Keeping a bike outside
Rigga
PostPosted: 21:21 - 03 Mar 2013    Post subject: Keeping a bike outside Reply with quote
So I'll be getting my bike in a few weeks either a gsx 1400 or a xjr 1300. Probably the gsx though!
My question is, it may be a couple of months before I get a shed sorted, will the bike be ok outside under a cover. (putting security to one side for a moment) or will it rust and fall to bits! It will be round the back of the house blocked in by the car so should be ok security wise.
scorps
PostPosted: 21:26 - 03 Mar 2013    Post subject: Reply with quote
ive been keeping my bike outside under a bike barn since march for the past year and its fine, well apart from the scratch on the exhaust cover when the gales managed to blow the barn free from its anchors and send it across the farm yard.
Do not presume that I am male.
Rigga
PostPosted: 21:28 - 03 Mar 2013    Post subject: Reply with quote
Do you use a cover?
angryjonny
PostPosted: 21:29 - 03 Mar 2013    Post subject: Reply with quote
Get a decent cover, use it all the time and be prepared to buy a new one a couple of times a year. The cover will suffer but the bike will be fine. It isn't weather that rots a bike it's salt.
Rigga
PostPosted: 21:33 - 03 Mar 2013    Post subject: Reply with quote
Ok cheers can you recommend a good cover?
scorps
I dont use a cover as the bike barn is big, well i could camp in it but im not very tall.
thx1138
don't feed it after midnight, and don't get it wet, and you'll be fine
haroman666
PostPosted: 21:37 - 03 Mar 2013    Post subject: Reply with quote
My bike stays under a cover most nights. The other nights it doesn't because I cant be arsed to put the cover on.
The only rust there is is on a tiny bit of my fuel tank where the paint has chipped away back to the metal.
Keep it washed and salt free and all should be fine Thumbs Up
Rigga
PostPosted: 21:47 - 03 Mar 2013    Post subject: Reply with quote
What cover do you use mate?
angryjonny
PostPosted: 21:48 - 03 Mar 2013    Post subject: Reply with quote
Anything that's less than six months old and doesn't come from Argos. I don't personally like fabric lined ones as they absorb and then slowly leak moisture - just something toughish and polyester. Doesn't have to be expensive. Better to have a cheap cover and replace it twice a year than to have a pricey one and keep it wet mouldy and torn on your pride and joy for years.
Tomzo47
PostPosted: 21:52 - 03 Mar 2013    Post subject: Reply with quote
GSX is a great bike, my missus's dads got one, hes done about 60,000 miles on it. Its usually kept in a garage however is left in the elements for about 12 hours a day while hes at work and for weeks at a time sometimes when he can't use the garage. Its in a really good condition with hardly any rust or flaking, and whatever there is could be cleaned off in an afternoon. Long story short, cover or no cover, the condition should be fine Thumbs Up (but get a cover because scrotes like shiny things they cant afford)
Ybr 125 > Bandit 650SA > GSXR 600 > Triumph Sprint St1050 > CB1300 > Z1000SX + FJ1200 (written off) > VFR750 >FJ1200
serlant
PostPosted: 21:55 - 03 Mar 2013    Post subject: Reply with quote
bike cover wise I have been using https://www.amazon.co.uk/SUPERBIKE-OUTDOOR-WATERPROOF-MOTORCYCLE-COVER/dp/B00308BCYM/ref=sr_1_1?ie=UTF8&qid=1362347617&sr=8-1 for nearly a year. fits nicely and has 2 clips underneath to stop it blowing off. its made of pretty thick stuff and i've had no problems with it melting even when throwing it on my still hot husqvarna. it is quite pricey but after nearly a year it doesn't show a single bit of loose stiching let alone a tear, has a hole each side front and back to feed a chain through, and has a soft lining in the top.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
haroman666
PostPosted: 22:05 - 03 Mar 2013    Post subject: Reply with quote
I do believe it is this one.
Got it in a large and it's quite baggy on the Bandit 4. But might be worth checking dimensions yourself Thumbs Up
Had it 6 months and there's no sign of wear of degrading just yet.
j00pY
PostPosted: 22:24 - 03 Mar 2013    Post subject: Reply with quote
I've kept mine outside under a cover since July. I've been very good at keeping it covered in ACF50, and I have to say that I am surprised by just how good the bike looks. None of the corrosion on the bike from the previous owner has got any worse. I have definitely stopped worrying about keeping a bike outside.
steady eddie
PostPosted: 00:45 - 04 Mar 2013    Post subject: Reply with quote
I can vouch for the r&g cover. Already lasted well longer than the argos crap, is pretty much waterproof, has lock holes front and back and just feels thick and well made. Think they're £35
Fz50>Ts185>Rd125Lc>Cb250n Superdream "Deluxe" (!)>Kmx200>Tdr250>Yzf600 Thundercat>
Current bikes: 1997 Fireblade RRV & 1989 KMX200
thx1138
PostPosted: 07:48 - 04 Mar 2013    Post subject: Reply with quote
avoid the Tesco cheap motorcycle cover, rubbish, better off cellotaping carrier bags together, and it makes Primark's large sizes look generous with the material.
Wonko The Sane
PostPosted: 08:02 - 04 Mar 2013    Post subject: Reply with quote
my bike has always been kept outside since July. I use an Oxford cover which is breathable.
I was told to never put the cover on when the bike is still warm (would cause condensation) or wet (holds in the damp)
I have a bit of rust here and there on things such as gear linkage and one or two bolts. How much of this is down to being used in most weather or under cover I don't know.
Slacker24seve...
PostPosted: 10:15 - 04 Mar 2013    Post subject: Reply with quote
Oxford Rainex here, quite decent.
A word of warning though, don't put a cover over a bike that's already wet. You'll only make things worse by trapping condensation.
Banger rallies are ace
UrbanRacer
PostPosted: 10:21 - 04 Mar 2013    Post subject: Reply with quote
I have an Oxford Stormex which in my opinion is an excellent cover.
Waterproof, breathable and has a fibre lining inside so it doesn't mark the bodywork underneath it.
cromwell
PostPosted: 11:42 - 04 Mar 2013    Post subject: Reply with quote
I had a pretty decent Oxford camo one a few years back until some scrotes decided to push my bike over and it ripped Evil or Very Mad
"unbelievable"
Current - Suzuki Bandit 600
Ex's - Yamaha YBR 125
Kwakki Si
PostPosted: 12:27 - 04 Mar 2013    Post subject: Reply with quote
My r&g cover fell apart after 6months, I was only taking it on and off a few times a month aswel, maybe i was unlucky and got a dodgy one.
MOD1 passed 26/01/12... MOD2 passed 08/02/12
My current ride: ZX6R NINJA G2, The GREEEEN one!
Is it a bird? Is it a plane? No, it's a mother fucking motorbike!
mossi123uk
PostPosted: 13:47 - 04 Mar 2013    Post subject: Reply with quote
https://www.ebay.co.uk/itm/MOTORBIKE-BIKE-COVER-SHED-MOPED-STORAGE-GARAGE-BARN-MOTORCYCLE-SCOOTER-SPORTS-/140893717729?pt=UK_Motorcycle_Parts&hash=item20cdeb84e1
i been using that for last year no problems
yaigi
PostPosted: 13:55 - 04 Mar 2013    Post subject: Reply with quote
Me and Mr Yaigi have each got one of these:
https://www.amazon.co.uk/OXFORD-STORMEX-MOTORCYCLE-WEATHER-COVER/dp/B000R593AG
They're really decent quality, have kept both bikes dry, and I reckon as far as covers go, are as good as it gets. Would still be much better off in a garage or shed (if only for the convenience alone!), but we don't have one, and they haven't feel to bits yet.
Amber Phoenix
PostPosted: 14:19 - 04 Mar 2013    Post subject: Reply with quote
You can get some decent R&G Covers cheap from their Outlet store on ebay. This is the one I've got, found it pretty decent. Had it six months now, on/off every work day, still holding together fine, just a bit dirty. They're discounted apparently because they've got a slight crinkled finish, however I've found them fine. Clips to hold them on, holes front and back for locking it on (my first was pinched!) and had no issue putting it on straight after pulling up with hot exhaust. It's also got a soft bit inside to go over tank.
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
mysterious_rider
PostPosted: 16:48 - 04 Mar 2013    Post subject: Reply with quote
You big bunch of girls. It's a bike. No point it putting a cover over it. It's only rain, and it's only salt. Didn't even spray it in duck oil this year, and you know what, she's fine.
Covers can cause condensation. And they usually make a sail and your bike falls over.
KAWASAKIIIII
The last post was made 13 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 125.73 Kb
