Dropping a cylinder in the wet
J.M.
PostPosted: 12:40 - 07 Mar 2013    Post subject: Dropping a cylinder in the wet Reply with quote
I have no way to describe this other than the bike feels to be dropping a cylinder in the wet. The sound starts to sound all raspy, like the exhaust was blowing, and the idle drops from 1250 to around 500-750. However, once revved above about 5-6rpm, the other cylinder appears to work, although it then drops again when the rpm falls below about 3-4k. If you ride around the 3-5k rpm marker, you can feel the moment sometimes when the second cylinder kicks in, as the bike picks up power fairly swiftly with 0 throttle movement. Lunges forwards almost.
It first happened after performing an emergency stop in the wet a few months ago.
On dry days, the bike runs spot on.
Thinking it was an exposed wire somewhere, I stripped the bike down and re-soldered all joints and replaced all insulation tape with heat shrink. I also removed the wiring for all accessories, including heated grips. This seemed to have fixed it, as I was then riding in the snow with no problems. Most of the days I rode were dry since then, so I kind of forgot about it, as the problem never came back.
I just rode to Uni now in the wet and it happened again.
Any ideas what it could be anyone?
2004 R1 & 2018 XSR900
CaNsA
PostPosted: 12:49 - 07 Mar 2013    Post subject: Reply with quote
Check the sparkplug wells for water.
haroman666
PostPosted: 13:04 - 07 Mar 2013    Post subject: Reply with quote
Does the GS have a hose that take spilt fuel from around the filler cap straight to the top of the Carbs? I know they share a lot of parts with the Bandit 4's and mine suffered in the wet because it just drained water from the filler cap stright to the top of the carbs. Just check under the tank and see how many hoses go from the tank to the carbs/inlet rubber.
J.M.
PostPosted: 13:58 - 07 Mar 2013    Post subject: Reply with quote
GS500FK4. It's too intermittent to be carbs.
The e-stop was months ago. Probably 1.5k miles done since the e-stop happened and it never happens in the dry. Carbs were also last cleaned on the 16th Feb.
I'll check the sparkplug wells for water Thumbs Up Although they are pretty shielded by the fairings, but I'll still check them.
Under the tank on the GS there are 3 pipes: 1 overflow/water drainage pipe which leads completely out of the bike. 2 from the tank petcock in to the main petcock (reserve and main) which then goes in to the carbs.
I just think it's super strange because it never happened before that e-stop. I mean, I was riding home in the wet a few months ago. Had to e-stop. Bike was running perfectly before, upon trying to accelerate away, it was on 1 cylinder.
The other thing to add is that when I got off the bike, it was just running on 1 cylinder. When I return to it about about 5-7pm tonight, it'll be running on both again. (That's what always happened before).
PostPosted: 14:24 - 07 Mar 2013    Post subject: Reply with quote
https://cdn.memegenerator.net/instances/400x/35826431.jpg
Clutchy
PostPosted: 14:28 - 07 Mar 2013    Post subject: Reply with quote
My mate had a GS that did this, not sure of the year though, and it was water getting into the spark plug/cap and a slight tear in the lower end part of the HT lead.
We worked it out by getting it to drop a cylinder in the wet, stop but keep the engine running, then sprayed WD-40 around the cap and the other cylinder fired right up. Thumbs Up
Replaced HT lead, plug and caps and worked fine from then onwards.
Benson_JV
PostPosted: 15:24 - 07 Mar 2013    Post subject: Reply with quote
Apparently happens quite often on the SV's, same symptoms as with your GS. Another shout for sparkplug wells / HT leads.
PostPosted: 15:31 - 07 Mar 2013    Post subject: Reply with quote
Find your coil, unbolt from the frame, clean it all up, all contact points, trim the HT leads, only a small amount off each end and refit.
J.M.
PostPosted: 17:00 - 07 Mar 2013    Post subject: Reply with quote
So it seems the area to check is coils/ht leads then. Bugger, they're a right pain to access Laughing
That's Sunday's job sorted then.
Cheers guys Thumbs Up
haroman666
PostPosted: 17:47 - 07 Mar 2013    Post subject: Reply with quote
I only said carbs cause I had similar sounding problems and ended up spend £££ on new coils/leads/plug caps/plugs and neeeeearly a CDI unit. Then I found out it was a case of removing the hose i mentioned and BAM. Job's a good'n.
But as you dont have the hose, i'll convert to the electrical side of things Laughing Thumbs Up
J.M.
PostPosted: 18:28 - 07 Mar 2013    Post subject: Reply with quote
Bah, barely made it home! Started off... not perfect but not too bad. By the final big hill near my house, I was struggling to hit 30mph with full throttle in 1st or 2nd gear; I think it was first gear.
Then I barely managed to accellerate from 5-10mph going up the slight incline of my drive using 3/4 throttle in 1st gear.
Misfiring like a bitch. Sounds like an open pipe harley almost, albeit much quieter.
Now to try and fix it in fuck all time as I need to make it to a band audition about 10 miles away on the motorway. Fark. Laughing
J.M.
PostPosted: 20:18 - 07 Mar 2013    Post subject: Reply with quote
Well the plug caps appear glued on to the leads for some reason... unsure why.
Removed the fairings, started the engine. Seemed to be running alright. Poured water directly over th right spark plug/cap. Worked fine. Poured water directly over the lft spark plug/cap. Worked fine.
Still had half a bottle of water left so I just chucked it over the bike. Started bogging down. Tried inspecting what was wet. Found a few electrical connector blocks near the right spark plug. Have taped them up in insulation tape so see if that provides any results.
Out of time for trouble shooting tonight... let's see if it can get me where I need to go!
PostPosted: 20:43 - 07 Mar 2013    Post subject: Reply with quote
Let it get dry tomorrow. Remove the tank and cover the fuel pipe, tip water on each part.
Leave it on choke so it revs high, you'll notice where it starts fucking up then.
J.M.
PostPosted: 00:12 - 08 Mar 2013    Post subject: Reply with quote
Dear the cunt that designed my waterproof gloves: we have different definitions of waterproof. Yours is wrong. Sponges aren't waterproof.
Got there and back, just about. It's the right ht lead/coil that foobared. Decided I was being an idiot with my diagnostics...
Had the engine idling on the point where one clinder is just about to bounce in to life but then dies. RPM jumping between 1000 and 1250. Disconnected the right ht lead, steady idle of 1000. Connected it back up, lumpy again.
Will probably check eBay for a used lead/coil and fit it.
J.M.
PostPosted: 01:43 - 08 Mar 2013    Post subject: Reply with quote
2x coils, leads & caps bought for £16.50 delivered. Very Happy
J.M.
PostPosted: 23:46 - 08 Mar 2013    Post subject: Reply with quote
unitynotsocrippledatmo wrote:
measure the resistance on the coils,if it still fks up after replacing the coils/leads/plugcaps then I 'd suspect a cracking cdi unit or knacked/damaged trigger coil.
CDI is a good shout, I should check to ensure there is no water affecting the operation of that.
Wouldn't have thought it would be the trigger as that's always dry and the problem only occurs in the wet. I could take the cover off to inspect it the next time it happens. More likely I suspect would be the wiring from the trigger. Although on the recent GSs, it only uses a single trigger rather than 2 triggers, so I would presume that one cylinder working perfectly would rule out the trigger?
Captain Liberious
PostPosted: 10:46 - 09 Mar 2013    Post subject: Reply with quote
I would say you've got water getting in at one of your plug caps. Had the same problem on a couple of bikes now, both times pulled the plug caps off, get any water out of them, spray with contact cleaner and put back together, wrap with copious amounts of insulation tape.
A squid eating dough in a polyethelene bag is fast and bulbous, got me?
The last post was made 13 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 114.44 Kb
