| Benno |
 Benno World Chat Champion
 Posted: 14:17 - 12 Mar 2013 Post subject: Chain adjustment issue |
My chain is a bit slack (3 inches of movement!) so I need to tighten it a bit.
But there is some kind of pin over the right side nut that I can't get off (it's a castle nut, I think the correct term is - can this be undone by a normal spanner?). How do I get this thing off without breaking it?
Cleaning the bike would probably help a little bit. It's covered in much and grime  ____________________ I'm autistic. That means I'm smarter than you. |
| P.addy |
 P.addy Formerly known as P.
| Islander |
 Islander World Chat Champion
 Posted: 14:31 - 12 Mar 2013 Post subject: |
Unless its an R shaped sprung one in which case you just pull it out
Don't forget to put it back when you're done. |
| P.addy |
| Islander |
| map |
 map Mr Calendar
| Islander |
| haroman666 |
 haroman666 World Chat Champion
| Benno |
| P.addy |
| Benno |
 Posted: 12:25 - 13 Mar 2013 Post subject: |
Well this pin is proving very hard to take out! And there seems to be a very thick bolt/screw going through the nut. Here's a picture of what I'm working with (I know it's filthy )
I am a total mechanical noob so forgive me
https://cdn.bikechatforums.com/files/imag0510.jpg ____________________ I'm autistic. That means I'm smarter than you. |
| Matt B |
 Matt B World Chat Champion
| Benno |
| Matt B |
| haroman666 |
| Benno |
 Posted: 13:36 - 13 Mar 2013 Post subject: |
This is so typical, I am missing the exact spanner size I need to take it off yet the nut on the other side is a different size that I have the spanner for
Time to do some MORE tool shopping. Although before I do, I watched a video on chain adjustment and the guy only undid the axle nut on the left hand side of the bike before tightening the chain. Thinking about it, is this all I need to do since if I loosen one nut on one side surely the whole thing is loose? ____________________ I'm autistic. That means I'm smarter than you. |
| Matt B |
| Islander |
 Posted: 14:06 - 13 Mar 2013 Post subject: |
Never begrudge buying tools - they'll serve you well in the future if you look after them.  |
| Benno |
 Posted: 14:12 - 13 Mar 2013 Post subject: |
Well I feel stupid. I found all the tools I need in the bike's own toolkit under the seat including a tool to undo the right-side axle nut
Both axle nuts are so f*cking tight though! Can't get them undone. Going to have another go later, soaked them with some WD40 for now. ____________________ I'm autistic. That means I'm smarter than you. |
| Islander |
 Posted: 15:02 - 13 Mar 2013 Post subject: |
Rear spindle nuts are done up pretty tight. Try putting a piece of piping or similar over the end of the spanner that goes on the castellated nut to give you some additional leverage. Bike tool kits often come with something designed to slip over the end of the spanner for exactly this purpose.  |
| map |
 map Mr Calendar
| Benno |
The last post was made 12 years, 339 days ago. Instead of replying here, would creating a new thread be more useful? |
