Steering head bearings
koolio
PostPosted: 00:26 - 10 Mar 2013    Post subject: Steering head bearings Reply with quote
I'm going to be messing around / replacing headstock bearings, had a couple of questions. Bikes are 70s CB450 K3-K5
1) Can you remove the fork yolk / steering stem and replace without having to replace the bearings?
2) The answer to this is probably no, but worth a shot. I have brand new bearings on 1 frame (haven't checked whether they are old type ball bearings or newer tapered type) , the other frame is a spare and requires an MOT to get papers (don't need to get into that subject here).
For the sake of getting an MOT and then storing the frame in question, is it possible to cross the bearings over from one identical frame to another and then later swap them back over?
I can imagine this being possible with the old ball bearing type, but with a tapered bearing hammering out may damage them.
All ears!
MarkJ
PostPosted: 00:46 - 10 Mar 2013    Post subject: Reply with quote
1. If you mean remove the bottom yoke, then yes that's fine. Actually removing the stem from the bottom yoke you'd have to remove the bottom race, but I doubt that's the question you're asking.
2. If the ball bearings fit in both frames then yes you can sue them fine. It's not recommended (in the same way that not putting new sprockets on when you change a drive chain isn't recommended) but would be fine.
Nick_Giles
PostPosted: 10:47 - 10 Mar 2013    Post subject: Reply with quote
unitynotsocrippledatmo wrote:
Knocking top cups out of tubes gently,with a longer drift from underneath,works,The bottom yoke is the prob but a local garage ,or gentle screwdriver may release them enough to come off,just try not to damage the cups,its easy to distort them,use lots of small taps rather than big metal bashing,evenly ,
The bottom shell is always / usually a right bastard to get out.! Crying or Very sad It will have you swearing and bashing your fingers in a right Royal fashion.
An assist to help is if you have a 'Dremil' or similar and cut / grind through the shell. (be careful and take your time) This will let you just tap it out simply. It may even just fall out.
New bearings must be packed with grease. i.e forced into the bearing not just wiped over.
When you reassemble it all make sure the new bearings are seated fully home and square. Don't over tighten the top bolt.!!!!!! - Nip it up and then back it off 1/2 a turn.
Nick
koolio
PostPosted: 15:53 - 10 Mar 2013    Post subject: Reply with quote
Yes I meant the bottom yoke (which is attached to the stem) not the stem from the yoke.
but for the effort and the cheap price of new bearings (loose) you could half retore em and save swapping em back at a later date.
you can replace ball bearings with rollers but the cups..bearing frame inserts are obviously a different shape.
Really you can get cheap loose bearing type for the 450? Where from?
MarkJ
PostPosted: 15:59 - 10 Mar 2013    Post subject: Reply with quote
There's a TRB kit for them here. Probably £30 after VAT and postage
koolio
PostPosted: 21:59 - 16 Mar 2013    Post subject: Reply with quote
I went today to try and get the the steering stem out.
I understand I require an adjustable C-spanner type thing to get it off right? It's mandatory right, no way around it? Clymer mentions a pin spanner.
MarkJ
PostPosted: 22:13 - 16 Mar 2013    Post subject: Reply with quote
Hammer and drift Thumbs Up
J.M.
PostPosted: 22:16 - 16 Mar 2013    Post subject: Reply with quote
I used a hammer + flat headed screwdriver because I was in a hurry. Works a treat, but you will damage it a bit. Not so much to make it unusable or unsafe, but noticeable.
2004 R1 & 2018 XSR900
koolio
PostPosted: 22:45 - 16 Mar 2013    Post subject: Reply with quote
Yea I definitely need a C spanner to do it properly.
koolio
PostPosted: 18:58 - 24 Apr 2013    Post subject: Reply with quote
Right only just got back to deal with this again and with a C spanner.
One frame has new tapered bearings the other has the remaining cups from the old ball bearings.
I cannot for the life of me get the cups from the old ones out, no amount of bashing is helping! Do I have to cut?
The last post was made 12 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 80.08 Kb
