ( take the filler cap off and run it).
Docker
PostPosted: 22:14 - 24 Feb 2013    Post subject: Reply with quote
Already checked Sad
Would the air filter really cause this kind of problem?
katana
PostPosted: 22:20 - 24 Feb 2013    Post subject: Reply with quote
When did this start, after the rebuild?
Docker
PostPosted: 23:18 - 24 Feb 2013    Post subject: Reply with quote
it was a project so bought none running
Casper
PostPosted: 23:23 - 24 Feb 2013    Post subject: Reply with quote
To much air will blow a flame out. No air will kill a fire.
J.M.
PostPosted: 01:36 - 25 Feb 2013    Post subject: Reply with quote
Somebody hasn't messed with the main jet sizes have they?
2004 R1 & 2018 XSR900
Docker
PostPosted: 02:21 - 25 Feb 2013    Post subject: Reply with quote
Doubt id be that unlucky on two sets of carbs from diff people, it worked perfectly with the new carb, then the next day it didnt work without any changes
Casper
PostPosted: 02:55 - 25 Feb 2013    Post subject: Reply with quote
Another option is you did not put the carbs back together proper or clean them proper or one of your main jets was not tight and is now sitting in the float bowl
Docker
PostPosted: 03:40 - 25 Feb 2013    Post subject: Reply with quote
Not that either, had the carbs off many times and put it back together exactly how it was before
Docker
PostPosted: 14:53 - 03 Mar 2013    Post subject: Reply with quote
Sad I just want to ride!
Docker
PostPosted: 19:26 - 03 Mar 2013    Post subject: Reply with quote
put the original carb and air filter back on, changed the ht leads to ones i had on a diff bike and it will reach 7-9k revs before bogging this time, next on the list is new coils, seems my test ones may not have been up to scratch either.
The last post was made 13 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 96 Kb
