| koolio |
 koolio Spanner Monkey
| MarkJ |
 MarkJ World Chat Champion
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 00:51 - 10 Mar 2013 Post subject: |
suppose you could,if you kept the bearings in each race complete and used the bottom and top frame bearing caps that went with the bearing.
but for the effort and the cheap price of new bearings (loose) you could half retore em and save swapping em back at a later date.
you can replace ball bearings with rollers but the cups..bearing frame inserts are obviously a different shape.
Knocking top cups out of tubes gently,with a longer drift from underneath,works,The bottom yoke is the prob but a local garage ,or gentle screwdriver may release them enough to come off,just try not to damage the cups,its easy to distort them,use lots of small taps rather than big metal bashing,evenly , ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Nick_Giles |
 Nick_Giles Could Be A Chat Bot
 Posted: 10:47 - 10 Mar 2013 Post subject: |
| unitynotsocrippledatmo wrote: |
Knocking top cups out of tubes gently,with a longer drift from underneath,works,The bottom yoke is the prob but a local garage ,or gentle screwdriver may release them enough to come off,just try not to damage the cups,its easy to distort them,use lots of small taps rather than big metal bashing,evenly , |
The bottom shell is always / usually a right bastard to get out.! It will have you swearing and bashing your fingers in a right Royal fashion.
An assist to help is if you have a 'Dremil' or similar and cut / grind through the shell. (be careful and take your time) This will let you just tap it out simply. It may even just fall out.
New bearings must be packed with grease. i.e forced into the bearing not just wiped over.
When you reassemble it all make sure the new bearings are seated fully home and square. Don't over tighten the top bolt.!!!!!! - Nip it up and then back it off 1/2 a turn.
Nick ____________________ Peter Cook: "I have learned from my mistakes, and I am sure I can repeat them exactly". |
| koolio |
 Posted: 15:53 - 10 Mar 2013 Post subject: |
| MarkJ wrote: | 1. If you mean remove the bottom yoke, then yes that's fine. Actually removing the stem from the bottom yoke you'd have to remove the bottom race, but I doubt that's the question you're asking.
2. If the ball bearings fit in both frames then yes you can sue them fine. It's not recommended (in the same way that not putting new sprockets on when you change a drive chain isn't recommended) but would be fine. |
Yes I meant the bottom yoke (which is attached to the stem) not the stem from the yoke.
| Quote: |
Really you can get cheap loose bearing type for the 450? Where from? |
| MarkJ |
 Posted: 15:59 - 10 Mar 2013 Post subject: |
There's a TRB kit for them here. Probably £30 after VAT and postage
| Vincent |
 Vincent Banned
| koolio |
| MarkJ |
 Posted: 22:13 - 16 Mar 2013 Post subject: |
Hammer and drift  |
| J.M. |
 J.M. World Chat Champion
| koolio |
| Vincent |
 Vincent Banned
 Posted: 22:56 - 16 Mar 2013 Post subject: |
| koolio |
The last post was made 12 years, 242 days ago. Instead of replying here, would creating a new thread be more useful? |
