Changing a rear brake
Trasler
PostPosted: 23:48 - 07 Mar 2013    Post subject: Changing a rear brake Reply with quote
My rear brake is annoying me. It's old, mucky and broken. I can break using it, but it's just a bit... sticky and is quite a bit on/off rather then a gradient.
Is it a job that a v. inexperienced person could do without a proper workshop if he had the parts, or do you think i should take it to a garage?
Current Bike: 2005 Suzuki EN125-2A Grey.
Dream Bikes: Harley Davidson Roadster 883, Triumph Bonneville (British Racing Green) and Norton Commando 961.
Islander
PostPosted: 23:51 - 07 Mar 2013    Post subject: Reply with quote
It's not the hardest job to do by any means but get yourself a manual first if you're not sure of how to do it.
PostPosted: 00:19 - 08 Mar 2013    Post subject: Reply with quote
Drum brake?
Easy. Dismantle, clean, lube ressemble.
I did a howto for beginners using a Honda drum brake but they're all much of a muchness.
https://www.bikechatforums.com/viewtopic.php?t=174773
You might even find that if you oil the pivots and wiggle them about, it smooths off easily. It might even be the lever pivot rather than the brake itself getting gummed up and stiff.
Trasler
PostPosted: 00:37 - 08 Mar 2013    Post subject: Reply with quote
I think i need to replace the rod that goes from the pedal to the brake because it's bent. I'll also need to replace a few things that have got very rusty/worn.
The last post was made 13 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 40.15 Kb
