Exhaust = Lean?
Benson_JV
PostPosted: 20:33 - 05 Mar 2013    Post subject: Exhaust = Lean? Reply with quote
Salutations Gentlemen
I've recently got the CBR out of hibernation and put my straight through pipe on. This one.
Now, from what I understand, a gutless pipe like this will cause the bike to run lean, I know it needs a rejet as it's taken all the midrange but what I'm concerned about is doing damage.
Is this pipe likely to cause any damage to the bike between now and when I get dyno time? (Perhaps next paycheck)
I'll stick the stock can back on if so.
Thank you
Benson
Copycat73
PostPosted: 21:58 - 05 Mar 2013    Post subject: Reply with quote
a lean mixture can cause exhaust valve burn out.
pic is off a car but you get the idear
caveat emptor
Benson_JV
PostPosted: 22:16 - 05 Mar 2013    Post subject: Reply with quote
Not good. I can understand that happening if I set the mixture lean but would an end can do such a thing?
The other thing is (and I will be doing a plug chop next chance I get) but if does smell quite heavily of petrol which I thought was a rich mixture thing, however I've been told that gutless can = lean.
haroman666
PostPosted: 22:21 - 05 Mar 2013    Post subject: Reply with quote
Lean = more heat which = pre-ignition = detonation.
I should note that = means "leads to" rather than "is equal to".
Formerly known as
P.
PostPosted: 23:00 - 05 Mar 2013    Post subject: Reply with quote
Unlikely. Mine states no rejetting is required, as does yours.
PostPosted: 23:11 - 05 Mar 2013    Post subject: Reply with quote
Entirely possible it will screw up the mixture in different ways at different revs. Could easily be lean in some places and rich at others.
Benson_JV
PostPosted: 09:38 - 06 Mar 2013    Post subject: Reply with quote
Thanks gents.
Paddy, I know it states no rejetting required and I went along with that but a friend of a friend said that I'm going to damage things if I didn't, if you haven't had any problems though then I'm happier knowing it'll be fine until I can get it done. Smile
haroman666
PostPosted: 10:39 - 06 Mar 2013    Post subject: Reply with quote
Is it a carbed bike? Or FI?
If carbed; you can make the mixture richer on the needle jet which is what I did when I fitted my can to the Bandit.
Carbs and needle jets are explained here.
At least that will richen up the mixture when you've got the throttle on 3/4's.
And to richen up idle you can screw out the pilot screws a couple of turns.
Benson_JV
PostPosted: 10:53 - 06 Mar 2013    Post subject: Reply with quote
Old '98 carb bike.
Will have a look at that link, thanks! Though I'm not sure about making it run richer across the whole rev range, I may just wait until I can get some dyno time and get the pro's to do it!
The last post was made 12 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 61.24 Kb
