| Conorday |
 Conorday L Plate Warrior
| paddlesat16 |
 paddlesat16 Crazy Courier
| pits |
 pits World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:59 - 26 Feb 2013 Post subject: |
Do they do much normally when you turn the key?
If it truly "won't do anything" then sure, electrical. Fuse, battery, frame earth. If it does anything at all, do yourself a favour and tell us what.
A pair of front forks will set you back £107.52 plus postage.
I'd bite pit's hand off if I were you. ____________________ Biking is 1/20th as dangerous as horse riding.
| map |
 map Mr Calendar
 Posted: 17:34 - 26 Feb 2013 Post subject: |
With a scooter have you tried pulling the left brake lever and with that still held in pushing the start button? If battery flat do the same with the lever and try kick starting it. Obviously turning ignition to the ON position first for either of those.
As said above forks can be replaced. Not worth hassle of straightening for something like that.
Sell for whatever you can get, don't expect a lot (also see above)  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| P.addy |
 P.addy Red Rocket
| Conorday |
The last post was made 13 years, 130 days ago. Instead of replying here, would creating a new thread be more useful? |
