| wots |
 wots World Chat Champion
| natefz6 |
 natefz6 Brolly Dolly
 Posted: 09:23 - 05 Mar 2013 Post subject: |
I don't know if they have improved but the ones we used to use when I worked at a jewelers years and years ago were shite. Took hours to do anything, you could get a better result using a polishing cloth in about 30 seconds.
That was 15 years ago mind  ____________________ "no I didn't steal it that's just the way I ride" |
| wots |
| BTTD |
 BTTD World Chat Champion
| wots |
| DrDonnyBrago |
 Posted: 09:48 - 05 Mar 2013 Post subject: |
I bought one from Maplins for my fiancee's engagement ring, not quite on the same level as the one you posted.
https://www.maplin.co.uk/ultra-7000-ultrasonic-cleaner-223108
That one was cheaper around Xmas ^^, I paid £30.
I find it does a good job of loosening the crap, but it still requires a bit of brushing etc to actually remove it. I have used a range of solvents, water, soapy water, diet cola, paraffin etc.
I have cleaned pretty much everything in it; rings, keys, fountain pens, coins, watches, parts of the coffee machine, bike parts etc etc etc. Does an ok job but generally it still requires a bit of brushing. It wont remove tarnish, just built up debris.
For carbs I suspect you'd want a half decent solvent if it was to have a chance at loosening anything. |
| wots |
| DrDonnyBrago |
 Posted: 10:01 - 05 Mar 2013 Post subject: |
Indeed, for carb bits you'd want a slightly larger one. The one my OH has, has a bath about 5 cm deep, 15 cm wide and 17 cm long (estimate) |
| Shaft |
 Shaft World Chat Champion
 Posted: 10:57 - 05 Mar 2013 Post subject: |
I bought one from Aldi (it was one their special offer days) last year, when I was fettling my Superdream, I think it was 20 quid.
It did a decent job of getting the crap out of the float bowls and I was able to get most of a brake caliper and mounting bracket in there; couple of bits needed two goes, but I thought it wasn't a bad buy for the money.
I didn't experiment with cleaning solutions, I just used warm water and a few drop of Jizer. ____________________ Things get better with age; I'm close to being magnificent........
| wots |
| BTTD |
| wots |
 Posted: 20:45 - 05 Mar 2013 Post subject: |
Got it home. Tried it with some rings and not much happening.
Added a small amount of Distilled Vinegar, then dropped in my carb. Not a great fit, but wow it works just like the YouTube videos.
I'd get a bigger one, but otherwise seems good. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| covent.gardens |
 covent.gardens World Clap Champion
 Posted: 21:23 - 05 Mar 2013 Post subject: |
Well that's it, seen the videos and now I'm going to have to get one!  |
| wots |
 Posted: 07:03 - 06 Mar 2013 Post subject: |
With a carb the bubbles and muck start rising almost instantly, by the end of 8 minutes (the longest cycle) it was very grey and murky in the tank. Lifted it out and the float bowl (which I'd split) looked super shiny inside. Jets all clean (again separated prior to their bath).
I would definitely suggest getting the biggest one you can afford, or likely you'll regret it later. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| Rowey |
 Rowey World Chat Champion
| wots |
The last post was made 13 years, 2 days ago. Instead of replying here, would creating a new thread be more useful? |
