| joss1 |
 joss1 L Plate Warrior
 Posted: 16:24 - 10 Mar 2013 Post subject: CG 125 engine seizure repair or replacement options? |
Yesterday, I bought a 2001 CG 125 nostalgia. However, whilst riding it back on the 80 mile trip home the engine seized,(there was no oil in the engine, the dipstick was screwed in so tightly it was impossible to remove without pliers) so after pushing it for two miles I left it at the nearest garage for safe keeping. Now I am £700 out of pocket, with a CG which doesn't work 50 miles away from me. However, I happen to have a written of CG125-W also 2001 in my garage with a working engine. so I have a few questions regarding my predicament.
1. is it possible to get a seized CG engine working again, or is it irreparable?
2. would it be possible to switch the engine from the broken CG ( which works) with the seized engine?
3. Would the above process be legal, and what would the procedure be for initiating such a change?
this entire ordeal has been an expensive and frustrating one, and I look forward to any advice that can be given, especially that which will help me get back on the road. |
| andym |
 andym World Chat Champion
| numpty2 |
 numpty2 Trackday Trickster
| joss1 |
| andym |
| Kai.Wilson |
 Kai.Wilson Spanner Monkey
| joss1 |
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| Islander |
 Islander World Chat Champion
| jimbob005 |
 jimbob005 Nova Slayer
| joss1 |
| jimbob005 |
| Kickstart |
 Kickstart The Oracle
| joss1 |
| Kickstart |
| devojunior |
 devojunior Brolly Dolly
| bradh511 |
 bradh511 Scooby Slapper
 Posted: 22:10 - 13 Mar 2013 Post subject: |
I would have changed cg engine or even swapped barrel and piston over my self playing with a cg engine is like building a Lego house only takes a few mins 40 to redo top end and about 2hrs max to change the engine ... Just hope u don't get screwed to much on labour... Get your blown engine back .. I would get it apart check the conrod then rebore and a piston and barrel and gasket set and all will be good did u not feel the clutch get funny and makes a whining noise when engine oils low my old one befor to end would use 2 or oil on a 40mile run and my Hartford I've even put a whole in piston and that's still going now when mot's out in April I'll have a top end and piston or engine for sale ____________________ Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013  |
| bradh511 |
 Posted: 23:08 - 13 Mar 2013 Post subject: |
| scarborough_lad |
 scarborough_lad Trackday Trickster
 Posted: 23:37 - 13 Mar 2013 Post subject: |
Well there's a great thread in show and tell about someone who did a few modifications to a CG. How about you head over there and give it a go!
Here's a link https://www.bikechatforums.com/viewtopic.php?t=237889 ____________________ '96 Suzuki GS500 |
| kramdra |
 kramdra World Chat Champion
| smegballs |
 smegballs World Chat Champion
 Posted: 04:21 - 14 Mar 2013 Post subject: Re: CG 125 engine seizure repair or replacement options? |
| kramdra wrote: | Return to seller. He sold you a bike with no oil, it siezed and could have killed you (..rear wheel locks, slides you under a car...)
I dont belive I would accept "sold as seen" in this case, the fact you only got 30 miles.
How can you trust that the rest of the bike will be safe? |
I'd say caveat emptor still applies here, don't you check the oil when buying a bike? It's not an unreasonable check to make.
I mean technically speaking, you are meant to check the oil before you start any engine, be it lawnmower, motorcycle car whatever. I certainly don't, and neither do most people, but there would be a lot less junked engines in the world if people did check.
When you think about a 15 second check compared to the ball ache of a new engine, there really isn't any good excuse for not checking every time you start the engine. |
| joss1 |
| kramdra |
 Posted: 12:37 - 14 Mar 2013 Post subject: Re: CG 125 engine seizure repair or replacement options? |
And how do you know it didnt simply dump the oil or burn it? dumping the oil on your tire could be far worse. The fact is that the seller would have known, been laughing as you failed to check the dipstick, and the failure could have caused you serious injury. If you know where he lives, and he does not know you, then the engine through his window would be a good start although Id personally be demanding for some monies back, assuming you plan to keep it.
Caveat emptor starts imo when you arrive home, unless the seller told you it were un-roadworthy. He is going to do same again to somone else, unless it hurts him.
Ive had a similar experince on my first car, except I did check the oil. It was a burner. Every tank of fuel, it needed new oil, and it took some very hard abuse in the 1.5 years she ran. Although it took more effort to maintain, I had no bad feelings towards the seller, becuase I did get my monies worth from it.
*note* that I use pliers to do up my dipstick. I dont like the idea somone could easily undo it and urinate, for example. |
The last post was made 13 years, 216 days ago. Instead of replying here, would creating a new thread be more useful? |
