bleeding rear brake ?
GZXR400
PostPosted: 21:06 - 26 Feb 2013    Post subject: bleeding rear brake ? Reply with quote
I am wanting to change the fluid in my rear brake but the caliper has 2 bleed nipples. I havent bled a brake with 2 bleed nipples so do i bleed just one or one after the other ? Thanks
PostPosted: 21:09 - 26 Feb 2013    Post subject: Reply with quote
Shirley you just bleed from the highest point and ignore the other nipple?
GZXR400
PostPosted: 21:11 - 26 Feb 2013    Post subject: Reply with quote
there both at the same height one on each side
Timmeh
PostPosted: 21:12 - 26 Feb 2013    Post subject: Reply with quote
Just pick one Thumbs Up
PostPosted: 21:13 - 26 Feb 2013    Post subject: Reply with quote
I'd bled using one and see how it felt. If it still felt spongy, bleed from the other nipple too.
kramdra
PostPosted: 00:23 - 27 Feb 2013    Post subject: Reply with quote
This is how Id do it, front or rear brakes. Requires two people for about 5 minutes. No fucking around with bleeding afterwards.
Reverse fill from one bleed nipple using a large (50ml or larger) syringe. Crack the other nipple open while filling to expel any trapped old fluid using a hose into a jar, or floor - wont be much.. While filling* crack open the master cylinder banjo while also pressing lightly on the brake pedal to expel any air** and you will have a perfect, air-free brake.
*this should all be done on the same, continuous stroke of large syringe.
** note its done up to 34Nm, you will want to loosen it off before hand and tighten it up again afterwards, ideally putting new washers in before starting.
Front brake is the same except you crack nipples open while doing the second side for a dual system.
Fizzer Thou
PostPosted: 11:50 - 27 Feb 2013    Post subject: Reply with quote
I have the same setup on the back brake of both my R1 and my Exup.They are twin piston calipers and so you should bleed both sides.Whichever is the easiest to access bleed first,then do the other.
Always have a 'Plan B'
Islander
PostPosted: 12:17 - 27 Feb 2013    Post subject: Reply with quote
Bleed from the nipple furthest from the rear master cylinder. Thumbs Up
GZXR400
PostPosted: 11:26 - 28 Feb 2013    Post subject: Reply with quote
Just snapped the bleed nipple mount off, brake fluid leaking evreywhere.
Dont know what happend connected my brake bleeding kit, topped up the fluid and open the bleed nipple.
Started pumping the brake i immediatly noticed fluid dripping from my caliper so cleaned it up, it contiuned to happen so i thought il stop and tighten the bleed nipple.
I tried to tighten it and it just wouldnt tighten and then the bleed nipple snapped off so its destroyed the caliper now so its useless now and its £375 for a new rear caliper...dont know why i bother
Islander
PostPosted: 11:56 - 28 Feb 2013    Post subject: Reply with quote
That's recoverable. You can try an easy out on the part of the nipple that remains or, if the broken section protrudes sufficiently, you might be able to get hold of it with a pair of molegrips or similar.
Failing that, it can be drilled out and either helicoiled or re-tapped.
GZXR400
PostPosted: 13:43 - 28 Feb 2013    Post subject: Reply with quote
the whole thing has snapped the metal included
Islander
PostPosted: 13:54 - 28 Feb 2013    Post subject: Reply with quote
Pic?
Islander
PostPosted: 13:58 - 28 Feb 2013    Post subject: Reply with quote
If it is truly buggered beyond redemption then this might be of interest to you...
https://www.ebay.co.uk/itm/GSXR400-GK76-Suzuki-Rear-brake-caliper-/110981977225?pt=UK_Motorcycle_Parts&hash=item19d70a9489
GZXR400
PostPosted: 14:11 - 28 Feb 2013    Post subject: Reply with quote
sorry is a zxr 400 and iv completely ripped the metal apart where the threads would be.
Islander
PostPosted: 14:20 - 28 Feb 2013    Post subject: Reply with quote
Ah sorry about that - eBay did its own search thing and I didn't check.
GZXR400
PostPosted: 14:27 - 28 Feb 2013    Post subject: Reply with quote
cant get a caliper anywhere so looks like my bikes off the road
Islander
PostPosted: 14:28 - 28 Feb 2013    Post subject: Reply with quote
Might be worth contacting this chappie.
https://www.ebay.co.uk/itm/Kawasaki-ZXR400-Race-bike-Breaking-/111019122541?pt=UK_Motorcycle_Parts&hash=item19d9415f6d
GZXR400
PostPosted: 15:26 - 28 Feb 2013    Post subject: Reply with quote
thanks i have emailed them but thats a H model my bike is a L model so not sure if the brakes are different
DrDonnyBrago
PostPosted: 15:31 - 28 Feb 2013    Post subject: Reply with quote
Tried a model specific bike forum?
kramdra
PostPosted: 16:13 - 28 Feb 2013    Post subject: Reply with quote
Kawa dont make the brake caliper, it will be made by somone else and probably used on many bikes, as its a rear brake. Does it have a part number stamped on it?
Find a microfishe to get the part number, find where its used, gives a lot more choice. For honda this is easy, but I had a look on ronayers, cant find your bike
https://www.ronayers.com/Fiche/TypeID/26/Type/Motorcycle/MakeID/3/Make/Kawasaki
This has dual nipples
https://www.ronayers.com/Fiche/TypeID/26/Type/Rear_Brake/MakeID/3/Make/Kawasaki/YearID/33/Year/1992/ModelID/3225/Model/Ninja_600R/GroupID/85787/Group/Rear_Brake
GZXR400
PostPosted: 16:47 - 28 Feb 2013    Post subject: Reply with quote
all i can see on the caliper is tokico japan
had a look on zxr world and the microfinche doesent say the brake part number.
Not doing very well here am i ?
kramdra
PostPosted: 17:01 - 28 Feb 2013    Post subject: Reply with quote
its not stamped anywhere on the caliper? get a couple pictures of it to compare with
goto kwak dealer, try to get a part number from them without actually ordering a new one Laughing this may be difficult.
Fizzer Thou
PostPosted: 19:26 - 28 Feb 2013    Post subject: Reply with quote
Try this site https://www.cmsnl.com/kawasaki-zx400_model12783/
If all else fails,take the caliper to an engineering firm.
GZXR400
PostPosted: 20:58 - 10 Mar 2013    Post subject: Reply with quote
bought a caliper should be here in the next few days
what is the best way to bleed the brake as its been completly drained.
I have a 1 way bleeding kit but im a bit worried about using it due to what happend last time but im sure it wasent the problem
GrumpyGuts
PostPosted: 21:37 - 10 Mar 2013    Post subject: Reply with quote
Fill reservoir, pump a few times, hold lever down, crack bleed nipple, close nipple, release lever, repeat.
That's what I did on my rear brake when I fitted braided lines and it bled pretty much straight away!
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
The last post was made 13 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 123.83 Kb
